Old 11-01-2009, 11:15 AM   eBay Motors   #1 (permalink)
Duramaxxed06
Duramaxxed06's Avatar
Coolant leak! Help!
I've isolated a coolant leak on my truck. Looks like the crimp from the soft line, to the hard line on one of the returns looks like it has gone bad.
Check out the picture, I'd like some opinions on how to fix it, and where I can get the parts... or who could do the work. I'm just outside of Atlanta, GA.
Thanks guys!
2006 Duramax LBZ SLT Crew Cab 4x4 w/nav
Stealth Gray
Edge Evolution CS
Edge A-Pillar
3" MBRP Downpipe (awaiting install)
s&b CAI Dry
MBRP 4" XP Series, no cat
2" T-Bar crankage
BF All Terrains (285/75/r16)
Fold-a-cover
Peripheral iPod Adaptor
Duramaxxed06 is offline   Reply With Quote
Old 11-01-2009, 12:52 PM   eBay Motors   #2 (permalink)
DuramaxSMOKE11
DuramaxSMOKE11's Avatar
which side of the engine and is it near the front of back and whats the leak near?
2005 Chevy 2500HD Duramax LLY, Banks ram air intake w/super scoop, Banks 4" exhaust, CAT DELETE and NO MUFFLER, EGR blocker plate & fingerstick, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, PPE standard, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
To come soon
AFE Intercooler, Raptor 150 pump, SunCoast tranny & TC
Big thanks to chad at Alligator performance and Guy at SoCal Diesel
DuramaxSMOKE11 is offline   Reply With Quote
Old 11-01-2009, 01:18 PM   eBay Motors   #3 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
trans line, famous line that always leaks, ive gone through 3 sets of them. the crimp is the problem, not the bend itself.
how many miles? it's covered under 3yr,36k warrenty.
Old 11-01-2009, 05:29 PM   eBay Motors   #4 (permalink)
Duramaxxed06
passenger side.. near the front.
Hondarider, im way outside of that warranty. But inside the 5 yr, 100,000... any help there?
Stealth Gray
Edge Evolution CS
Edge A-Pillar
s&b CAI Dry
2" T-Bar crankage
Fold-a-cover
Old 11-01-2009, 05:36 PM   eBay Motors   #5 (permalink)
lubeman1969
lubeman1969's Avatar
Thats a trans leak...HR552 said it...very common problem and should be warrantied by GM. There was definately a bulletin put out on this, at least I was told of one. Mine were replaced at 19k.
2006 2500 LBZ CREW CAB LONG BED * NFAB STEP BARS
35" TOYO OC MT"S W/ 18" ROCKSTARS * FABTECH 6" LIFT * FABTECH HD TIE RODS
BD FULL BORE MANIFOLD * S&B CAI
4" STRAIGHT PIPE EXHAUST * MBRP 5" TIP
TRANSGO JR 4/11/09...THIS WAS A GREAT MOD!!!
BANKS INTERCOOLER * RESONATOR HOLE PLUGGED
EGR BLOCKER PLATE * EDGE INSIGHT MONITOR
TUNED WITH EFI LIVE>>>NOTICE I AM SMILING!!!!
www.huskerdiesel.com
lubeman1969 is offline   Reply With Quote
Old 11-01-2009, 05:37 PM   eBay Motors   #6 (permalink)
Duramaxxed06
Think I'll have any issue trying to get the work done at 93k?
Stealth Gray
Edge Evolution CS
Edge A-Pillar
s&b CAI Dry
2" T-Bar crankage
Fold-a-cover
Old 11-01-2009, 05:49 PM   eBay Motors   #7 (permalink)
lubeman1969
I hope not, but who knows. They know that its a real common problem but they're not wanting to spend any money right now for sure! I know for sure that I read on here that many were being replaced under either a bulletin or a warranty recall. But if you have to do it yourself, its an easy fix. Just have to release the clips and pull the line out of the fitting. The hardest part will be figuring how to wiggle it out from under the truck. Shouldnt be bad at all.
Old 11-01-2009, 05:57 PM   eBay Motors   #8 (permalink)
Duramaxxed06
I deal with excavators on a daily basis, and change out hyd. fluid lines all the dang time. I could probably do this myself, but I'd need to know part numbers for etc. etc.
I think I'll call the dealership tomorrow to see if they can help me out... otherwise, I'm gonna need some help from you guys. Thanks for everything so far.
#08-07-30-049A: Transmission Oil Cooler Line Leak (Replace Affected Cooler Line) - (Mar 18, 2009)
Subject: Transmission Oil Cooler Line Leak (Replace Affected Cooler Line)
Models: 2006-2007 Chevrolet Silverado Classic 2500/3500 Series
2007-2009 Chevrolet Silverado 2500/3500 Series
2006-2007 GMC Sierra Classic 2500/3500 Series
2007-2009 GMC Sierra 2500/3500 Series
Equipped with 6.6L Diesel Engine (VINs D, 2, 6 -- RPOs LBZ, LLY, LMM)
This bulletin is being revised to update the warranty information. Please discard Corporate Bulletin Number 08-07-30-049 (Section 07 -- Transmission).
Condition
Some customers may comment on a transmission fluid leak. This concern will be more prevalent in extreme cold climates.
Further inspection may find that the leak is coming from one of the transmission cooler lines at the hose to steel line crimp.
Correction
If the under vehicle inspection reveals transmission fluid leaking from one of the cooler lines, replace the affected cooler line. New transmission cooler lines have been released to address this concern. These new lines have been manufactured with an updated crimp process to better withstand the cold temperatures. Refer to SI for the replacement procedures.
Parts Information
Part Number
Description
20759971
Pipe Assembly, Trans Fluid Cooler (Upper/Outlet)
20759972
Pipe Assembly, Trans Fluid Cooler (Lower/Inlet)
20759973
Hose Assembly, Trans Fluid Aux Cooler Inlet
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
K9528*
Transmission Fluid Aux Cooler Inlet Hose - Replace
1.7 hrs
Add
To Replace Lower Pipe if Required
0.2 hr
K9529*
Transmission Fluid Cooler Upper Pipe Assembly - Replace
2.3 hrs
Add
0.2 hr
Add
To Replace Aux Cooler Hose if Required
0.2 hr
Add
With 4WD
0.6 hr
K9530*
Transmission Fluid Cooler Lower Pipe Assembly - Replace
1.5 hrs
* This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
Stealth Gray
Edge Evolution CS
Edge A-Pillar
s&b CAI Dry
2" T-Bar crankage
Fold-a-cover
Old 11-01-2009, 06:17 PM   eBay Motors   #9 (permalink)
lubeman1969
Looks like you're equipped for the argument!! Good to go now.
Old 11-04-2009, 05:43 PM   eBay Motors   #10 (permalink)
Duramaxxed06
Update: Called 3 dealerships... including the one that the company uses for all of our fleet trucks... and they've all told me the same thing. Just because a TSB has been released, doesnt mean it can be fixed under the "sorry ass excuse for a" warranty blanket.
So, I was able to get a hold of Harley from Georgia Diesel, and I think he'll be helping me get this problem solved the right way. Looking forward to it as I am headed back home to MD for the holidays, on top of Steelheading in PA, and Huntin' in WV. I've got some driving to do!
I'll keep ya'll posted on the outcome. Thanks for all the info!
Stealth Gray
Edge Evolution CS
Edge A-Pillar
s&b CAI Dry
2" T-Bar crankage
Fold-a-cover
