Just installed s&b intake. Check engine light? - Chevy and GMC Duramax Diesel Forum
post #1 of 60 (permalink) Old 01-11-2013, 01:26 PM Thread Starter
Installed the intake and now the check engine light is on. Guessing this is due to the other maf wire. How do I fix this?
2013 2500 lml leveled w/ s&b intake, 5'' turbo back flo pro, h&s minimax, egr delete, drp downpipe.
Oilfieldtrashdmax is offline
post #2 of 60 (permalink) Old 01-11-2013, 01:33 PM
jokerfabworx.com
JOKER's Avatar
JOKER is offline
post #3 of 60 (permalink) Old 01-11-2013, 01:34 PM
Justin mccabe's Avatar
Did you connect both the connectors from the stock set. Some thing happened with my dads we ha just forgot one connector so I would start there and just go over everything again.
2006 lbz dually, efi live by Idaho rob, ad2 165, pcv reroute, tie rod sleeves, cts insight, sdp egr delete, down pipe. Built trans and twins coming soon. Www.atptrucks.com
Justin mccabe is offline
post #4 of 60 (permalink) Old 01-11-2013, 01:41 PM
Most Known Unknown
jwcgmc1985's Avatar
jwcgmc1985 is offline
post #5 of 60 (permalink) Old 01-11-2013, 01:46 PM
jokerfabworx.com
JOKER's Avatar
Originally Posted by jwcgmc1985 View Post
subd
thinking to install mine tonight,
unless theres a noob on here that we can MEME attack, then in that case id rather do that!
I'll be around if you have any troubles.
I am still trying to figure out what this "other" MAF wire...
JOKER is offline
post #6 of 60 (permalink) Old 01-11-2013, 02:04 PM
Chevytuff19's Avatar
I am not mechanically inclined at all and mine installed pretty easily without throwing any codes. Do you happen to have the oiled filter by chance?
2011 GMC 2500HD Duramax Z-71 CCSB SLE
S&B Dry Cold Air Intake
Ranch Hand Front and Rear Replacement Bumpers (Ridgid Dually Lights on Rear (2)), NFAB 6-Step Nerf Bars, RKI Tool Box, Custom Headache Rack w/ Ridgid Dually Lights (4)
Limo Tint All Around w/ Limo Brow
EDGE CTS Insight, Rancho Steering Stabilizer, Backup Camera
3/4" Lift via Torsion Bars (it was all I could get with stock keys), 285/65/18 Nitto Trail Grapplers
GoLight Stryker HID
XRT Pro on Tow with 4" Flo Pro Exhaust
Chevytuff19 is offline
post #7 of 60 (permalink) Old 01-11-2013, 06:59 PM Thread Starter
There's two sensors in the stock intake and only one in the s&b there's 3 plugs in the harness. Where does the second one go out of te stock box
post #8 of 60 (permalink) Old 01-11-2013, 07:41 PM
jokerfabworx.com
JOKER's Avatar
Use Paint and draw on this picture of mine. What are you referring to?
My aFe Stage Deux
JOKER is offline
post #9 of 60 (permalink) Old 01-11-2013, 07:46 PM
Most Known Unknown
jwcgmc1985's Avatar
Just did mine including the scoop
Hear turbo a little more and zero codes thrown
Took me 1.5 hours. And the longest part was trying to remount the passenger HID ballast since I originally had it mounted under the air box tray with zip ties!
And I didn't install that stupid factory filter minder in, couldn't seem to get the stupid thing to go into the S&B per drilled hole!
Otherwise
Easy install!
post #10 of 60 (permalink) Old 01-11-2013, 07:46 PM Thread Starter
Ok there's one plug that goes into the inter cooler hose. Then there's the ont that goes in the tube. Where does the other one go? Idk how to paint
