Lml throttle body porting? Banks intake manifold? - Page 3 - Chevy and GMC Duramax Diesel Forum
post #21 of 60 (permalink) Old 12-10-2012, 06:48 AM Thread Starter
Camaroz2866's Avatar
I will tackle this tomorrow most probably. At the min ill remove the throttle blade. I will prob wait to port it till I so the manifolds, ups, down, full egr delete ect.
2016 Denali HD iridium metallic- led fog lights, pisk, led license plate lights, weathertech floor mats, windows tinted, tool box, ad2 4g, cts2,color matched billet front gmc, debadge tailgate,mbrp downpipe,5" exhaust, banks cai, kw tunes,amp steps, trans tune, shortened antena even with the roof, titan fuel tank, paint matched mirrors, pcv rerout, kryptonite tie rods, 37x12.5 nitto m/t, nictane adapter with uhe filter,
shortly: full egr delete, turbo, wc intake setup, order pro fab man/ups,unlock radio/navigation features, lift 6" with 40"s.
sold 2/2016-2012 Denali HD
Camaroz2866 is online now
post #22 of 60 (permalink) Old 12-10-2012, 07:01 AM
Taking the Long Way Home
FC5452's Avatar
Send a message via AIM to FC5452
Originally Posted by LMLFanatic View Post
I do believe that Don and Rick have/had discussed some of the intake plumbing. Perhaps we will see something from Rick in the near future.
The Last time I talked to Rick he was looking at it, I believe not only the Y Bridge but the Intakes themselves as well. As far as the Passenger side IC pipe, You can fab it up to the Butterfly and boot it on. The CAI probe has to be bunged in there as well. I may just get a LMM Y bridge from him and pull mine and see what is what.
S468 with some fuel and a Tuna or two
MY Build
Need or Want Tuning for your Duramax, click Below
FC5452 is offline
post #23 of 60 (permalink) Old 12-10-2012, 07:54 AM
Its just a worktruck
DMAXchris's Avatar
Originally Posted by Camaroz2866 View Post
So this would be called? Throttle opening?
A giant piece of garbage.
It cant be called anything throttle because diesels are throttled by fuel, not air. Its for emissions and the EGR system.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
post #24 of 60 (permalink) Old 12-10-2012, 08:14 AM
FC5452's Avatar
MY Build
FC5452 is offline
post #25 of 60 (permalink) Old 12-10-2012, 08:53 AM
GMC..Professional Grade
KensAuto's Avatar
It's official name is 'intake air valve' altho I would call it a t-body or TAC because of the physical similarities, and it's used to maintain exhaust temps during regens by restricting airflow. The only physical difference between an IAC and a TAC is the plate is open at rest instead of closed. I haven't found any info related to it being part of egr operation
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #26 of 60 (permalink) Old 12-10-2012, 09:37 AM Thread Starter
Ok but back to my point. I wan to know if porting the tb/ intake opening would be beneficial or just removing the blade would be all that's needed
post #27 of 60 (permalink) Old 12-10-2012, 09:56 AM
KensAuto's Avatar
I don't think anyones tried it and i haven't taken measurements to see if there's enough restriction.By looking at pics, the y-bridge and the pipe that hooks to it have huge restrictions and angles. my only problem with modifying the exhaust/intake system on an LML is, the H&S guys built their tunes around a truck with all of the factory stuff in place....on the other hand FC5452 and Flyin6 noticed improvements w/some extra exhaust mods....Just try the plate if you want to do something, doubt porting it with 500 max hp will make any noticeable diff.
Member #19
KensAuto is offline
post #28 of 60 (permalink) Old 12-10-2012, 01:01 PM
cleandirtymax's Avatar
subd for info
cleandirtymax is offline
post #29 of 60 (permalink) Old 12-10-2012, 09:36 PM
i took my intake off today the throttle body or whatever u want to call it is not near as restrictive as the intake heater that is directly behind it i took it out!!! Guys looking for sum whistle thats where its at if you take it out you can for sure hear hear it
Burt 2011 Lml is offline
post #30 of 60 (permalink) Old 12-10-2012, 09:39 PM Thread Starter
Please elaborate or even post pics please as I'm doing the throttle blade removal tomorrow.
