Topper center high mounted brake light - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 05-17-2011, 02:49 PM Thread Starter
Does anyone know which wire to tap into for the brake light on the center of the topper? I tapped the yellow wire, but it flashes with the left turn as well as the brake light. I really don't want to run a wire from the back of the cab light.
2011 GMC Denali 2500HD, black on black traded!!!
2012 GMC DENALI 3500HD, black/black, nav radio, sunroof, backup camera, short box srw,traded!!!
2013 GMC Denali 3500HD, black, srw, nav, sunroof, power sliding rear widow, high idle, rear camera, b&w
S&W 460 XVR is offline
post #2 of 6 (permalink) Old 05-17-2011, 03:21 PM
LHN...We ARE the Joneses
Not sure if it changed on the LML, but at the rear trailer harness/spare area you'll find a small blue unused wire wrapped up...that's for the aux cap brakelight.
Hook'em_Horns! is online now
post #3 of 6 (permalink) Old 05-17-2011, 07:40 PM Thread Starter
I tried to find it. Not having any luck so far. Everything is taped up and covered in plastic hose type covering. Can any LML owners confirm the blue wire is still there. Please post a picture if possible.
post #4 of 6 (permalink) Old 05-17-2011, 08:49 PM
Start at the trailer plug harness and work back.
post #5 of 6 (permalink) Old 05-20-2011, 08:25 PM Thread Starter
Called my dealer, after waiting 15 minutes on hold, while he searches where ever they look things like this up. He can't find a wire to hook to. Anyone got any suggestions.
post #6 of 6 (permalink) Old 08-09-2013, 08:06 AM
The 07 to 13 Silverado and Sierra are sort of tricky to wire up. GM does not run a separate wire to the back of the truck for a topper. There are two ways to wire it. First you can run a wire under the truck up into the engine compartment through the fire wall and tap into the wire at the brake pedal. Usually the wire is blue. Otherwise you can use a logic box, which separates out the brake and turn signal. The logic box comes with three wires sticking out of it, yellow, green, and blue. The yellow wire goes to one turn signal and the green wire goes to the other turn signal. The blue wire goes up to the third brake light on the topper.
Top a Truck.com is offline
