Check engine...P2201 & P2202 - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 13 (permalink) Old 12-05-2012, 02:47 PM
NorskeNY's Avatar
Should not cost anything to fix it - covered by the warranty.
Emission Control System Warranty - .
6.6L Duramax Diesel Engines are covered for the first 5 years or 50,000 miles, whichever
comes first.
‐ Specified components for the emission control system are covered for the first 7 years or 70,000 miles, whichever comes first.
. Emission Warranty Parts List
The parts that may affect your vehicle's emissions are on the following pages. These emission parts covered under emission warranties are as follows:
• Federal coverage - refer to the "Federal Emission Control Warranty" previously in this section.
• California coverage - refer to the "California Emission Control Warranty" previously in this section.
Important: Certain parts may be covered beyond these warranties if shown with asterisk(s) as follows:
• (*) 7 years/70,000 miles, whichever comes first, California emission coverage.
• (**) 8 years/80,000 miles, whichever comes first, Federal emission coverage. (Also applies to California certified Light Duty and Medium Duty vehicles.)
Powertrain Control System
Barometric Pressure Sensor
Brake Switch
Camshaft Position Actuator Assembly *
Camshaft Position Actuator Valve
Coolant Fan Control Relay
Coolant Level Sensor
Data Link Connector
Electronic Throttle Control (ETC) Motor
Engine Control Module (ECM) **
Engine Coolant Temp. Sensor
Fast Idle Solenoid
Flexible Fuel Sensor *
Intake Air Temperature Sensor
Malfunction Indicator Lamp
Manifold Absolute Pressure Sensor
Mass Air Flow Sensor (7/70 Tracker Only *)
Oxygen Sensors
Powertrain Control Module (PCM) **
Programmable Read Only Memory (PROM)
Throttle Position Sensor
Throttle Position Switch
Vehicle Control Module (VCM) **
Vehicle Speed Sensor
Transmission Controls and Torque Management
Manual Transmission Clutch Switch
Torque Converter Clutch Switch
Torque Converter Clutch Solenoids
Transmission Control Module **
Transmission Gear Selection Switch (Diesel)
Transmission Internal Mode Switch
Transmission Speed Sensors
Fuel Management System
Common Rail Assembly (6.6L Duramax Diesel) *
Diesel Fuel Injection Pump *
Diesel Fuel Injection Pump Timing Adjust
Diesel Fuel Injector Control Module - EDU (6.6L Duramax Diesel) *
Diesel Fuel Temperature Sensor
Direct Fuel Injector Assembly (6.6L Duramax Diesel) *
Function Block (6.6L Duramax Diesel)
Fuel Injector
Fuel Pressure Regulator
Fuel Rail Assembly
Fuel Rail Sensor (6.6L Duramax Diesel)
Air Management System
Air Cleaner
Air Cleaner Diaphragm Motor
Air Cleaner Resonator
Air Cleaner Temp. Compensator Valve
Air Intake Ducts
Charge Air Control Actuator
Charge Air Control Solenoid Valve
Charge Air Control Valve
Charge Air Cooler (6.6L Duramax Diesel) *
Charge Air Cooler Fan
Idle Air Control Valve
Idle Speed Control Motor
Intake Manifold *
Intake Manifold Tuning Valve
Intake Manifold Tuning Valve Relay
Supercharger Assembly *
Throttle Body *
Throttle Body Heater
Throttle Closing Dashpot
Turbocharger Assembly *
Turbocharger Boost Sensor (6.6L Duramax Diesel)
Turbocharger Oil Separator
Turbocharger Thermo Purge Switch
Vacuum Pump (6.6L Duramax Diesel)
Ignition System
Camshaft Position Sensor(s)
Crankshaft Position Sensor(s)
Distributor *
Distributor Cap
Distributor Pick Up Coil
Distributor Rotor
Glow Plug(s) (Diesel)
Glow Plug Controller (Diesel)
Glow Plug Relay (Diesel)
Ignition Coil(s)
Ignition Control Module
Ignition Timing Adjustment
Knock Sensor
Spark Plug Wires
Spark Plugs
Catalytic Converter System
Catalytic Converter(s) and Muffler if attached as assembly **
Exhaust Manifold (7/70 Only Cadillac 4.6L, Aurora 4.0L, C/K Truck <14,000 GVWR 8.1L*)
