| Premium Membership | |
| | | 07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising |  | |
07-24-2008, 12:33 PM
eBay Motors
#11 (permalink)
| | DPF Delete man
| I just got off the phone with quadzilla, and ecm is the same but the operating system could be different, so its a 50% chance it will work. Let me know if wanting to give it a try.
Tyler
__________________ 07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake. Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler |
| Advertisement
07-24-2008, 12:34 PM
eBay Motors
#12 (permalink)
| | DPF Delete man
| Yes even after that, these are not fool proof, its like if you dont pull the fuses with the ppe on the older model trucks.
07-24-2008, 02:37 PM
eBay Motors
#13 (permalink)
| | Junior Member
| thanks for all of the input, its actually a rollback... and its at the dealership right now getting some warranty work done and SUPRISE!! the egr cleaned/replaced, but i will try and get pix as soon as i get it back.... the dealer told me that i "couldnt" use a programer because they would know immediately that it had been used and it would void the warranty, and a "chip" couldnt be used because "if they looked hard enough they could find that it was on there also", but if i take it off before i have any work done that chances are they wont know it was there. Im not looking for big performance gains, mostly fuel mi. so i guess the next questions are
1. what "chip"???
2. airaid drop in filter???
3. banks or other dpf back exhaust???
__________________ 97 Dodge 3500 4x4 Cummins: AEM Brute Force, 4"TBE Straight, Fuel plate & Star wheel adjusted. boost & pyro guages
03 Dodge 3500 Cummins: K+N FIPK, MBRP TBE Straight, Edge Juice/Att. Hot
07 Chevy C5500: stock, need advice!!
Justin |
07-24-2008, 02:42 PM
eBay Motors
#14 (permalink)
| | DPF Delete man
| The stock airbox is fine and the filter is good to. I would consider a Ts Mp8 undetectable once removed, they wont find it on there, and i would consider a mbrp exhaust, but thats just for cost purposes, the banks has the best design.
07-24-2008, 02:49 PM
eBay Motors
#15 (permalink)
| | Junior Member
| this might be a stupid question, but does the mbrp change the sound any on the chevys??
Justin |
07-24-2008, 02:52 PM
eBay Motors
#16 (permalink)
| | Catch Me If You Can!
| Quote:
Originally Posted by jspike91 this might be a stupid question, but does the mbrp change the sound any on the chevys?? | It all depends on what you get. The cat back or DPF back systems will not change the sound, but a turbo back system will.
__________________ KYLE
07-24-2008, 02:55 PM
eBay Motors
#17 (permalink)
| | Junior Member
| the only thing i would be able to do at this point is a dpf back w/out voiding the warranty so far as i know....
Justin |
07-24-2008, 02:56 PM
eBay Motors
#18 (permalink)
| | Junior Member
| so if that is the case, is their any advantage to changing the tailpipe at all?
Justin |
07-24-2008, 02:57 PM
eBay Motors
#19 (permalink)
| Yes if you are worried about the warranty you will have to stick with the dpf back system. Does the 5500 have a dpf on it? I thought the heavy trucks were still exempt. If it does IMO the dpf back exhaust really isan't worth the money. It won't give you any performance gains or egt drops. All of the restriction is in the cat and the dpf. Just my .02 cents.
07-24-2008, 03:02 PM
eBay Motors
#20 (permalink)
| | Junior Member
| Quote:
Originally Posted by BigRedChevy Yes if you are worried about the warranty you will have to stick with the dpf back system. Does the 5500 have a dpf on it? I thought the heavy trucks were still exempt. If it does IMO the dpf back exhaust really isan't worth the money. It won't give you any performance gains or egt drops. All of the restriction is in the cat and the dpf. Just my .02 cents. | thats the response i didnt want, but expected to get...anything manufactured after jan. 1 2007 has to meet these requirements, even semi's. i was told that caterpillar was pulling out of all on road markets for that reason, just like everyone else, the heat from the dpf and the egr is killing the engines... sorry, that was off topic, but back to the original question, will the ts mp-8 help me any with the stock crap still on the truck?
Justin |
| Advertisement
