Old 01-30-2009, 04:00 PM   eBay Motors   #1 (permalink)
NoSparks
NoSparks's Avatar
?T-Bar cranking?
I am looking to raise my front end about 1 1/2 inches.
Do I need to jack up the truck and release the load on the T-Bars before adjusting the key bolts?
I don't want to damage the bars (over-twisting).
I plan on obtaining shock extenders shortly (Cognito).
Thank you.
Steve
2007 Chevy Silverado Classic 2500HD LT3 Crew-Cab, Short-Bed
-6.6L LBZ, PPE Standard: Tune 1[/color]
-Banks 4" Turbo-Back (Downpipe-Back, Cat Delete, Muffler Delete)
-EGR Block Plate, Resonator Plug[/color]
-Bridgestone Dueler AT 695 LT265/75R/16E, Stock Wheels 16x6.5''
-AMSOIL AME 15w-40, AMSOIL ATF, Line-X, UWS Utility Box, UWS Nerf Bars, PIE Auxiliary Input Adapter (MP3 to factory stereo)
NoSparks is offline   Reply With Quote
Old 01-30-2009, 04:06 PM   eBay Motors   #2 (permalink)
usafracer
Red trucks rule.
usafracer's Avatar
Yes you need to raise the front of the truck. Shock extenders are only going to cure half the problem with just cranking the torsion bars. You still will be limited on travel because of the factory bump stops and your ball joint angles are going to be extreme.
2008 GMC Sierra Crew Cab 4X4
2004 CC/SB 4X4 Duramax (sold)
Old 01-30-2009, 04:21 PM   eBay Motors   #3 (permalink)
NoSparks
NoSparks's Avatar
Thanks for the info.
Steve
Old 01-30-2009, 04:59 PM   eBay Motors   #4 (permalink)
Tamperman
Tamperman's Avatar
also, need to re-align the front end when you do it.
05' GMC 4WD SLT CREW CAB WITH 2 CARSEATS IN THE BACK!
FIRST DIESEL,
LOVE IT,CANT WAIT TO DO SOME MODS.
Air Box Mod... More to come...
Coolant Filter System, Courtesy of Dieselsite...
Hypertech Max Energy, Lots of Chrome!:cool
Turbo resonator box plugged! Nice Whistle!
EGR Blocker Plate.... White Lighting light bar by RECON
Tamperman is offline   Reply With Quote
Old 01-30-2009, 05:29 PM   eBay Motors   #5 (permalink)
NoSparks
NoSparks's Avatar
Almost forgot that.
Thank you.
Steve
Old 01-30-2009, 05:36 PM   eBay Motors   #6 (permalink)
Chkmeout08
Banned
will it ride alot ruffer?
Chkmeout08 is offline   Reply With Quote
Old 01-30-2009, 05:43 PM   eBay Motors   #7 (permalink)
Dmax15
Dmax15's Avatar
It'll be stiffer the higher you crank the bars.
2002 GMC LB7
homemade twin turbos, stock IHI over s475
EFI live tuning from IdahoRob
http://www.atptrucks.com
12.34 @ 108.7mph
Dmax15 is offline   Reply With Quote
Old 01-30-2009, 05:53 PM   eBay Motors   #8 (permalink)
farmer14
farmer14's Avatar
oh yes it will
2007.5 2500 ltz fully loaded crewcab,
banks air intake with scoop,
truxx 3inch lift, 33/1250r20
nathan k5la train horns,
b&w hideaway goose & 5th wheel
stealth 2, stacked with banks pda,
banks speed brake
mbrp duals-dpf & muffler delete
fire & ice lightbar, resonator plugged, egr blocked,transgo jr
farmer14 is offline   Reply With Quote
Old 01-30-2009, 05:58 PM   eBay Motors   #9 (permalink)
dirtymax04
It will be stiffer depending upon how much you crank. If you cant get 1 1/2 out of your stock keys get some ford keys. Your angles arent going to be too bad...they start getting bad over 2". You are going to want at least some shock extenders...or better yet go buy some new extended length shocks. and you wont damage the tbars, you will break the adjusting bolt off before you do that. And yes, jack the front end of your truck up, put some pb blaster on the bolts about an hour before you go out and do it
2004 GMC Sierra LB7 CCSB
--sold...lookin for another
dirtymax04 is offline   Reply With Quote
Old 01-30-2009, 07:10 PM   eBay Motors   #10 (permalink)
ankersen557
I had the dealership raise mine about 1.5in to 2. in to make it level. They allined it for me. Cost me about $60. I have not noticed any diff in the ride at all. And it looks much better.
2008 CC LTZ 4x4 Greystone Metallic, Edge Juice w/ attitude,DPF Back MBRP Exhaust, Alpine drop down 10in DVD, LINEX Bedliner, Window visors all around, 15% Tint all around, T-bars cranked 2in to level front(dealership done), HID 10000k,chrome 6in oval nerf bars,B&W turnover ball, Ultra Goliath +20mm offset 17-8 on 285-70-17 BFG ATs
EDJE JUICE WITH ATTITUDE FOR SALE $400.00 shipped OR BEST RESONABLE OFFER
www.HUSKERDIESEL.com[url]
ankersen557 is offline   Reply With Quote
