Lml to lmm build - Chevy and GMC Duramax Diesel Forum
 2Likes
post #1 of 503 (permalink) Old 12-05-2012, 12:48 PM Thread Starter
DmaxMonster's Avatar
Lml to lmm build
We you all win.they may and most likely will never do programming for the lml...I am looking in to swapping over my lml to a lmm..I know the injectors are different, mike said he can make my Trany work. I am looking at what all other than the wiring harness and the computer, injectors heads, and fuel system would I have to change. Would the cp3 fit my block? And would the lml turbo work with the lmm computer? Any and all help will be great
2011 LML ecm converted to lmm 4x4 CCD Socal stroker kit, bored .040 for the 437ci, triple 366 turbos, triple 44mm trial liquid cooled wast gates, Leash boost controller, full NOS system, PPE mans, up pipes, CP3, 150over injectors, 5" exhaust, 250Fass lift pump, EFI live, Focal K2s all around two JL 13" PS2 flip down in back, dual CP3 custom built tran thanks to the help and savings from Tim Heckler Ballies, Sam at Southern Style Diesel, Mark at Danville, Tony at All season, Guy at Socal, Mike L, and all the people on the df
DmaxMonster is offline
post #2 of 503 (permalink) Old 12-05-2012, 12:52 PM
SickLL7Crenshaw's Avatar
i wish i had ur money..
05' LLY CC/SB 12.41 @109.9 119k
Blake
SDP Twinz, 40% overs, EFILive by me, Stage V trans, BT lock up box
4'' Exhaust, Airdog, Traction Bars, Built Front End,
Big Thanks to Henry and Scott
01' LB7 EC/SB 13.5@97 230k
EFILive by me, Grade C HG, ARP studs,
4 in duals, S@B intake, Airdog, PPE boost valve, BT lock up box on stock trans
SickLL7Crenshaw is offline
post #3 of 503 (permalink) Old 12-05-2012, 12:56 PM
6dot6's Avatar
yea you are far better off doing it as an lmm. good luck bud.
2014 ram 3500 dually staying stock
6dot6 is offline
post #4 of 503 (permalink) Old 12-05-2012, 01:10 PM
BorderlineReckless's Avatar
i guess i don't get it lol
-Trent-
2008 LMM 2500HD, MA-700, MBRP 4'', K&N cold air intake, EFI Live from Diesel Addiction, edge insight, PPE lift pump, egr blocked, 33'' Goodyear duratracs on 20" XD Misfits, de-debadged,smoked tail lights and cab lights, halo headlights, black grille, leveled with keys, B&M gooseneck hitch, air ride air bags with compressor, Alligator tie rod sleeves, PPE shim kit,Rough Country 6'' Lift Powdercoated Orange, 35w 5000k HIDs highs, lows and fogs
WAITING TO BE INSTALLED - PCV reroute, Ppe rear diff cover, inline filter kit
>>>build thread<<<
BorderlineReckless is offline
post #5 of 503 (permalink) Old 12-05-2012, 01:22 PM
b14
he wants mo powa in a nbs!! lol i often wondered what a roller chassis would cost from gm, then put a pre-emissions block in it and consider it "glider" i know you can get away from ALL emissions on semi's if you have two major pieces with mfr date codes PRE emissions standards, this includes ALL of your major drive line,
my way around emissions testing; i think yes
2010 2500 ccsb
dpf delete - egr blocked - cheap pcv re-route
efi live tuned dsp5 - by rob!
4" Diamond eye duals
afe intake with pro dry 2
ride rights
edge insight cts w/ egt probe and two backup cameras
Dirty Loud and Proud
b14 is offline
post #6 of 503 (permalink) Old 12-05-2012, 01:35 PM
6dot6's Avatar
who knows. we may all need to do this eventually if we buy newer trucks down the road. my next project will be a cts-v though, or a z06.
6dot6 is offline
post #7 of 503 (permalink) Old 12-05-2012, 01:56 PM Thread Starter
The word it dodge is doing it on the 2013. EPA
post #8 of 503 (permalink) Old 12-05-2012, 02:59 PM Thread Starter
I am still doing my stroker build just mines the heads with that money I found a 07 lmm motor and all the wiring I think I will need for $3,900.00 the motors got 125,000miles on it mines the basic bolt ons...but it has all fuel system
Can it be done?
post #9 of 503 (permalink) Old 12-05-2012, 03:22 PM
bigblackdmaxx's Avatar
Could you just use the fuel system and ecm out of the lmm? is that what your wanting too do?
Goes by Taylor
2012 Range Rover Autobiography
Sadly Sold :2005 Lly Black 4wd cc/sb
6 inch Rancho lift kit with 35's
4 inch strait pipe, Egr delete, MA High Performance Duramax Motor Mounts :rockin AFE stage 2 cold air intake, Lbz mouthpeace, PPE Exhaust Manifolds & Up Pipes, 4.56 gears
EFI by IdahoRob With a little extra fuel
You may all go to hell and I will go to Texas. –Davy Crockett
bigblackdmaxx is offline
post #10 of 503 (permalink) Old 12-05-2012, 03:25 PM
I have no doubts that it is possible, but I personally don't see the benefit in it. What is your horsepower goal? There are numerous companies working on a CP3 pump addition kit, and so far I am seeing good things. I am personally driving one and there is PLENTY of fuel for some good HP numbers (I dare say up to 800HP with supporting air and nozzles). Right now I am still on the stock turbo, and it becomes very inefficient around 550hp. Transmission will also need some upgrades if we keep pushing it like we are. The aftermarket is coming for the LML, and I see no reason to jump ship unless you are going for a 1000+ hp truck. We don't know yet how the LML will take very high HP levels, so you may be better off jumping to a proven platform.
H&S Tech is offline
