How to remove fan guard - Chevy and GMC Duramax Diesel Forum
Old 06-12-2012, 08:31 PM   eBay Motors  #1 (permalink)
Thinking of removing the fan guard for the next time I change my belt. Any pointers on how to remove it? Is it two pieces or one?
Lmholmes11 is offline   Reply With Quote Quick reply to this message
Old 06-13-2012, 06:15 AM   eBay Motors  #2 (permalink)
2xCP3 in the works
DMAXchris's Avatar
Its one piece and your truck will run hotter with it removed.
There are 3 13mm bolts holding it. 1 is on top of the core support, the other 2 are down on each side of the block.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline   Reply With Quote Quick reply to this message
Old 06-13-2012, 07:36 AM   eBay Motors  #3 (permalink)
I have heard of a lot of guys removing it. It will run hotter as in too hot and could harm the engine? Or just a few degrees hotter . I might not remove it now
Old 06-13-2012, 08:21 AM   eBay Motors  #4 (permalink)
gr8shot's Avatar
What year is your truck? The fan shroud on my lb7 is two piece. 4 10mm bolts across the top and the little plastic push plugs on the sides. Remove all them and move the big black plastic ecm box outa the way and the top half comes right out easy as pie. Had mine off this weekend to hose out my cooling stack.
Sent from my old skool Droid
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline   Reply With Quote Quick reply to this message
Old 06-13-2012, 08:29 AM   eBay Motors  #5 (permalink)
No I'm talking about the fan guard, not the shroud. 07 lbz. The lb7 doesn't have one
Insurance
