2011 Electrical Problem - Chevy and GMC Duramax Diesel Forum
post #1 of 18 (permalink) Old 01-17-2013, 06:45 AM Thread Starter
Has anyone heard of any problems with these trucks regarding the electrical.
Here's my problem: Driving truck and gauges started going down to zero/radio shut off/heater quit working/DIC went through alot of problems (check tire pressure/air bags/4wheel drive/etc.) It would do this in approx. 15 minute intervals. I tried to drive it the next day to the dealer and it wouldn't start, so I had it towed. Dealer has been problem solving for a week and can't find the problem, but the truck is mysteriously running fine now, so I am getting it back.
Does anyone have any advice on this. The truck has 25k on it and this is a sudden problem.
Thanks in advance.
PA_DEEREMAN is offline
post #2 of 18 (permalink) Old 01-17-2013, 07:03 AM
AWM
AWM's Avatar
Can’t say I have heard of this.... Keep us updated.
LML
DELETED/REMOVED/RE-ROUTED
S&B/FASS/FLOPRO
CUSTOM TUNING BY KORY WILLIS
SYNTHETIC MOTORSPORTS
AWM is offline
post #3 of 18 (permalink) Old 01-17-2013, 02:49 PM
Guest
never heard of such but am very interested to hear what happened.
Cayenne is offline
post #4 of 18 (permalink) Old 01-17-2013, 02:58 PM
Grasshopper101's Avatar
It sounds like a weak alternator that is just keeping the battery barely working.
2011 GMC 2500 HD. First ever diesel and loving it.
PPEI tunes by Kory
Flo-Pro 4" exhaust with muffler
EGR blocker plates
DPF/DEF deleted
Air Dog Lift pump.
Edge CTS
Grasshopper101 is offline
post #5 of 18 (permalink) Old 01-17-2013, 03:26 PM
GMC..Professional Grade
KensAuto's Avatar
Could be anything to do with main power feeds. Battery, batt connections, alternator or lead to alternator, main power leads to underhood fuse block (especially if someone has added something and tied into a main lead somewhere), ground connections, well you get the idea, it really could be anything on these complicated vehicles.
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #6 of 18 (permalink) Old 01-17-2013, 04:19 PM
Agree. I had a vehicle years ago that did weird things like that and it was eventually tracked to the alternator but a bad connection would do the same thing.
PPEI tunes by Kory
EGR blocker plates
DPF/DEF deleted
Air Dog Lift pump.
Edge CTS
post #7 of 18 (permalink) Old 01-17-2013, 09:50 PM
DENALI HD3500's Avatar
I agree. I would lean more towards a bad (green) ground, or corroded PCM wire.
2015 SLT CCSB Summit White on Jet Black sunroof/rear slider/driver alert/ cooled/heated leather/nav/ telescope/tilt steer... Z71 package .
Previous:2002 LB7 ECSB
2005 LLY CCSB
2007.5 LMM CCSB
2010 CTD CCSB
2011 LML CCSB
DENALI HD3500 is offline
post #8 of 18 (permalink) Old 01-17-2013, 09:56 PM
FireRescue's Avatar
Which trucks had the wiring harness that rubbed and caused problems? Anyway, have batteries checked seperately, have the alternator checked, maybe belts and pulleys. But I would bet it's a wiring issue / connection issue somewhere.
Bryan
2011 Chevrolet Silverado 2500HD WT, Victory Red, 4x4, ECLB, Duramax(LML)/Allison, Heavy Duty Towing Package
Insalled: Amp Research, Amsoil, ATS, Autometer, B&W, Back Rack, Bushwacker, Code Alarm, Cognito, DRP, FASS, Goodyear, H&S, Hypertech, Mayhem, MBRP, Plasti Dip, Precision, Ranch Hand, Rearview Saftey, Rhino Linings, Rigid Industries, Rough Country, S&B, Snow Performance, Titan, Warn, Weather Guard
Need the Guts to Install: Frost Fighter.
FireRescue is offline
post #9 of 18 (permalink) Old 01-17-2013, 10:26 PM
This may have changed between 06-11 but I had electrical issues with my stereo, mirror display and airbag light. At first I thought it was just a fuse because my airbag fuse was blown. Replaced it and it was fine for a week or so... Then it happened again, after I released my e-brake. I found a wiring harness on the DS floor board that is behind the e-brake arm, so after pushing it down many times it rubbed the wire coating off and grounded, causing my issues and blown fuses. Repaired the wire and moved harness and haven't had the problem since.
Jeremiah
2006 LBZ W/ EFI DSP 5 by RGR Racing, DP 3794 Stg 2 Turbo, AFE intake and 4" EX. Down pipe, EGR blocked, Autometer boost & pyro gauges. All Amsoil. 235k Miles
D2DAMAX is offline
post #10 of 18 (permalink) Old 01-18-2013, 01:49 AM
Charliechevy's Avatar
Agreed. I had this happen to me on a couple occasions in a gas motor, can be a real PITA if the dealers are clueless.
2015 Chevy 2500 HD Duramax, Crew Cab Z71 LT, Stock for now, Morimoto Retro Kit soon.
Charliechevy is offline
