2011 LML Oil Pump Noise - Page 4 - Chevy and GMC Duramax Diesel Forum
 2Likes
post #31 of 179 (permalink) Old 06-05-2012, 10:46 PM
Originally Posted by sparky660 View Post
From what I can tell we are assuming that it is cavitaion but GM is calling it pulsation. If it is pulsation then it might not be as much of an impact as long as there is sufficient pressure at all times and the oil film mantains its specified thickness.
Cavitation is quite another. I do agree that cavitation will cause vibration but I don't think that the small oil pump is enough to create mechanical failure to anything other then the pump impeller. As long as you don't run an extremely low oil level or extremely high level I highly doubt cavitation is as what we are hearing. Obviously a pump failure due to cavitatiion will lead to a catastophic failure but I don't think this is the case.
These trucks are built the same but there are so many variables that could make my truck louder than yours. Synthetic oil, viscocity, engine break-in, oil fliter construction are just a few things that would have a direct influence on how the oil system will operate and might be the difference between my truck ticking and yours not. They are all built the same but that is where the similarities stop.
I agree. My reference to bearing failure was referring to within the oil pump itself. Of course it's vibration wouldn't cause other bearing failures within the engine. But, I'd be interested to hear from their engineers how an oil pump could pulsate. Never heard of such a thing...how is it an oil pump pulsates? Doesn't the pump spin in direct relation to the engine RPM's?
Great truck... I love mine. Just think GM should look into this before it becomes much bigger issue for the customers with the problem.
Best Regards,
Rusty
2015 Chevy 2500 HD Duramax CC LTZ 4x4 Z71
2015 43ft Sandpiper 376BHOK
Rusty0007 is offline
post #32 of 179 (permalink) Old 06-07-2012, 03:18 PM
Clubin's Avatar
Interesting info. Keep it coming.
Bump
2012 Denali HD
Clubin is offline
post #33 of 179 (permalink) Old 06-08-2012, 06:33 PM
GMC..Professional Grade
KensAuto's Avatar
im finally getting used to the noise, but that may not be a good thing
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #34 of 179 (permalink) Old 06-13-2012, 09:25 AM
Same problem here, right after my 2nd oil change.....nothing normal about this problem and unacceptable....the noise is making me nuts knowing that i still owe 30k and truck sounds like a pos already. I will post the bullcrap printout the dealer gave me later today....( different than oil pump one)
2011 Silverado 2500 4wd ext cab
Deleted - Motor Ops/4" straight pipe
zank28 is offline
post #35 of 179 (permalink) Old 06-13-2012, 09:46 AM
Location: Born on a mountain, raised in a cave .....truckin and fu?#$in is all I crave
I'm wondering if this is the same weird buzzing noise I am getting from my truck. It is a 2010 but I have a weird buzzinf sound that no one has been able to diagnose. I know they updated the oil pumps on the 11s so mine may be different. Any input would help?
andybootz is offline
post #36 of 179 (permalink) Old 06-13-2012, 10:15 AM
Here' what they sent me:
zank28 is offline
post #37 of 179 (permalink) Old 06-13-2012, 11:35 AM
KensAuto's Avatar
they r talking about the famous 'typewriter tick' these r noted for, mine does that to, its differant than the the oil pump whine
Member #19
KensAuto is offline
post #38 of 179 (permalink) Old 06-13-2012, 12:06 PM
gr8shot's Avatar
The typewriter tick is common on the older motors. A lot of folks claim that rotella brings out the tick and running Mobil delvac 1300 super will get rid of the tick.
Is anyone with the noisy oil pump running Mobil delvac oil? Might try it and see if it cures this problem too...
Sent from my old skool Droid
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #39 of 179 (permalink) Old 06-13-2012, 12:21 PM
Taking the Long Way Home
FC5452's Avatar
Send a message via AIM to FC5452
Running Delvac at the dealers request. Squeal went away but after a couple thousand it has sporadically reappeared.
Sent from my Autoguide iPhone app while eating a beef and bean burrito.
S468 with some fuel and a Tuna or two
MY Build
Need or Want Tuning for your Duramax, click Below
FC5452 is offline
post #40 of 179 (permalink) Old 06-13-2012, 04:15 PM
Thanks for the suggestion guys. I will try it. Really hoping it works too ! This clacking is driving me nuts and its only been one day....its getting worse the more i drive too ! (sorry if i'm hijacking the o.p.) I'm gonna make a video of mine and post as well, although it sound the same as o.p. to me.
zank28 is offline
