Drained Fuel Rails - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 36 (permalink) Old 10-10-2016, 10:46 AM Thread Starter
lbz.erik's Avatar
Drained Fuel Rails
So the other day on Saturday I was doing some back road racing and looking back at it I feel bad for doggin the ol dmax but it was a good time and still feels like new. Anyways on the 5th race my fuel rails drained I was going 80 and then lost power "change fuel filter" messaged popped up and check engine light did to I thought I limped the tranny so I threw it in neutral immediately but it was ok I got the gas station read the code and it read P0087 I cleared it and reset the fuel filter and pumped a full tank of diesel and been babying it since and they haven't came on yet feels like if nothing ever even happened feels good as new still any ideas on what cause that? I was on the street 150hp tune I also have a sump and lift pump. Truck only has 3,3xx miles.
- Deleted 2016 GMC LML - PPEI -
lbz.erik is offline
post #2 of 36 (permalink) Old 10-10-2016, 10:56 AM
Is the pump running?
Hope the cp4 isn't about to take a dump on you.
LML6600DMAX is online now
post #3 of 36 (permalink) Old 10-10-2016, 10:57 AM Thread Starter
lbz.erik's Avatar
Originally Posted by LML6600DMAX View Post
Get a lift pump
I do and a sump
lbz.erik is offline
post #4 of 36 (permalink) Old 10-10-2016, 10:58 AM
I corrected the first post didn't read far enough.
post #5 of 36 (permalink) Old 10-10-2016, 11:07 AM Thread Starter
lbz.erik's Avatar
I assume it is it turns on and is pulling fuel from sump but I'm not sure if it's at it's full potential is there any way to check and I hope not is there any way to diagnose if it's about to go out? If so, so I can stop driving it and order a cp3 before it ruins and breaks more things.
lbz.erik is offline
post #6 of 36 (permalink) Old 10-10-2016, 11:22 AM
Kennedy makes a gauge that hooks up to the test port beside the alternator.
Turn the key and crawl under hear if it's running. Could be simple as a blown fuse or bad wire/connection.
If it's running fine I doubt it's the cp4 typically they just go with no warning.
post #7 of 36 (permalink) Old 10-10-2016, 11:51 AM Thread Starter
lbz.erik's Avatar
Alright I look Into that Could it also be that when I raced i only had a quarter tank of diesel
lbz.erik is offline
post #8 of 36 (permalink) Old 10-10-2016, 12:12 PM
Shouldn't matter because you have a sump so it's always pulling from the bottom of the tank.
post #9 of 36 (permalink) Old 10-10-2016, 12:14 PM
John6363's Avatar
Drained Fuel Rails
X2 on making sure the pump and sump is actually running first.
The sump is what lets you fun below a
1/4 tank without fueling problems.
Depending on what lift pump you have you should be able to adjust the pressure on it with the adjustment screw. It may not have been set right.
I'd look into doing a cp3 swap in the future as well. Cp4s suck.
Jaime S.
06 RCLB 4x4
EFI live
Built trans
30% sticks
68mm stg2r
Supporting mods
Top end rebuild at 90k
Hot blonde driven and maintained
Wondering when the bottom end will blow
John6363 is offline
post #10 of 36 (permalink) Old 10-10-2016, 12:15 PM
we are having a similar problem i think mine has progressed a little further than yours as of right now tho haha i just posted a new thread "help lml issue" read what my trucks doing and chime in haha
chaseallen-lml is offline
