Losing coolant somewhere in 2012 LML.... - Chevy and GMC Duramax Diesel Forum
post #1 of 86 (permalink) Old 04-13-2012, 05:49 AM Thread Starter
Armalite's Avatar
I'm losing about a half of a quart of coolant everyday in my truck. Its a 2012 LML crew cab 4wd. It started about a week ago. My display flashed low coolant level. I check it, it's down to the min mark. Fill it up to the max mark, and drive it. Next morning, same thing. Down to the min. I drive about 100 miles a day, sometimes more. My truck does sit and idle for 10-15min. at times. Nothing really out of the ordinary. It is not running hot. Where is my coolant going, and has anyone else had this problem? thanks.
Armalite is offline
post #2 of 86 (permalink) Old 04-13-2012, 05:51 AM Thread Starter
Armalite's Avatar
And it's doing this everyday. Not losing more or less, same amount, every day. Top it off in the morning. The next morning, back down to the min mark. Every day.
Armalite is offline
post #3 of 86 (permalink) Old 04-13-2012, 05:53 AM Thread Starter
Armalite's Avatar
I've checked my oil, no sign of it in there, so im at a loss.
Armalite is offline
post #4 of 86 (permalink) Old 04-13-2012, 06:56 AM Thread Starter
Armalite's Avatar
well, its dripping down onto my passenger side cv joint. Got a leak in hose or connection.
Armalite is offline
post #5 of 86 (permalink) Old 04-13-2012, 07:40 AM
Grasshopper101's Avatar
Sounds like you found the problem. Trip to the dealer in the future.
2011 GMC 2500 HD. First ever diesel and loving it.
PPEI tunes by Kory
Flo-Pro 4" exhaust with muffler
EGR blocker plates
DPF/DEF deleted
Air Dog Lift pump.
Edge CTS
Grasshopper101 is offline
post #6 of 86 (permalink) Old 04-13-2012, 08:18 AM
GMCustomerService's Avatar
Armalite,
I'm sorry you are having this issue. Your truck is a 2012 and if you have under 36,000 miles on it, your truck is covered under your bumper to bumper warranty. Have you taken your truck into the dealer for this leak yet?
Evan, GM Customer Service
GMCustomerService is offline
post #7 of 86 (permalink) Old 04-13-2012, 10:25 AM
You're not trying to keep coolant in both sides of the tank are you?
redwngr is online now
post #8 of 86 (permalink) Old 07-15-2012, 03:48 PM
my 2012 lml is leaking too
did the dealer fix it? i have a 2012 with 1800 miles on it and its leaking from the right front corner too!!
sm139028 is offline
post #9 of 86 (permalink) Old 07-15-2012, 05:27 PM
I noticed a couple of drops on my hose today, the lower hose attaching to the radiator or so it appeared. There should be a tsb on this if a lot of people are having issues. My fluid also has never appeared low and I haven't seen any spots on the driveway either.
2012- Denali HD 4x4 2500
Xpel clear bra, amp steps, Inyati Bedliner. Rancho RS5000 Steering Stabilizer-Rancho 9000XL Shocks
PPE PTO-front/rear/Allison covers with transynd and amsoil severe gear oil. Magna-flow DPF back exhaust.
48548 is offline
post #10 of 86 (permalink) Old 07-15-2012, 06:16 PM
Wow, makes me want to buy a new truck.
2008 GMC 3500 SLT Dually 4X4
Dually Club Member #104
Edge Evolution CTS
235/80-17 Toyo AT2
dakster1a is offline
