Edge Insight - Chevy and GMC Duramax Diesel Forum
post #1 of 19 (permalink) Old 12-26-2012, 01:25 PM Thread Starter
Edge Insight
Just wondering if somebody can answer my quesion. Can I put an edge insight controller in my truck without voiding the warrant if I leave it at the stock horsepower? I just want it so I can monitor everything and to erase codes with. thanks..
Duchek is offline
post #2 of 19 (permalink) Old 12-26-2012, 01:41 PM
812-200-2200
Meyerperformance's Avatar
The CTS Insight won't void your warranty, all it does is read data.
Meyerperformance is offline
post #3 of 19 (permalink) Old 12-26-2012, 01:41 PM
Pat H's Avatar
The insight doesn't change the power level of a truck (unless it's a LB7/LLY with EFI tuning), so it should not have any effect on warranty.
2010 Chevy 2500HD CCSB LMM
A few things here and there installed
Originally Posted by danhr View Post
well you have reduced power..... you fix it by adding more power
Pat H is offline
post #4 of 19 (permalink) Old 12-26-2012, 04:16 PM
Insight is not a 'controller' it is a 'monitor', so no problems with warranty.
redwngr is offline
post #5 of 19 (permalink) Old 12-26-2012, 04:20 PM
DLB
DLB's Avatar
^All correct. I've had mine in for warranty repair with my Insight CTS installed and the dealer never said a word.
2013 Silverado 1500
275/60R20 AXTs, 2" level, UnderCover Flex, BedRug, WeatherTechs
2015 GMC Yukon XL SLT - SOLD
Husky Liners throughout, HID lows, LED fogs
2011 Duramax LML - SOLD
LTZ, Z71 pkg, VYU pkg, CCSB
AMSOIL in the diffs Edge Insight CTS FASS 150 FLO~PRO 5" exhaust H&S Performance LINE-X bedliner Mobil 1 5w-40 syn PPE Diff Cover Rough Country steering stabilizer TranSynd Trifold Tonneau Cover
DLB is offline
post #6 of 19 (permalink) Old 12-26-2012, 05:16 PM
BigDW's Avatar
It'll void your warranty as soon as you plug it in.
Edit - Oh, sorry.. I am wrong!
BigDW is offline
post #7 of 19 (permalink) Old 12-26-2012, 05:18 PM
Hang it!...Fire!
TDIpowered's Avatar
Wrong
Max - 07 LBZ ECLB LOWERED!
TDIpowered is offline
post #8 of 19 (permalink) Old 12-26-2012, 05:42 PM
6dot6's Avatar
lol
2014 ram 3500 dually staying stock
6dot6 is offline
post #9 of 19 (permalink) Old 12-26-2012, 06:09 PM
Question, With the Insight can you add on the EGT prob and turbo timer, or do you need the tuner aswell?
2010 GMC SLE 2500HD 4x4 White CCSB 33 TOYO AT2's Method Racing Wheels Kryponite A-arms - Kryptonite sway bar ends Rare parts tie rods Moog Idler & Pitman arms - Cognito PISK - Fox 2.0 shocks McGaughty drop shackles Edge Insight EAS and backup camera PPE modded air box MBRP 4inch DPF back Line-X Amp steps Fumoto valve Firestone towbags w/ compressor JL10 sub and amp - Katzkin leather seats - Filled with Amsoil
GMCRIG is offline
post #10 of 19 (permalink) Old 12-26-2012, 08:22 PM
Grasshopper101's Avatar
If reading the EGT in 4 locations isn't enough for you, you can add the probe. I'm not sure about the turbo timer.
2011 GMC 2500 HD. First ever diesel and loving it.
PPEI tunes by Kory
Flo-Pro 4" exhaust with muffler
EGR blocker plates
DPF/DEF deleted
Air Dog Lift pump.
Edge CTS
Grasshopper101 is offline
