Airbag service warning - Chevy and GMC Duramax Diesel Forum
Old 01-23-2013, 09:16 AM   eBay Motors  #1 (permalink)
tcharon's Avatar
My service airbag warning is on, can I do it myself or is this a dealer only problem? Thanks.
05 Silverado 2500HD 4x4 2" lift Crew Long, Killer Bee's Cold Air, Stinger Scoop & Custom tuned ECM, 4" S/S Exhaust, Banks exhaust brake, rear Eaton TrueTrack EGR block EBC sport rotors Yellowstuff pads, Earls large aluminum trany oil cooler & deep al pan, Cognito Pitman & Idler arm braces, large al rear diff cover, 265x75 10 ply General Grabber HTSs on Amer Race Al 16x8" Outlaw & winter 235x85 BFGs w/ studs on skinny stock rims, Firestone air spring bags, Hellwig sway bar, Rancho 9000XL shocks, Torklift Stable Load brackets, AEM filter, Lowrance HDS-7m GPS, HIDs, KC 8” 130w driving lights, CB, Warn 12K winch, Superhitch; Stretched Jeep TJ 5.9L V8 auto, Atlas, D60 Warn hubs D70 R both Detroits, rear line locks, PSC hydro steer, 39” Krawlers.
tcharon is offline   Reply With Quote
Old 01-23-2013, 11:22 AM   eBay Motors  #2 (permalink)
well it depends what the problem is...............................
you need to check what codes are being set. A fairly common problem is the EFS (electronic front sensor) fails and has to be replaced. Its mounted on the radiator core support in the center. It costs less than $100 and can be replaced in your driveway with a 10mm socket in about 5 minutes.
But dont go out and buy one, because I cant say for sure if thats the problem your truck is having, because you havent posted any codes.
Im just saying thats ONE of the problems it COULD be.
ben
05 dmax/allison
duratothemax is offline   Reply With Quote
Old 01-23-2013, 01:26 PM   eBay Motors  #3 (permalink)
tvti's Avatar
I have the same problem. How do I check the codes?
2005 Chevy 2500 HD, 4x4
6" Pro Comp lift, Edge Juice with Attitude, K&N CAI, Banks dual exhaust, Viper 5704
Adrenaline Truck Performance
Diesel Performance Parts & Products | Alligator Performance
MadJack Racing
PowerLabs Diesel
tvti is offline   Reply With Quote
Old 01-23-2013, 02:58 PM   eBay Motors  #4 (permalink)
tcharon's Avatar
ben
Thanks, what's the code for the EFS?
Old 01-23-2013, 03:49 PM   eBay Motors  #5 (permalink)
I dont know the exact code, but if you get the code number (it will be "Bxxxx") and put it into google it should come up. Some code readers even give you the written description. Not all code readers will read airbag codes. You will need a more advanced code reader. I dont know if the code readers they let you borrow at Advance Auto will read airbag codes or not...
ben
05 dmax/allison
Old 01-23-2013, 03:56 PM   eBay Motors  #6 (permalink)
Goose2448's Avatar
INNOVA 3160B ABS/SRS+ Professional CanOBDII Diagnostic Code Scanner with Enhanced Live Data : Amazon.com : Automotive INNOVA 3160B ABS/SRS+ Professional CanOBDII Diagnostic Code Scanner with Enhanced Live Data : Amazon.com : Automotive
That's what I have, works great. And not most auto places do not have one that does ABS or SRS
2008 GMC 3500HD CC LB DRW 4x4~5" MBRP Filter Back Straight Pipe, Westin Step Bars, WeatherTech Floor Liners, Antenna "Delete", Plasti Dipped Grill and Emblems and Rims, Leveled, Funky Gear Rims, Nictane Adapter with Donaldson and Clear Bowl
1985 Chevy C20 RCLB 350 4 Bolt, 4 Barrel Carb, 4.10 Gears, 8600 GVW, Glass Packs Dumped, Pig Skin Leather, Bed Mounted 5th Wheel, Dual 20 gal Tanks, 62,146 Miles, Indian Bronze and Cream~Rolled
DF DRW Club Member 129
Goose2448 is online now   Reply With Quote
Old 01-23-2013, 04:01 PM   eBay Motors  #7 (permalink)
CFD95's Avatar
Could be the clock spring in steering column also
2007 GMC 2500 LBZ CLASSIC CCSB
EGR BLOCKED AND STICKED
MAGNAFLOW DOWN PIPE
MBRP 4'' EXHAUST
BILSTEIN SHOCKS
CFD95 is offline   Reply With Quote
