Old 06-22-2009, 08:39 PM   eBay Motors   #1 (permalink)
amo
battery issues
okey dokey...late last year replaced alternator and both batteries....last month pass side battery started seeping acid....took battery back and got new one. bosch hd batteries. now new battery same thing. seeping from seam...another bad battery or how does the charging system work? any ideas dmax gurus? 2005 k2500.
2005 K2500
Triple Dog
5" from downpipe
amo is offline   Reply With Quote
Old 06-22-2009, 08:43 PM   eBay Motors   #2 (permalink)
DuramaxOnTheBrain
DuramaxOnTheBrain's Avatar
Sounds like overcharging. I had a similar problem in my Suburban. It took a long time and many batteries before we realized the alternator was overcharging..... Even with a fairly new one I would check it out really well, maybe even pull it out and bench test it.
Brian
PPE Standard level 2
Kodiak mouthpiece
Truxedo Duece Tonneau
06 style leveled towing mirrors, 285 75 R16 BFG AT KO
BUY FROM MPF!!!!!
DuramaxOnTheBrain is offline   Reply With Quote
Old 06-22-2009, 11:57 PM   eBay Motors   #3 (permalink)
Toypuller
I am going with an overcharging condition. But the only way you will be able to tell that is a charing system test at the dealer or another like shop.
2005 LT 3500HD CCLB SRW LLY
EFI LIVE TUNED BY IDAHOROB
TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
Old 06-23-2009, 05:36 AM   eBay Motors   #4 (permalink)
amo
only overcharging one of them? the other battery does not have any issues.
2005 K2500
Triple Dog
5" from downpipe
Old 10-29-2009, 06:40 AM   eBay Motors   #5 (permalink)
amo
well summmm beeech...new alternator...fixed like a charm.....thanks all!
2005 K2500
Triple Dog
5" from downpipe
Old 10-29-2009, 07:23 AM   eBay Motors   #6 (permalink)
tpb1976
apparently i am havin the same problem,i had the alternater checked they said it was ok,but my gauge shows about 17 when running.
2001 2500hd lb7 a/t. ex cab sb.leather,straight pipe,westin steps,intake horn mod,billet grille emblem,mldgs removed,partially debadged,Quadzilla stealth 2 perfomancetruckproducts.com
tpb1976 is offline   Reply With Quote
Old 10-31-2009, 09:07 AM   eBay Motors   #7 (permalink)
Johnasara
Yeah, That guy!!!!!
Johnasara's Avatar
17 is overcharging it should be at 14 to 14.5 even as low as 13 sometimes but never 17.
4" DIAMOND EYE EXHAUST,
DIABLO @ 120,S&B COLD AIR INTAKE, RESONATOR PLUGGED
AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....Its Coming.....EFI LIVE.....
WORK RIG
Old 10-31-2009, 09:40 AM   eBay Motors   #8 (permalink)
bowhunternkbay
bowhunternkbay's Avatar
Yeah, I just bought 2 new batteries for 'ol Betsy. Noticed the gauge was "actin funny" so I had 'em check the altenator.It was fine,Checked each battery individually, both showin signs of goin bad. Replaced them both, everything back to normal. Gauge should read 14-14.5 volts. Never 17!!
'06 2500 HD CC/SB
BullyDog TripleDog
AiRaid CAI
MBRP 4" Turboback
Goodyear Silent Armor LT 285/75R16
Blocked,Fingered,Rerouted,Sleeved and Plugged
www.DiscountTireDirect.com
bowhunternkbay is offline   Reply With Quote
