Something I found out about regens... - Chevy and GMC Duramax Diesel Forum
post #1 of 39 (permalink) Old 11-17-2012, 12:25 PM Thread Starter
Chevytuff19's Avatar
So, I was out hog hunting at my ranch last night. My truck hit 44 grams of soot and the high idle started happening. I was in the middle of nowhere on rocky roads, so no way of going 30 mph for the regen to start. I continued to creep around in my truck at a speed of less than 10 mph for a couple of hours. To my surprise, the DPF started to heat up and it started to regen at less than 10 mph. I have an edge insight, so I could actually see the soot being burned off. I was always told regens don't start until 30 mph, so I learned something new last night.
2011 GMC 2500HD Duramax Z-71 CCSB SLE
S&B Dry Cold Air Intake
Ranch Hand Front and Rear Replacement Bumpers (Ridgid Dually Lights on Rear (2)), NFAB 6-Step Nerf Bars, RKI Tool Box, Custom Headache Rack w/ Ridgid Dually Lights (4)
Limo Tint All Around w/ Limo Brow
EDGE CTS Insight, Rancho Steering Stabilizer, Backup Camera
3/4" Lift via Torsion Bars (it was all I could get with stock keys), 285/65/18 Nitto Trail Grapplers
GoLight Stryker HID
XRT Pro on Tow with 4" Flo Pro Exhaust
Chevytuff19 is offline
post #2 of 39 (permalink) Old 11-17-2012, 01:19 PM
Fastereddie's Avatar
Interesting......
2011 chevy 3500hd cc 4x4 drw ltz loaded with snowplow prep. Minimaxx w/ pyro, Drp down pipe, flo-pro 4" cat and dpf delete pipe, banks dpf back. Amsoil fluids front to back.
Fastereddie is offline
post #3 of 39 (permalink) Old 11-17-2012, 01:20 PM
Armus's Avatar
Interesting. While it is understandable they would want the truck to be at speed while the regen occurs, there must be a "desperation mode" that kicks in once the ECM realizes a DPF plugging is imminent.
DPF/SCR technology summarized in three words: It doesn't work.
Armus is online now
post #4 of 39 (permalink) Old 11-17-2012, 01:24 PM
DuramaxForum Guru
HD Dmax Machine's Avatar
I thinks its if the truck is moving itll start to burn off the soot. @ 30mph or faster it burns off the soot faster. & if you get the 'clean exhaust filter' you have to drive 30 mph or faster. @ that point the DPF is near plugged up or it is plugged.
HD Dmax Machine is offline
post #5 of 39 (permalink) Old 11-17-2012, 01:27 PM Thread Starter
It just surprised me that the DPF actually got hot enough to burn the soot. I was actually kind of nervous because I was driving over some tall grass at times and had to keep looking behind me for fires since the DPF was getting close to 1000 degrees.
GoLight Stryker HID
post #6 of 39 (permalink) Old 11-17-2012, 02:42 PM
I'm new to the diesel world and my question is. how do you know when your truck is going into regen? Every now and then I'll get a weird smell and I'm assuming thats when my truck is going through regen???
2012 Chevy Duramax LT 3500 SRW, AMP Running Boards, 20' Fuel Kranks, 305/55/20 Toyo AII, Bilstein 5100 Shocks, Leveling kit.
Traded in:09 GMC Sierra 1500 SLT(it was fun but now enjoying my diesel)
M8chris is offline
post #7 of 39 (permalink) Old 11-17-2012, 02:54 PM
What I noticed in my 2012 is the DIC Compass loses the correct heading and the fuel economy drops quickly. Sometimes I smell the odor sometimes not. I plan to buy a CTS Insight to watch my soot levels.
'12 2500HD, LML, SLE, CCSB, Z71, Factory 18's, Line-X XS350 OR-BL, OPTILUBE XPD, EDGE CTS INSIGHT, RUGGED WW-LINERS
Pottery_Pal is offline
post #8 of 39 (permalink) Old 11-17-2012, 02:55 PM Thread Starter
I have an edge insight monitor, so I can just check the soot levels and DPF temp. The easier way to tell without any gauges is that the truck will idle higher than normal.
GoLight Stryker HID
post #9 of 39 (permalink) Old 11-17-2012, 03:02 PM
So more importantly did you bag a hog?
Sandman_73 is offline
post #10 of 39 (permalink) Old 11-17-2012, 03:05 PM Thread Starter
Haha...no. Only saw 3 and one was in really thick brush and heading away from me. The other two were smaller pigs and were at a full sprint across a brushy field. I don't this I was hunting the right pasture, though. Going to try to go back next weekend and try out a different spot.
GoLight Stryker HID
