Airdog 2 or Fass - Page 4 - Chevy and GMC Duramax Diesel Forum
post #31 of 50 (permalink) Old 11-20-2012, 09:13 PM Thread Starter
Originally Posted by Armalite View Post
Not 100% definite here, but I believe you can source out the fass, but not the airdog. Have to run airdog only filters...
Again, I think this is what I was told. I know for a fact I can source out the Fass, i'll put it that way. The ad, im not sure, but I don't think you can.
My brother uses a air dog on his dodge diesel. He buys Fleetguard filters that are cheaper I think the FF is 12 bucks. But you cant find airdog filters in Edmonton It took me 3 days of calling and finally foundto the fleetgaurds for him I can get the numbers if you need them
2011 Gmc Denali 2500 full load 20" ultra mako wheels with 285/60/20 nitto terra grapplers H&S xrt pro 5" ss mbrp with muffler diamond eye DP Fass titanium 150
denali2500 is offline
post #32 of 50 (permalink) Old 11-21-2012, 09:03 AM
Go Green!
Blackcloud556's Avatar
You can run cat filters on the airdog. 1r-0751.
Blackcloud556 is offline
post #33 of 50 (permalink) Old 11-21-2012, 09:10 AM
ATS Diesel Performance
lb7blksmk's Avatar
Send a message via Yahoo to lb7blksmk
You can. The pump also requires modification in order to run the filters since they are larger.
David Spidle
03 LB7Auroura 5000 W/ Manifolds & Up-pipes, Synapse 50mm Gate, 40% Over Injectors, Alligator Stg5 Trans, EFI Live
lb7blksmk is offline
post #34 of 50 (permalink) Old 11-21-2012, 09:18 AM
Not sure if the FASS does but I went with the AD due to it still being able to flow fuel through it in the case the pump does fail. I just ordered a case of the fleetguard replacements for the AD, I'll see if I can round up the numbers from somewhere.
Auston KCCO
2014 EX-L V6 Accord Coupe White
2013 Ducati Hypermotard SP Ducati Corse livery
2009 GMC D/A CC/SB 4x4 SLT 41,xxx mi. Sold
DuramaxxedLMM is offline
post #35 of 50 (permalink) Old 11-23-2012, 03:15 PM
This pump will be coming out very soon for the D-Max, mounting brackets just being finished. Alligator and Meyer will both have them available I believe.
http://www.alligatorperformance.com/...s-p-13210.html
S. KONDOLAY is offline
post #36 of 50 (permalink) Old 11-27-2012, 10:58 AM
FASSAshley's Avatar
Yes, the FASS Titanium and HD series pumps have a flow by in them if the pump were to ever stop working.
FASS Technical Support
866-769-3747
techsupport@fassride.com
FASSAshley is offline
post #37 of 50 (permalink) Old 11-29-2012, 09:17 PM
I put a bd diesel pump on mine and have no issues at all and its cheaper and flows 160
procharged is offline
post #38 of 50 (permalink) Old 11-30-2012, 10:18 AM
I've been reading these post and am curious as to what the advantages are to installing any of these pumps. Does the installation of any of these systems impact warranty and will these system extend fuel pump\injector life?
Thanks
Shocky111 is offline
post #39 of 50 (permalink) Old 11-30-2012, 04:53 PM
sandcar361's Avatar
I was going to install the Airdog at the same time as I put in the Titan fuel tank but I am pretty sure that the mount location for the Airdog is now going to be occupied by the larger Titan tank. Anybody running a Titan with an Airdog?
2013 Silverado 2500HD CCSB, Cognito 4-6 NTB lift, Fox 2.0 shocks w/resivors, Sulastic, 305/55R20 Trail Grapplers, Bush Wacker fender flares paint to match, mini max, diamond eye dp, full delete, FloPro 4" dp back with muffler, Titan XL fuel tank, AD lift pump
sandcar361 is offline
post #40 of 50 (permalink) Old 11-30-2012, 05:24 PM
snomoblr88's Avatar
Air Dog has my vote! The only down fall is the new plastic mounts!
Levi
2006 CC/SB LBZ
4" Black Magnaflow duals
EFI By Rob Coddens
Air Dog II 200
EGR Blocked, PCV Rerouted
Built Trans and other supporting mods
www.dieselprosbozeman.com 406-551-2777
snomoblr88 is offline
