Egr trouble code on 2012 lml - Chevy and GMC Duramax Diesel Forum
post #1 of 17 (permalink) Old 01-14-2012, 12:09 PM Thread Starter
Last night I had a check engine light come on so I pushed the Onstar button they told me if was linked to the egr on the truck..... I was wondern if any of you all had had this code pop up and what was done about it.... Is it safe to drive the truck till Monday rolls around where I can get it to the dealer..
Tyler,24
2012 victory red Chevy 2500hd d/a ex/sb...EFILive by PPEI.....cognito a arms with fox shocks all the way around and steering braces..rare parts tie rod ends..18x9 black xd addicts ...33/12.5/18 toyo open country mt...Ranch hand grill guard ...B&W turn over ball...Armor-thane spray in bed liner...AFE stage 2 intake....Led bulbs here and there....5 inch flo-pro down pipe back exhaust 8 inch black tip....mbrp down pipe.... Egr delete...Auto meter NV boost and pyro gauges ....air dog II 165...built trans with suncoast stuff
Alot more to come
Red012 is offline
post #2 of 17 (permalink) Old 01-14-2012, 01:04 PM Thread Starter
The code is P140C
Tyler,24
Alot more to come
Red012 is offline
post #3 of 17 (permalink) Old 01-14-2012, 11:14 PM Thread Starter
Anyone
Tyler,24
Alot more to come
Red012 is offline
post #4 of 17 (permalink) Old 01-15-2012, 05:04 AM
Na. Haven't and don't remember hearing anybody. Good luck
2011 GMC 3500HD SLT 4x4 DRW CC STORM GRAY/CASHMERE
HS minimax 5' mbrp
2009 CAN AM OUTLANDER 800R (too much to list)
willsdiesel is offline
post #5 of 17 (permalink) Old 01-15-2012, 05:19 AM
Danno001 is offline
post #6 of 17 (permalink) Old 04-14-2012, 08:45 PM
any update on this? Did you get the truck fixed?
My truck got stuck a week ago and about 30 miles after getting pulled out the CEL came on, same p140c code. I was about 800 miles from home so i just reset it. It keeps coming back on and at seemingly quicker rates each time. I stopped at a dealership in Hays Kansas on the way back and they said that to diagnose anything would cost a minimum of 90 bucks because they claim o2 sensor is only covered on 36k mile warranty and i have 53k miles. Shouldnt the o2 sensor be covered in the 100k powertrain warranty, or at the very least, the emissions warranty?
How many O2 sensors are on this thing? I assume the sensor behind the cat and before the dpf is the O2 sensor? I checked it and all the wires look fine to me. Could have some water in that connection there but it looks like it needs a special tool to take it apart. Are there any other O2 sensors besides this one?
In any case, im back home now and plan to take the truck back to where i bought it for the DEF recal and see if they can check this while its in, but any input from you guys would be greatly appreciated.
btw when it got stuck, it wasnt burried or anything, the truck just slid into a ditch because the dirt road turned to soup in the rain.
Edit, found another thread that says diesels dont use o2 sensors and that this code could be because of poor egr flow. Is this true? If so, what would cause this? (i idle the truck A LOT but am always able to drive it on the highway for regens)
2015 Sierra 3500 Denali SRW long bed
2011 Sierra 2500 SLE - sold
TX2011 is offline
post #7 of 17 (permalink) Old 04-16-2012, 06:29 AM
Anyone?
TX2011 is offline
post #8 of 17 (permalink) Old 12-12-2012, 11:36 AM
AWM
AWM's Avatar
Please excuse the thread resurrection but I am now throwing the P140C code. I can only find 3 threads that mention this code and none have an outcome or solution. I installed a S&B intake with an oiled filter on Saturday and on Tuesday, approx. 500 miles later, my CEL came on. Brought it to the dealership today and they showed me a P140C code explanation showing one of the causes as "aftermarket air filter". They hung there hat on this and said no further diagnostics could be completed until the stock box and filter were reinstalled. I purchased some MAF cleaner and plan to clean the MAF check the box connections and clear the code. Any other thoughts or advice?
LML
DELETED/REMOVED/RE-ROUTED
S&B/FASS/FLOPRO
CUSTOM TUNING BY KORY WILLIS
SYNTHETIC MOTORSPORTS
AWM is offline
post #9 of 17 (permalink) Old 12-12-2012, 01:35 PM
GMC..Professional Grade
KensAuto's Avatar
Try cleaning and check tube connections...anything that would throw the MAF off. if that doesn't work, install oem filter. The computor knows exactly what the maf should read under every condition possible, so if it opens the egr a certain amount, the maf should drop to a specific value....it's dropping to much, hence the P0140c, too much egr flow, which means the MAF is reading low (dirty, oily, intake leak, etc.) other things can cause that code, but since it did it immediately after air cleaner replacement you gotta start there
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #10 of 17 (permalink) Old 12-12-2012, 03:58 PM
AWM
AWM's Avatar
Thanks Ken. I did as indicated in my post and what Ken suggested then cleared the code. Drove it over 100 miles without an issue. Hope it is not reoccurring as indicated in other's posts.
LML
S&B/FASS/FLOPRO
AWM is offline
