Old 02-02-2009, 09:23 PM   eBay Motors   #1 (permalink)
deskjet_18
deskjet_18's Avatar
Auto Headlights
I have the auto headlight. I have the off switch on my console for them but i turn the knob and it just goes back to auto it won't stay on off. How can i turn my headlights off in the dark when i want them to go off? This is a 2004.5 so the dome light trick does not work!
2004.5 LLY Crew Cab, Deep marine blue
Interior: 7" Clarion flip out deck with 2 10" Kicker subs powered by 1000W Kicker amp
Exterior: 285/75/R17 Hankook AT's on rims. Fender flares. Aftermarket hood. Head and taillights. Custom rear full window decal. Custom Blue driving lights.
Engine: AEM Brute force intake. 4" MBRP Turboback. Diablosport Predator. EGR Blocker plate. Intake horn block off.
deskjet_18 is offline   Reply With Quote
Old 02-02-2009, 09:25 PM   eBay Motors   #2 (permalink)
Chasesmax
even though the switch goes back to auto the lights should go off
2003 chevy 2500hd crew cab, edge with attiude, custom stack, 6" RCD lift with 35" bigfoot a/t
Chasesmax is offline   Reply With Quote
Old 02-02-2009, 09:34 PM   eBay Motors   #3 (permalink)
mookie980g
mookie980g's Avatar
you have to hit the dome override button a couple of times but once you shut the truck off and turn it back on auto will be engaged again i dont think there is a way to turn off the auto mode
2001 Chevy 2500HD CC\SB D-MAX\allison 5spd
1500series torsion keys to level it
PPE STANDARD 160 HP TUNE
Raptor 150GPH Lift Pump, aFe stage I intake,
5" MBRP W\6" Tip, Autometer Cobalt boost and pyro guage
KenWood Flip out,MTX 2 10" subs, MTX amp
windows tinted, HID's, smoked tail lights,Recon Roof lights, N-Fab Nerf Bars.
BEST TIME 15.145@91.35 ENGLISHTOWN RACEWAY PARK
mookie980g is offline   Reply With Quote
Old 02-02-2009, 09:48 PM   eBay Motors   #4 (permalink)
usafracer
Red trucks rule.
usafracer's Avatar
Flip the switch back one click and the lights will go off. The switch will still be in the auto position so next time you start the truck they will come back on. That or pull the DTRL (day time running lamps) fuse.
2008 GMC Sierra Crew Cab 4X4
2004 CC/SB 4X4 Duramax (sold)
Old 02-02-2009, 09:49 PM   eBay Motors   #5 (permalink)
sandboxrocker
sandboxrocker's Avatar
try your e brake as well
03 2500HD
Upgardes:
Edge Juice with Attitude, Volant Air intake with scoop, 4" mbrp, grill insert, tow mirrors, Pioneer DVD & Naviagtion B&W turnover.
sandboxrocker is offline   Reply With Quote
Old 02-02-2009, 09:56 PM   eBay Motors   #6 (permalink)
jcline
jcline's Avatar
I think if a truck is a Canadian build it wot let you override. Mine works great.
2005 LLY CCSB
Leather, Bose, XM
Truxedo bed cover, Line-X
305/75/16 BFG M/T's Ready Lift Leveling kit
B&W Turn-over-ball
Resonator plugged
NO CAT!!!!
Superchips Flashpaq (It was free and now I know why what a P.O.S.)
BG Synthetic fluids throughout!
jcline is offline   Reply With Quote
Old 02-02-2009, 10:07 PM   eBay Motors   #7 (permalink)
Duramax-LB7
Duramax-LB7's Avatar
all u do is push the overdrive button 2 or 3 times like they said and u can manually switch the lights from there...then do it again to go back to auto
-2002 LB7, CC/SB 4x4 SLT
Performance:
-EFI LIVE DSP 5,SUNCOAST IV, PPE BOOST VALVE, 4" TB MBRP exhaust, Volant Cold Air Intake,Banks Exhaust Brake, ISSPRO PYRO/BOOST, Intake Horn mod
Exterior:
-4" fabtech lift on 35x12.5x17R toyo M/T
tailights + third brakelight smoked, Bushwacker Pocket Style Fender Flares, Halo headlights and unders smoked, black nerf bars
Duramax-LB7 is offline   Reply With Quote
Old 02-02-2009, 10:09 PM   eBay Motors   #8 (permalink)
Duraski
Duraski's Avatar
X2 on what jcline said. My 02 the dome lite overide three times shuts the auto off until you either do the dome overide again 3 times, cycle the head light switch or the ignition key.
2002 2500HD Dur/Al CC SB LS 4x4 Sprayed in bedliner, Sun Visor Star Board running boards from previous owner. Edge w/attitude is installed again.
Next Mods when I have the Cash
4" Stainless Exhaust Single Or Duals?
1967 Camaro RS 327 .30 over Holley 650, Edelbrock hi-rise, Crane Fireball level three cam(torque range 2000 to 8000rpm double bumped heads Hooker Headers 2 inch Duals and thrush turbo muffs,4 Speed Saginaw.
Duraski is offline   Reply With Quote
Old 02-02-2009, 10:11 PM   eBay Motors   #9 (permalink)
usafracer
Red trucks rule.
usafracer's Avatar
The button only works on the 01-02's when they switched the body style they took that all away.
Old 02-03-2009, 02:32 AM   eBay Motors   #10 (permalink)
daddysLBZ
ONEFASTCOONASS..
daddysLBZ's Avatar
Wink
Cycling the override switch enough will do the trick,I use just my fog lights and the park lights like this...like they said though,you'll have to cycle the switch each time you shut her down.....
06.LBZ GMC[SLE1] 4x4 ....114k miles,4136 hours[Modded a bit.LOL]
1987 Monte Carlo SS 89k
1978 Malibu
FORMER DURAMAX FORUM MODERATOR...........i HAVE YOUR iNTERNET pROVIDER ADDRESS...:tease
