DEF?s and usage? - Chevy and GMC Duramax Diesel Forum
post #1 of 25 (permalink) Old 10-09-2013, 03:29 PM Thread Starter
DEF?s and usage?
I just bought a 2013 2500 duramax put just shy of 2000 miles on it and checked def on dic said 22% left added 2 gallons all good major ? is how often do you add def or how many miles do you get out of the def, I drive a mix of highway and in town I plan on using and keeping gm def on hand aprox a case at a time or 2 I do not want quality issues with it.
I am loving this truck and am pretty up on preventative maintenance fluid and filters.
I had no idea if tank was full from dealer when I bought it?
thanks in advance
carl
cgff is offline
post #2 of 25 (permalink) Old 10-09-2013, 03:38 PM
About 1000mi to a gallon. Tank is 5.5gallon I believe.
2012 Quicksilver SLT CCSB Sub 200mi regen club, fuel guzzling, dealer queen LEMON...
Amp Powersteps
Insight CTS
305/55/20 Mickey ATZ P3
Bilstein 5100s
Rancho stabilizer
B&W Turnover Ball w/Andersen Ultimate 5er Hitch
Sandman_73 is offline
post #3 of 25 (permalink) Old 10-09-2013, 03:46 PM Thread Starter
thanks for the info I have been searching and am finding different info
I plan on keeping a gallon or 2 on hand in truck and maybe a case in garage
added 2 gallons this evening all good have 2 on hand and will be buying a case from dealer on friday.
The station I usually fuel at and time of morning I fuel at does not have def available other then during normal business hours when store is open;(
cgff is offline
post #4 of 25 (permalink) Old 10-09-2013, 03:57 PM
I wouldn't stress over it. The truck gives ample warning when it's running low and you can pick it up about anywhere. I don't recommend stockpiling as storing for long periods of time is when the stuff goes bad. Especially in warm conditions.
Amp Powersteps
Insight CTS
Bilstein 5100s
Rancho stabilizer
post #5 of 25 (permalink) Old 10-09-2013, 04:09 PM
Timmy390's Avatar
Sounds like your dealer did the same thing to you as they did me.....didn't fill the tank but said they did. I got luck and there was 2 gal under the back seat.
I average 6K there bouts per 2.5 gal box (I buy blue DEF from Wal Mart). I drive mostly highway and do tow some but it's just a 18 foot bass boat so it don't work the truck at all.
Don't know about the 13's but my 11 gives a you a DIC message of 999 miles left on DEF. I always add a 2.5 gal jug at that time.
Tim
2011 GMC 2500 CCSB 4x4 SLT
Timmy390 is offline
post #6 of 25 (permalink) Old 10-09-2013, 04:39 PM Thread Starter
I was just shy of 2000 miles and checked dic and was at 22% we are experiencing some pretty nasty weather here but when the rain lightened up i added 2 gallons I have 2 gallons on hand and will top off on friday afternoon
then replace with case I should be good to go for a while, weather is getting cooler now here in NC so a case in the garage should be ok I will only keep a case on hand 4 gallons, at a time after def tank fill
I work part time and the 2 days I work I have a total 400 mile commute just do not want to have an issue on the road
Just unsure what to expect with a full def tank and mileage
Thanks for all the help
carl
cgff is offline
post #7 of 25 (permalink) Old 10-09-2013, 04:52 PM
2006blackmax's Avatar
What kind of mileage are you getting?
2006 2500HD Duramax LBZ with Allison 6 Speed Allison
PullRite SuperGlide 5th Wheel
Merchant Auto Pump Rub Fix
HD Stainless TieRod Sleeves
3600 PSI Tranny Lines
DeepPan / FilterLock
MBRP DownPipe
Cat w /Adapter
AirDog 165
Transgo Jr.
MBRP 4''
2006blackmax is offline
post #8 of 25 (permalink) Old 10-09-2013, 07:47 PM
Def usage should be about 1.5% of fuel usage (according to GM).
redwngr is offline
post #9 of 25 (permalink) Old 10-10-2013, 03:33 AM
2014rubyred3500's Avatar
DEF is available at any Walmart and most auto parts stores. I wouldn't stock any. You have plenty of time to get some when first warning comes up. Wouldn't carry any in truck, especially in summer, unless you are traveling a long distance.
2014 Chevy 3500 Crew Cab Long Bed 4x4
Ruby Red, LT, Line-X, Edge CTS, Cobra 29NW LTD, 4ft. Firestik
2014 Coachmen Chaparral Signature 327 RLKS
2014rubyred3500 is offline
post #10 of 25 (permalink) Old 10-10-2013, 05:50 AM
Timmy390's Avatar
DITTO.....
Most Truck Stops sell it too at the pumps. Every Wal Mart has it and there everywhere. 2.5 gal jug $11.97 at WM.
Tim
Timmy390 is offline
