| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 2001 - 2007.5 (GMT800) Non Powertrain Discussion of 01 to 07.5 Topics Not related to the Powertrain, interior, suspensions, body,wheels, tires, ect. |  |
04-16-2006, 10:33 AM
eBay Motors
#1 (permalink)
| | Junior Member
| 2001 throwing oil I need help. I have a 2001 3500 4x4. It has 58000 miles on it. I have not had any trouble in the past and just had it serviced by dealer 2 weeks ago. I have drove it 1500 miles since servicing with no issues. 3 days ago I left texas headed for south carolina. On day 2 of the trip I noticed the oil pressure dropped to 25# normally it runs 75#. I pulled over at a fuel station and checked the oil, it showed full on the stick and I noticed a film of oil all over the side of the truck and the tail gate. I struck back out on the road and made it about 75 miles and a car pulled up beside me and said I was throwing oil all over the place. I took the next exit and checked the oil and there was nothing on the dip stick and there was oil all over the outside of the truck and everything under the truck was covered with oil. I started putting oil in the truck and it took 2 gallons before it registered on the dip stick. I started the truck and oil was flooding out from somewhere like a water fall. I think I may have put to much oil since the truck was hot which is why it was flooding out but I could not tell where the leak was coming from or what caused it. I called a tow truck and had it hauled to a dealer in Alabama and called a friend to come get me and take me on to south carolina. When the tow truck arrived I started the truck and backed it up, a massive cloud of smoke came from the exhaust and the truck sounded sluggish. My truck is at the dealership in Alabama and I am going to call them monday. Does anybody have any Ideas of what could have happened to my MAX. |
| Advertisement
06-08-2006, 07:13 PM
eBay Motors
#2 (permalink)
| | Member
| GM issued a TSB concerning oil cooler leaks. The o ring seal where the cooler attaches to the block leaks. Could this be the problem? |
06-09-2006, 02:03 AM
eBay Motors
#3 (permalink)
| | Junior Member
| Sounds like a bad injector,filling the base with fuel.
__________________ 2001 GMC 2500 reg cab ZF6speed,Mac's dual disc pulling clutch,AFE intake,MITUSA lift pump,Wester's"Insane Freight Train" ECM,Boost/Pyro gauges,4" straight pipe,SD sleeves,Cognito braces |
06-09-2006, 04:53 AM
eBay Motors
#4 (permalink)
| | Gear Jammer...
| Quote: |
Originally Posted by jon72 Sounds like a bad injector,filling the base with fuel. |
Thats my thoughts also, hows your fuel milage since this started?
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
06-13-2006, 09:14 AM
eBay Motors
#5 (permalink)
| | DF Sponsors
| Any update from the dealer? I dont think the internal injector leak is going to cause a loss of oil. It is usually the opposite. The truck appears to begin to make oil. You are right about how common the leaky injector problem is, that is why GM has extended the warranty quite a bit on these. |
| Advertisement
