Old 10-07-2008, 08:56 PM   eBay Motors   #11 (permalink)
iceman
Door chime partial fix
Well for those interested, I removed front of the dash and pulled out the stereo and started probing wires with test light, when I got to the plug with the most wires in it and probed the small orange wire, lower right hand corner if facing plug ( stereo side ) door chime tuned off. But found if left test light in wire long enough it would start to effect gauges. This tells me must go to computer or ? Removed wire from stereo and found radio wouldnt work. Tried grounding radio terminal to see if would come on with no luck. Checked orange wire with meter and found very minimul voltage if any. Put all back to the way it was didn't know what else to do.
So started pulling apart stering colum thinking must be a switch to tell truck when key is in. Found small white switch on top of key cylinder that was activated with key in. Took and released keeper on left side of switch and rotated it clock ways and pulled straight up to remove. Found this disabled door chime when key is in and door open so can listen to radio with engine off without being bothered. So far no side effects from this that have been found. Left switch laying on top of colum and put all covers back on. So happy I got ride of at least part of the door chime problem. Now if I can get ride of the rest i would really be happy. Sorry this was so long. Hope this helps somebody.
iceman is offline   Reply With Quote
Old 10-08-2008, 06:25 AM   eBay Motors   #12 (permalink)
bhiland23
bhiland23's Avatar
I got mine to lower but it is still too loud.
2003 GMC Sierra SLT CC/SB. Loaded interior, autometer gauges, ATS E-POWER, Ported fuel fitings, PPE Boost valve, Rapid Flow intake, Plugged resenator, Straight piped with 6 inch tip, High idle, 285/75/R16 Pro comp All Terrains, Tinted windows, Step tubes, Bed rail caps with bed tubes, adding more all the time. Decked out with LEDs for the fire department. Saving for trans and a few more goodies.
bhiland23 is offline   Reply With Quote
Old 10-09-2008, 07:12 AM   eBay Motors   #13 (permalink)
Killerbee
Killerbee's Avatar
could you post a pic? You have hit on something useful.
The only downside I can think of, is now you won't get warned that you are getting ready to lock the keys in the car.
Michael, 2500HD LLY, Systems Engineer, EMAIL
PRODUCT PAGE CUSTOM TUNING
Quick Links:ECM's , INDUCTION OVERHAUL, EFILive,
NEW Lockable DSP Switches coming Nov 1
Old 10-09-2008, 07:36 AM   eBay Motors   #14 (permalink)
rap2orrider660R
Serving the Oil Industry
rap2orrider660R's Avatar
And on the 2007.5 & 2008's (no sure about other models) there is also a ALERT sounded when you have for say low tire pressure, or low fuel, or when any vital message comes up on the message screen...BUT I usually have the radio crankin too loud to hear it anyways..
Aaron Blackwell
Cen-Tex Marine
Proudly Serving the Marine and Oil Industry
2007.5 D-MAX, EDGE DIGITAL GAUGES, QUADZILLA WITH DPF DELETE, TUNED AT 90HP NO MORE NO LESS, STRAIGHT PIPED, 17" CHROME SHAKER RIMS WITH 285 70 17 BFG KM2 MUD TERRAIN TIRES, AIR BOX MODIFIED,BUSHWACKER BED CAPS, RECON SMOKED LOW PROFILE CAB LIGHTS AND MORE TO COME (I HOPE)
rap2orrider660R is offline   Reply With Quote
Old 10-17-2008, 12:35 PM   eBay Motors   #15 (permalink)
iceman
Door chime
Will try to post some pics soon of switch. have to take back apart to do so. That will teach me to take pics as I go. Thanks
Old 11-14-2008, 12:10 PM   eBay Motors   #16 (permalink)
iceman
Door chime Delete
started pulling apart stering colum thinking must be a switch to tell truck when key is in. Found small white switch on top of key cylinder that was activated with key in. Took and released keeper on left side of switch and rotated it clock ways and pulled straight up to remove. Found this disabled door chime when key is in and door open. Put everything back together and left switch sitting on top of colum as seen in pic under plastic cover.
Here are some pics hope this helps.
http://www.duramaxforum.com/forum/vb...do=full&p=1455
http://www.duramaxforum.com/forum/vb...do=full&p=1456
http://www.duramaxforum.com/forum/vb...do=full&p=1457
http://www.duramaxforum.com/forum/vb...do=full&p=1458
Old 11-14-2008, 12:17 PM   eBay Motors   #17 (permalink)
Beaner242
Beaner242's Avatar
DO you have to pull the dash off to get the colum cover off?
08 GMC Sierra
Summit White
Crew Cab
30% Tint
Edge Race
MBRP 4"
Go Rhino Steps
Beaner242 is offline   Reply With Quote
Old 11-14-2008, 12:17 PM   eBay Motors   #18 (permalink)
bnkrupt
ASE Certified PartsWhore
bnkrupt's Avatar
BRAVO Iceman! you just went up a few notches in my book, whatever that saying means exactly.
excellent pics, sweet idea, and i also appreciate that you took some risk to get this done.
A++ for the day..
Jess Hardessen | Husker Diesel | 402-570-1200
Blocker Plates | WIF Wrench | Fuel Filters
www.huskerdiesel.com | Email us!
Visa, MasterCard, Discover, American Express, PayPal
* GIVE US A CALL FOR THE BEST DEALS! *
bnkrupt is offline   Reply With Quote
Old 11-15-2008, 12:49 AM   eBay Motors   #19 (permalink)
iceman
Yes you do, not a big deal at all, just start around the edges and start gently pulling away from the dash and try to bring it out somewhat evenly as you go. It just snaps off and just pops back on when done. Found it helps to tilt steering wheel down and pull gear shifter all the way down to first.
The colum is a little harder to get apart. You need to get the top piece off, the bottom will stay pretty much where it is
Old 11-15-2008, 06:53 AM   eBay Motors   #20 (permalink)
Killerbee
Killerbee's Avatar
Nice job, nice pics. IIRC, the entire front bezel just pulls off, correct?
Also, did you look at disconnecting at the doors instead?
