| Premium Membership | |
| | | 07.5+ LMM Performance Parts Discussion Discussion of Performance Parts For the 07 and up LMM Duramax Trucks No Advertising |  | |
07-24-2008, 03:14 PM
eBay Motors
#21 (permalink)
| | DPF Delete man
| The Ts will help some alot of cummins guys run it and see around 2 mpg gain.
__________________ 07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake. Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler |
| Advertisement
07-24-2008, 10:02 PM
eBay Motors
#22 (permalink)
| | Catch Me If You Can!
| The bad thing about the TS-MP8 is that it is a fueling box which will cause a little more black smoke. Since you will be running it with the dpf you may shorten the life of the DPF filter. If you are going to keep the dpf i would suggest running a banks chip. It will not be traceable since it is a inline chip that alters the readings instead of Flashing the ECM. The banks tunes are "clean" tunes and won't plug your dpf up.
__________________ KYLE
07-25-2008, 11:41 AM
eBay Motors
#23 (permalink)
| | Junior Member
| trust me, i dont want to keep the dpf, but ive only had the truck less than a week, and its sad that its already had warranty work done...whats the banks goin to run $$$?????
__________________ 97 Dodge 3500 4x4 Cummins: AEM Brute Force, 4"TBE Straight, Fuel plate & Star wheel adjusted. boost & pyro guages
03 Dodge 3500 Cummins: K+N FIPK, MBRP TBE Straight, Edge Juice/Att. Hot
07 Chevy C5500: stock, need advice!!
Justin |
07-25-2008, 11:49 AM
eBay Motors
#24 (permalink)
| | DPF Delete man
| with or without pda.
07-25-2008, 11:53 AM
eBay Motors
#25 (permalink)
| | D-Zule Vin-door
| Did you want a Banks package or just piece prices? I have the Banks packages on my site.
__________________ See site for current sales/promotions. Name: Mike Email: 4x4Fantasy@gmail.com Phone: (703) 932-1197 |
07-25-2008, 11:56 AM
eBay Motors
#26 (permalink)
| | DPF Delete man
| And if you were wanting to do a dpf delete in the future, i would just hold off on anything till then. Let me know if i can help with any thing.
07-25-2008, 12:54 PM
eBay Motors
#27 (permalink)
| | Junior Member
| this early in, i just want the mpg gains, if it will help??? when i first got my 2000 F550 i put a superchips and k+n drop in, it jumped it 4 mpg. sometimes more out on the road. but since someone felt they needed it more than we did, its no longer here... the 07 5500 is the replacement. will the banks help any??? or is it pointless with the dpf still attatched???
Justin |
07-25-2008, 12:56 PM
eBay Motors
#28 (permalink)
| | DPF Delete man
| it has clean tune technology so no black smoke but with restrictive exhaust i dont honestly know what kinda gains you will see, i want to say around 2.
07-25-2008, 01:14 PM
eBay Motors
#29 (permalink)
| | Junior Member
| i def. dont need the pda... actually i dont even need the adjustable switch, but thats the only route i see that i have...
Justin |
07-25-2008, 02:15 PM
eBay Motors
#30 (permalink)
| | Duramax Forum Moderator
| most of the warranty troubles and problems with the new engines are traced back to the DPF causing to much heat so IMO i wouldn't hesitate removing the DPF and voiding my warranty,for instance if you increase by 4MPG and over a 10,000 miles period you can save alot of cash so now saved enough that you can do some repairs on your tuck yourself and still be ahead money wise but voiding a warranty it's kinda like me and gambling you win some and lose most.don't feel like you have to follow this advice but we have a local guy here that just did the DPF delete and with a 5MPG increase running a Quadzilla he has saved enough already to make it worth it.
__________________ James
My Truck now,1987 Chevy 2500 350 tweaked,6" SuperLift,350 V8 bored 60 over,Elderbrock headers Cam and Titanium Rockers,750 Twin Pumped Holley Carb and some other goodies.crank dynos over 400HP. |
| Advertisement
