| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising |  | |
07-20-2008, 10:07 AM
eBay Motors
#11 (permalink)
| | Senior Member
| Mine Is An 04 Lb7 And After I Intalled My Silverline 4 Inch I Have The Same Growl At Idle, It Comes And Goes, But If You Put You Foot On The Exhaust Tip It Will Quit, Which Leads Me To Think The Tranny Crossmenmer Idea Just My .02
__________________ 2004 CHEVY LB7 2500HD, CREW CAB SHORT BED, 4X4, AUTO., PPE BOOST VALVE, EDGE JUICE WITH ATTITUDE, AND QUADZILLA STEALTH, AFE STAGE 2, FASS 95, AND 285 STT`S |
| Advertisement
07-22-2008, 10:50 PM
eBay Motors
#12 (permalink)
| | Super Man Moderator
| Here's the old pics I have of how I bent the mounts for the exhaust. Im 99% sure thats your noise. Mine did it all the time. Thers one next to the rear of the trans that can be bent with a pry bar but theres another one thats a pain I used a rack and a "hootie" pole. You could also use a floor jack as well.
This is the mount by the trans. You can see at the bottom right of the picture how close the exhaust and cross member are.
Bent this mount up as well to give the exhaut more room. Its near the rear of the cab.
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 265/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
07-23-2008, 07:31 AM
eBay Motors
#13 (permalink)
| | DuramaxForum Fanatic
| If its the turbo vanes switching position (go from hissing to rumbling or vise versa) then its completley normal. I don't know exactly why it does it, but its all controlled by the computer. I know that in cold weather it will close the vanes to try and put more backpressure on the motor to warm it up faster, thats one function of it. |
07-23-2008, 09:08 AM
eBay Motors
#14 (permalink)
| | Senior Member
| Thanks man i will try it today
07-27-2008, 08:44 AM
eBay Motors
#15 (permalink)
| | Junior Member
| Well, you guys were right again! The sound was the exaust rubbing.. It seems odd that a growling noise would come from a metal to metal rattle.. Anyway thanks again to all who replied.
__________________ 07.5+ LMM CC/SB Summit White
T Bars up W/ 285's Toyo MT
PPE Hot Race
Magnaflow 4'' SS Turbo back |
07-27-2008, 08:38 PM
eBay Motors
#16 (permalink)
| | Super Man Moderator
| Quote:
Originally Posted by bmoore2156 Well, you guys were right again! The sound was the exaust rubbing.. It seems odd that a growling noise would come from a metal to metal rattle.. Anyway thanks again to all who replied. | Awesome! Glad you figured it out! I scratched my head when mine was making noise to find out what it was and how to fix it.
07-27-2008, 08:48 PM
eBay Motors
#17 (permalink)
| | Senior Member
| I Just Pin Pointed It To The Hanger In The Second Picture I Just Unhooked It From The Hanger, And Now We Good!!
08-15-2008, 06:46 PM
eBay Motors
#18 (permalink)
| | Senior Member
| Back to the same ole problem
08-15-2008, 08:48 PM
eBay Motors
#19 (permalink)
| | Member
| I'm glad some one has explained the change in sounds while idling. From what's been said, will it do this more in the winter time trying to warm it up faster??? Mine seems to only do this when first cranking it up. Whatevr the case it sounds cool to me!! Also it sounds very wild between 2400-3000 rpm's when I'm really getting on it. Didn't expect that!
__________________ 2006 2500 LBZ CREW CAB LONG BED
EDGE JUICE W/ ATTITUDE
315'S W/ 17" GEAR LOCKER 714C WHEELS
FABTECH 6" LIFT
BD EXHAUST MANIFOLD
S&B COLD AIR INTAKE
4" STRAIGHT PIPE EXHAUST
RESONATOR HOLE PLUGGED
1 CARSEAT IN THE BACK- |
08-15-2008, 10:50 PM
eBay Motors
#20 (permalink)
| | Super Man Moderator
| Quote:
Originally Posted by catman_05 Back to the same ole problem | Try hooking the exhaust back up and bend that bracket and the bracket on the trans cross member up with a pry bar. IIRC the bracket on the cross member is real flimsy. So from removing the rear hanger you put more weight on the front hanger and it probably bent down over time. Quote:
Originally Posted by lubeman1969 I'm glad some one has explained the change in sounds while idling. From what's been said, will it do this more in the winter time trying to warm it up faster??? Mine seems to only do this when first cranking it up. Whatevr the case it sounds cool to me!! Also it sounds very wild between 2400-3000 rpm's when I'm really getting on it. Didn't expect that! | Ya it will do it more in the winter. If you let the truck sit for a minute the truck will go into high idle and the veins will open and close. IMO the sound is cool to! I have went outside to start my truck in my shorts and waited in my drive way shivering to hear the high idle kick in
| Advertisement
