Cold weather disappointment and frustration! - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 48 (permalink) Old 01-14-2013, 02:09 PM
DuramaxForum Guru
HD Dmax Machine's Avatar
Im betting fuel gelled. Im truck started I cycled the glow plugs 2x & started just right. If it was fuel gelling do add some anti gel additive.
HD Dmax Machine is online now
post #12 of 48 (permalink) Old 01-14-2013, 03:02 PM Thread Starter
I went home about 4 hours later (heater plugged in) and it stumbled once and then started up. I donít believe it was fuel just the engine not wanting to stay running once the initial kick started. Really weird if you ask me. All my Fords would start without plugging in at much colder temps and it sounds like you guys are too. They would run rough for maybe 5 minutes at the most ever but after that they were fine.
I agree that 9 degrees should not be a problem. Iíll leave it unplugged tonight and see what happens in the morning.
Collimare is offline
post #13 of 48 (permalink) Old 01-14-2013, 04:34 PM
Glad you got it started. I'm amazed how many people on here don't plug in there rigs. I have mine on a timer so it comes on 2 hrs before I leave, the glow plugs don't even come on and it warms up much faster. Extend the life of the glow plugs and possibly engine? No brainer for me.
Jeremiah
2006 LBZ W/ EFI DSP 5 by RGR Racing, DP 3794 Stg 2 Turbo, AFE intake and 4" EX. Down pipe, EGR blocked, Autometer boost & pyro gauges. All Amsoil. 235k Miles
D2DAMAX is offline
post #14 of 48 (permalink) Old 01-14-2013, 05:13 PM Thread Starter
I have a new truck that I have no experience with and now no confidence. I want to know that it is going to crank in my driveway under normal cold conditions, not when I am out in the middle of nowhere hunting, skiing, on the road towing or parked at the airport for several nights.
I believe I was told the truck would crank down to -20 without issue. 9-10 is a long ways from -20.
Once I have confidence in the truck I donít mind plugging it in when it gets really cold, but it never gets cold enough not to crank in Denver. If it does not crank in the morning it will be towed to the dealer. I am not messing with a truck that wonít crank when it is well above its cold crank specifications or other brands I have owned.
post #15 of 48 (permalink) Old 01-14-2013, 06:02 PM
Collimare, your truck should definitely not need to be plugged it when above 0*F, as others (and your owners manual) have said.
Since it it is new, the dealer should be helping resolve this issue.
redwngr is online now
post #16 of 48 (permalink) Old 01-14-2013, 06:28 PM
E_money's Avatar
It could still be a fuel issue. When you plug it in there is a fuel filter heater that comes on and may have ungeled the fuel in the filter.
2010 LMM CCSB all stock for now
E_money is offline
post #17 of 48 (permalink) Old 01-14-2013, 06:29 PM
DENALI HD3500's Avatar
On myy 3rd winter with the lml. Have never used block heater. It is still curled up under hood. ~18c this morning. I suspect poor fuel. Dealer will help.
2015 SLT CCSB Summit White on Jet Black sunroof/rear slider/driver alert/ cooled/heated leather/nav/ telescope/tilt steer... Z71 package .
Previous:2002 LB7 ECSB
2005 LLY CCSB
2007.5 LMM CCSB
2010 CTD CCSB
2011 LML CCSB
DENALI HD3500 is offline
post #18 of 48 (permalink) Old 01-14-2013, 06:42 PM
2009DuramaxLTZ's Avatar
Im gonna say fuel issue also. I never plug in my truck. When its super cold I cycle the key a few times and never have a problem.
09 LMM CCSB LTZ
MBRP 5" Turbo Back, Diamond Eye Down Pipe, 6" Stack, EFI Live Dsp5, Moto Metal 951 35X12.50X20 Nitto Trail Grapplers
6" Zone Suspension Lift, Isspro EV2 Pyro, Boost & Trans, Nicktane Filter Adapter.
08 Dmax RCLB Stock (Dad's)
88 Mustang GT 347 Stroker 125 Shot Of N2O
- Justin
2009DuramaxLTZ is offline
post #19 of 48 (permalink) Old 01-14-2013, 08:35 PM
I don't have any problems starting my 2011 lml and I don't plug it in and it gets down to -7 at my house. Be careful where you get your fuel though. Sometimes when you bargain shop for fuel you end up in these types of situations. A buddy of mine bought fuel at a store that he doesn't normally go to because it was cheap and had the same problem as you and had it towed to the dealer and there was water in the tank. After pulling the tank they pulled about a gallon of water from it he may have shaled the motor and he's having to fight GM over the bill.
Lowelife is offline
post #20 of 48 (permalink) Old 01-14-2013, 08:43 PM Thread Starter
I did buy from a station that I normally do not buy from as I try to always put Shell in but did not have time last tank so I have decided to give the truck the benefit of the doubt and plugged it in. What winter fuel conditioner do you recommend? It is also about time for me to change the oil and I am going to put synthetic in now that I have about 10K on it. I always do this after break in as it makes a big difference in cold cranking. Thanks for all the input.
