| 2001 - 2007.5 (GMT800) Non Powertrain Discussion of 01 to 07.5 Topics Not related to the Powertrain, interior, suspensions, body,wheels, tires, ect. |
| Senior Member Join Date: Jul 2011 Location: Edwardsville IL
| ABS System? Hey guys. Sometimes, driving down the road my ABS and Park Light will come on. Trying to diagnose, looked for bare wires etc. No codes being thrown just the lights while moving down the road. Sometimes while warming up in the morning. My question is, what components does the ABS system consist of and how to they work together? I know there are two speed sensors connected to the front wheels, but thats about it. Thanks guys. |
| Duramax Lifetime Supporter Join Date: Feb 2010 Location: Southern Maine
| Check the fluid and make sure it's full Sent from my iPhone using my iPhone
__________________ 2003 CCSB 4x4 EFI Tuned by ATP -PPE Stage 4 -Silverline 4" Exhaust -MBRP Downpipe -PPE Boost Valve -CAI -Ported Intake Horn -Ready Lift Leveling Kit -Autometer Boost & Pyro -Airdog II 165 |
| yes fluid is full |
| Senior Member Join Date: Oct 2012 Location: Everywhere
| Check your power steering fluid as well.
__________________ Purchased 11/15/12: 2004 LB7 CCSB, ATS 4000 turbo, upgraded injectors, Diamond Eye 4 inch turbo back exhaust, H2's on 315/70/17's, Ranch hand front bumper. EFI LIVE by Kory Willis Purchased parts awaiting install: Moog problem solver lower ball joints, Moog pitman and idler arm, AD 165 ![]() Special thanks to: Brent@LDS, mrmanners@Synthetic Motorsports, and Kory Willis@PPEI. DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource Jesus loves YOU, Have you asked Him to be your Savior yet? |
| The only problem I've ever had with fluid was and oil leak and a new banjo fitting fixed it. I'm wondering what components make up the ABS system where is the control module etc |
| Master cylinder, brake control module with pump motor ( under drivers seat area along frame rail), front wheel speed sensors (integrated into the front wheel bearing assemblies) and a speed sensor on the output shaft of the transmission. You may also want to check the big maxi fuse in the underhood fuse box. I believe it's either a 40 or 60 amp fuse. If that blew then it would throw both the ABS light and the red brake light on. I've personally only seen both lights come on for 1 of 2 reasons... 1.Blown maxi fuse under hood, which typically but not always means you have a bad module or pump motor Or 2. Low brake fluid Sent from my iPhone using my iPhone
| Thank you. |
| DuramaxForum n00b Join Date: Dec 2010
| Codes should be thrown. Most obd scanners won't read abs or airbag codes. Wife's tahoe would light the abs and brake warnings together. GM tech manual says when an abs fault is detected both lights will come on. Low fluid should only light the brake warning. Hopefully its just a wheel speed sensor.
__________________ 2006 GMC 2500hd ccsb lbz stock 4x4 Nictane with donaldson EFI V2 scan only |
| Quote:
__________________ 2003 CCSB 4x4 EFI Tuned by ATP -PPE Stage 4 -Silverline 4" Exhaust -MBRP Downpipe -PPE Boost Valve -CAI -Ported Intake Horn -Ready Lift Leveling Kit -Autometer Boost & Pyro -Airdog II 165 | |
| Junior Member Join Date: May 2012 Location: Fairfield ,Ca
| I get these codes to and they only started coming on once I adjusted my tire size with my ppe programmer. I think what's happening is that when u calibrate for tire size to make your speedo correct, the signal from the wheel sensors are getting a different reading from the speed sensor in the transmission, which will cause the ABS and brake light to come on. Never had a problem till I corrected my tire size. I was told that with a tech 2 you can reprogram the ABS system after you adjust tire size so the lights don't come on, but have yet to find someone that knows how to do it. Sent from my iPhone using AutoGuide.com Free App
__________________ John, 2006 GMC Sierra 2500HD CCSB Dmax w/6 speed Alli 9-11" CST lift 8 fox shocks w/res rear air bags 22x12 Fuel 2 piece Maverick wheels with toyo mt 37x13.5x22 Mag-Hytec Trans and Diff, Amsoil oil filter bypass kit with 2 Amsoil semi truck oil filters AFE intake, AMP steps, 45 gal tank PPE xcelerator and 4" turbo back with EGR block off plate Hopefully Soon will re-gear and get the Air dog pre filters and lift pump... And prob more to come... |
