Diesel Exhaust Fluid issue hopefully resolved - Chevy and GMC Duramax Diesel Forum
post #1 of 162 (permalink) Old 01-17-2011, 04:54 PM Thread Starter
My DEF system never did read how much DEF I actually had in the tank. Hopefully got it fixed today and I did learn a few new things that GM sent out to the mechanics very recently. This could be stuff you already know, but I doesn't hurt to try to give some facts.
The new GM suggestion for when to add DEF is when the 1st warning light is activated and your DIC reads Exhaust Fluid Range: 1000. They suggest to add 3.5 gallons at that time. You must drive the truck for a while to get the system to read the level again. If the DIC doesn't clear then after you shut the truck off for 5 minutes it SHOULD clear the system.
If your truck does what mine did and what quite a few others have done, the system won't read the change and your range will continue to fall. You must get it fixed or you will lose speed and power when you get under 75 miles left. The mechanic must drain the tank and put in a new calibration system. The new system came out 1/13/2011 is what the papers showed.
Hopefully your new truck won't run into the DEF issues. I can't really answer any questions because I'm no mechanic. I'm just trying to spread word on what I was told and what information I saw.
2011 Chevy 2500HD LT Extended Cab 4x4 Z71 Stock...till the warranty is done.
http://www.powerlabsdiesel.com/
13redwings19 is offline
post #2 of 162 (permalink) Old 01-17-2011, 05:12 PM
rascal810's Avatar
Interesting.....................................Di d they give you a invoice with any number on it?
2015 GMC 3500HD CCLB DRW
2008 LMM EFI Live by Nick, Transgo jr., Diamond Eye Quiet Exhaust with Quiet Tone Front Pipe, Big Blue Converter, Blocked EGR, Fass 150 lift, ITBC bypass, Heated Windshield Fluid CCLB Dually LTZ, Sulastics, Bilstein rear shocks, Sold
162,000 miles
2004 LLY RCLB 4x4 80,000 miles bone stock oil every 3k SOLD
2011 Chevy RCLB 4x4 LML 3500HD SOLD
2013 GMC CCSB 4x4 LML 3500HD
http://www.duramaxforum.com/forum/new-here-please-read/
rascal810 is offline
post #3 of 162 (permalink) Old 01-17-2011, 05:18 PM Thread Starter
Invoice states this:
Inspected vehicle and checked diesel exhaust fluid system. DTC Code P20EE-00 Catalyst efficiency below threshold. Level 4. PIP4864 To perform new calibration to system. Completed as needed. Drained and refilled fluid as needed. Checked Ok
post #4 of 162 (permalink) Old 08-10-2012, 10:49 PM
have you had any problems since... I have an identical truck but i def in before the warning and now im having more major problems with mine....
2011 Extended cab 6 1/2' bed 8' Fisher MM2 plow
Dubois811 is offline
post #5 of 162 (permalink) Old 08-11-2012, 10:55 AM
During 2011 there were multiple releases of the programming associated with PIP4864, and then a recall (for 2011 trucks) in the fall of 2011.
If you have a version from 13 Jan 2011, you are probably not yet done with this issue.
redwngr is offline
post #6 of 162 (permalink) Old 08-11-2012, 12:07 PM
GMC..Professional Grade
KensAuto's Avatar
redwngr, is yours still 'intact'? if so have the updates taken care of the issues (if u had any to start with) ?
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #7 of 162 (permalink) Old 08-11-2012, 03:40 PM
Yes its' intact.
PIP4864 rev D was done because it had the classic issue of not resetting after a def refill. 4 or 5 weeks later (and 500 miles from home) it decided it needed fluid again, but would only take less than a quart, and would not reset. Found a dealer, and because of knowledge from this site, was able to work with service writer to keep researching in his computer and find PIP4864. (He wanted to follow a procedure that was for a different problem ). Anyway, he agreed PIP4864 was the correct thing to do, and the truck has been trouble free since.
I've had zero troubles since PIP4864 rev F was applied in late spring 2011. I had the 'recall' programming done late in the fall.
The truck has just over 30,000 miles.
redwngr is offline
post #8 of 162 (permalink) Old 08-11-2012, 04:42 PM
KensAuto's Avatar
30,000 sounds like a good enough test drive
Member #19
KensAuto is offline
post #9 of 162 (permalink) Old 08-11-2012, 08:45 PM Thread Starter
I am now at 21000 miles and I have not had an issue since my original post
post #10 of 162 (permalink) Old 08-12-2012, 10:45 AM
tazz3069's Avatar
I think that I need to take mine in to get checked. Mine did give me the low fluid warning. Then soon there after I get the "Engine Power Reduced" warning. Now the truck runs a little funny. Doesn't seem to have the power it use to have..
2011 2500 Duramax 4x4
Air Lift Suspension Bags, 150db air horns with 2.5 gal tank and compressor, HID Hi/Low Beam and Fog lights. LED interior lights. Switch Back LED turn signal lights. Line X spray in bed liner.
tazz3069 is offline
