front axel leak - Chevy and GMC Duramax Diesel Forum
post #1 of 36 (permalink) Old 06-25-2012, 06:36 PM Thread Starter
skidoochris's Avatar
front axel leak
while installing my steering shock I noticed a oil leak on the front diff
on the long side (pass) where the axel is bolted to the diff
with 14000 miles on mine I need to take in asap
I never have good luck with new vehicles and you guys with out the warranty
may want to keep a close eye on that
2012 2500 lml lt ecsb 4x4 moca
285/60 20 duratrac, cognito level kit
rockford fosgate twin 10 subs kenwood 8405 amp
8.5 western pro plow, cci grill and mirror covers
skidoochris is offline
post #2 of 36 (permalink) Old 06-25-2012, 06:54 PM
Mine isn't dripping but it is def gear oil coming out, same place too
2011 GMC 3500HD SLT 4x4 DRW CC STORM GRAY/CASHMERE
HS minimax 5' mbrp
2009 CAN AM OUTLANDER 800R (too much to list)
willsdiesel is offline
post #3 of 36 (permalink) Old 07-03-2012, 12:36 PM
Kaleh08's Avatar
Mine is dripping also. Why?!
Kaleh08 is offline
post #4 of 36 (permalink) Old 07-03-2012, 07:32 PM
I just had mine replaced the dealer said it is a defective seal and had to order a new one it took three days to get in.
Dreck is offline
post #5 of 36 (permalink) Old 07-04-2012, 03:50 AM
That's sucks 3 days hurts when u need your truck
HS minimax 5' mbrp
post #6 of 36 (permalink) Old 07-04-2012, 05:26 AM
Taking the Long Way Home
FC5452's Avatar
Send a message via AIM to FC5452
Seals are wearing at 14K, That's always a comfortable thought. 54K for a truck, and a 2 dollar part giving way
S468 with some fuel and a Tuna or two
MY Build
Need or Want Tuning for your Duramax, click Below
FC5452 is offline
post #7 of 36 (permalink) Old 07-07-2012, 07:40 AM
my passenger side axle seal went at around 7k...the tech i had do the work at GMC is a good friend of mine, and said it appeared it was not assembled correctly from the factory....
92teg92 is offline
post #8 of 36 (permalink) Old 07-16-2012, 01:14 PM
Hitechmotorsports's Avatar
Just noticed my driver side seal leaking, only 4500 miles on it....bummer. I'll be taking it in soon.
2012 LTZ 4x4 crew
Hitechmotorsports is offline
post #9 of 36 (permalink) Old 11-26-2012, 09:28 PM
03sxviper's Avatar
Just noticed that my passenger side seal is leaking as well. I have 65,000kms on my 2011 3500. I wonder if it is covered under the power train warranty or if there will be a recall?
03sxviper is offline
post #10 of 36 (permalink) Old 11-30-2012, 03:18 PM
I just spoke with the dealer about mine leaking as well.. I didn't even get the chance to explain what was leaking .. He cut me off and laughed and told me exactly what was leaking.. Apperently it is very common on the newer trucks
2011 Denali 2500hd
6.5" bds lift, toyo m/t, amp steps
Aprudhomme is offline
