What does LML stand for - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 08-21-2013, 05:37 PM Thread Starter
LMLandLBZduramax's Avatar
ik the lml is the 2011+ duramax but what does it stand for
LMLandLBZduramax is offline
post #2 of 16 (permalink) Old 08-21-2013, 05:44 PM
Ask one to be one
usafracer's Avatar
Its the 3 digit code gm uses to identify the engine family. They have been doing it for years.
Marty
2010 GMC Sierra CC SB 4X4 Cognito 6" lift and 315/70/17 ATP Tuned!!
2008 GMC Sierra Crew Cab 4X4 (wifes) Zone lift set close to 4" 305/70/17's Hankook Dyna Pro RF-10 ATM
usafracer is offline
post #3 of 16 (permalink) Old 08-21-2013, 06:02 PM
rparlee's Avatar
More specifically, its the RPO code. Look in your glovebox and it will be listed.
Ryan
2006 GMC Sierra 3500 SLT CCLB 4x4
Mods: EGR block, EFI LIVE by Rob (DSP5), Edge Insight CTS2 w/ backup cam and EGT probe, Pacer 07.5+ smoked cab lights, M-A Pump rub fix, TransGo Jr w/ Mike L springs, Russell stainless brake lines.
My Build Thread
rparlee is offline
post #4 of 16 (permalink) Old 09-11-2013, 06:42 PM
Little money left
Lol!
Jb904 is offline
post #5 of 16 (permalink) Old 09-11-2013, 06:51 PM
NorskeNY's Avatar
Not sure how they came up with the RPO engine codes but - - - RPO stands for Regular Production Option. Manufacturing site: Moraine, Ohio
01-04 LB7 Injectors housed inside valve covers and no EGR, with the exception of California models
________________________________________
04-06 LLY Introduction of Garrett VGT turbo and EGR
06-07 LBZ Revised piston design lowered compression ratio to 16.8:1 from 17.5:1, a stronger block debuted, and a 32-bit ECU was introduced
07-10 LMM Introduction of DPF and exhaust after treatment
2011 LML Extra fuel injector placed behind turbo, urea injection, and dual-loop EGR system
2011 LGH Detuned version for 2500 and 3500 vans and will use GM's 6L90 six-speed transmission instead of the Allison 1000
Duramax V8 engine - Wikipedia, the free encyclopedia
and
http://duramax-engines.com/6-6l-dura...sel-engine-lml
2011 Chevy Silverado 3500HD LTZ CCLB LML SRW 4X4 Blue Granite Metallic.
Towing a 2012 Cruiser Patriot CF335SS fifth wheel.
Previous DAs:
2005 Chevy Silverado 3500 LT CCLB LLY SRW 4X4 Silver Birch Metallic
2004 GMC Sierra 2500HD SE ECLB LB7 4X4 Sand Beige Metallic
NorskeNY is offline
post #6 of 16 (permalink) Old 09-11-2013, 07:08 PM
rinkman07's Avatar
LML = Lost My Leg bahahaha ZING!
rinkman07 is offline
post #7 of 16 (permalink) Old 09-11-2013, 07:18 PM
lugnut's Avatar
GM has been using the 3 letter designation for years. All engine in GM vehicles will begin with the letter "L". This applies to all gas and diesel engines. The same is true for all transmissions, the only difference is they start with a "M". The "L" designation for engines is piece of history for GM. On rare occasions, they reuse the RPO, but it is very rare. A lot of GM vehicles have been identified over the years by RPO. Some of the more famous ones in my opinion are Z71 - used on 4x4 trucks, ZR1 - used on HP Corvettes, Z28 - used on Camaro's. There are plenty more. Hope that helps.
2006 2500HD LBZ 4X4 CC/SB LT3, 265/75R16, Rhino Liner, PCV Reroute, Resonator Plugged, 35w 6K HID Low Beam & Fog Lights, LED Interior Lights, ISSPro Pyro, Boost, & Rail Pressure Gauges in A-Pillar, Cognito Idler/Pitman supports, more to come soon.
1996 K2500 Suburban 7.4L, 265/75R16, Brush Guard, Nerf Bars
lugnut is offline
post #8 of 16 (permalink) Old 09-11-2013, 07:33 PM
LHN...We ARE the Joneses
L88
Hook'em_Horns! is online now
post #9 of 16 (permalink) Old 09-11-2013, 08:21 PM
rinkman07's Avatar
L88
Old corvette motor?
post #10 of 16 (permalink) Old 09-11-2013, 09:06 PM
Oh yeah.
Less than 2 dozen made in '67, before the body change to stingray in '68.
L88 Coupe
Got to drive a '68 years ago; sent as a runner to go pick up the Boss' wife's car from the shop. I was the only one in the office at the time that knew how to drive a stick and No one bothered to mention beforehand, anything about this car. Just a raised eyebrow and half a grin, "Don't mess it up, I wouldn't want her mad at me if I was you!" I just thought it was another Red 'vette with a 350 and loud exhaust....not a 600hp beast with a wicked clutch. Scary.
