LML Pop then gush of wind loss of power - Chevy and GMC Duramax Diesel Forum
 2Likes
post #1 of 42 (permalink) Old 05-17-2017, 05:59 PM Thread Starter
Driving to work turbo spooling up then I hear a single POP then a gush of wind (like you would disconnect an airhose from a compressor) Driving I do have loss of power, and now it is giving me P0299. I Checked the hoses from what I can see (engine is real hot right now) and the charge hose (replaced month ago) looks ok. Anyone have any recommendations as to where to look? Goosing it on the eway doing 65+ turbo will only show 2.6 PSI I don't hear the turbo spooling up. Even on the driveway if you goose it I never hear the turbo spool up when it rev's over 2500 RPM. I'm waiting for the engine to cool a bit anyone have pointers or ideas of what to look at?
mario430 is offline
post #2 of 42 (permalink) Old 05-17-2017, 06:02 PM
Sounds like you popped an intercooler boot. P0299 is underboost code which if you have a boost leak will pop.
redneck47441 is offline
post #3 of 42 (permalink) Old 05-17-2017, 06:08 PM
LHN...We ARE the Joneses
If the top is visually intact, then the bottom end at the CAC blew off/apart.
You'll need to pull the inner fender liner for easy access to it. It would make sense too if it was recently replaced and the clamps didn't get sufficiently tight.
Hook'em_Horns! is offline
post #4 of 42 (permalink) Old 05-17-2017, 06:19 PM Thread Starter
Is it possible to over tighten the clamps?
mario430 is offline
post #5 of 42 (permalink) Old 05-17-2017, 06:31 PM
If they snap, yes.
Sometimes, you don't get the pipe positioned right, add a little bit loose clamp and Pop!
Scares ya don't it?
post #6 of 42 (permalink) Old 05-17-2017, 07:13 PM Thread Starter
Ok the Charge Pipe Drivers side is tight no issues there. Took it off and re-tightened it but turbo still does not spool. :-( still trying to look any other ideas?
mario430 is offline
post #7 of 42 (permalink) Old 05-17-2017, 07:51 PM
Odd. Usually that's the source.
Boost leak test.
You can build your own with a few items from the plumbing aisle (bushing, tees, gauge, ect.) and compressed air.
post #8 of 42 (permalink) Old 05-17-2017, 08:19 PM Thread Starter
OK so with the Truck in 4wd TC off and everything like that. In reverse if you goose it With parking brake and foot to floor on brakes for a second you hear a woosh sound when under load and it sounds likes it coming from under or near the resonator area (black piece that has the Duramax 6.6L on it)
Ideas?
mario430 is offline
post #9 of 42 (permalink) Old 05-18-2017, 06:24 AM Thread Starter
How bad is it to drive the truck in its current state where it is not building boost and I'm just running off just engine power? Asking as I need to get to and from work.
mario430 is offline
post #10 of 42 (permalink) Old 05-18-2017, 06:32 AM
oscyjack's Avatar
Go easy on it. Temps will Be high
oscyjack is offline