Exhaust Manifold with Catalytic Converter attached **
Exhaust Manifold Gasket
Exhaust pipes and/or Mufflers (when located between catalytic converters and exhaust manifold)
Positive Crankcase Ventilation System
Oil Filler Cap
PCV Filter
PCV Oil Separator
PCV Valve
Exhaust Gas Recirculation System
EGR Feed and Delivery Pipes or Cast-in Passages
EGR Valve
EGR Valve Cooler (6.6L Duramax Diesel)
EGR Vacuum Pump Assembly (6.6L Duramax Diesel)
Secondary Air Injection System
Air Pump
Cutoff Valve
Check Valves
Vacuum Control Solenoid
Evaporative Emission Control System (Gasoline Engines)
Canister
Canister Purge Solenoid Valve
Canister Vent Solenoid
Fuel Feed and Return Pipes and Hoses
Fuel Filler Cap
Fuel Limiter Vent Valve *
Fuel Tank Filler Pipe (with restrictor)
Fuel Tank(s) *
Fuel Tank Vacuum or Pressure Sensor
Miscellaneous Items Used with Above Components are Covered
Belts
Boots
Clamps
Connectors
Ducts
Fittings
Gaskets
Grommets
Hoses
Housings
Mounting Hardware
Pipes
Pulleys
Sealing Devices
Springs
Tubes
Wiring
* 7 years/70,000 miles, whichever comes first, California emission coverage.
** 8 years/80,000 miles, whichever comes first, Federal emission coverage. (Also applies to California Certified Light Duty and Medium Duty Vehicles.)
Parts specified in your maintenance schedule as requiring scheduled replacement are covered up to their first replacement interval or the applicable emission warranty coverage period, whichever comes first. If failure of one of these parts results in failure of another part, both will be covered under the Emission Control System warranties.
If equipped, items marked with an asterisk are covered by the California long-term emission control system Defects Warranty for 7 years/70,000 miles. (For example, if one of these parts causes a smog check failure after the 3 year/50,000 mile performance warranty has expired, the part is still covered for 7 years/70,000 miles.)
For detailed information concerning specific parts covered by these emission control system warranties, ask your dealer.
2011 Chevy Silverado 3500HD LTZ CCLB LML SRW 4X4 Blue Granite Metallic.
Towing a 2012 Cruiser Patriot CF335SS fifth wheel.
Previous DAs:
2005 Chevy Silverado 3500 LT CCLB LLY SRW 4X4 Silver Birch Metallic
2004 GMC Sierra 2500HD SE ECLB LB7 4X4 Sand Beige Metallic
NorskeNY is offline
post #12 of 13 (permalink) Old 12-05-2012, 03:18 PM
it should of been free under war. 3yrs 36000 /5 yrs 100000 power train only thing it should of cost is your time taking it to the dealer . if they charged you I would call gm
05 3500 ccdrw lly, complete lbz banks ram-air intake set-up with with super scoope, egr deleted profab intake elbow , diamond eye 4' duals , diamond eye down pipe and no kitty efi by full throttle customs , edge insight cts for gauges ,lbz mp. and fuildamper .pcv reroute,right and left side boost tubes, banks techi cooler ppe ported fitting , afe rear diff cover magtec trans pan ,does it ever end airdog 2 165 bd manifold, merchant transfercase brace and rub kit , transgo jr, custom convertor . earls 82510aerl for trans cooler ,hellwig bigwig rear sway bar , fleece tap shifter
www.alligatorperformance.com
www.merchant-automotive.com
www.madjacksynthics.com
happyduramax is offline
post #13 of 13 (permalink) Old 12-06-2012, 08:21 AM
GMCustomerService's Avatar
Iím happy youíre healing wonderfully, kerrlakelover!
Unfortunately, I donít have access to the information youíre seeking about the NOX sensor. However, I can look into the warranty and possible cost assistance with this. Iíll send you a private message of the information Iíll need to get looking into this for you.
Michelle, GM Customer Service
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
GMCustomerService is offline
