| 2001 - 2007.5 (GMT800) Non Powertrain Discussion of 01 to 07.5 Topics Not related to the Powertrain, interior, suspensions, body,wheels, tires, ect. |
| Service 4 Wheel Drive Message When driving my truck to day I noticed that the service 4wd message was on my DIC. I shut the truck off and restarted the truck. Upon restarting the truck I noticed that while starting it all the led lights on the 4wd push buttons came on never noticed that before but honestly never looked at the buttons while starting the truck.The lights then go out and the led on the 2wd stays lit. I attempted to push the 4hi button and it appears as if the truck is not going into 4wd. After pushing the 4hi the 2wd light stays on. I do not feel or hear the truck going into 4wd. Did a search and it appears as if it could be the switch, encoder motor, or actuator on the axle. Are there any tests that I can do to narrow it down. Went to autozone and it showed no codes on their scanner. Are there any fluid monitors in the 4wd system where there could be low or dirty t-case fluid or axle fluid? Any help would be greatly appreciated!!!!!!!! The truck is a 2004 2500 HD with 173,XXX miles... |
| Senior Member Join Date: May 2009 Location: Ohio
| mine also did that. it was the encoder motor! the part was like 90 bucks and pretty easy to change. im not sure if there are any test to narrow down the prob.
__________________ 2003 chevy cc,sb 4x4 Engine: LB7 6.6 duramax diesel Transmission: allison 1000 Mods: transparts stage IV, S/C 1056 converter (built by me), EFI live w/ DSP2, LBZ fuel pressure regulator, 5" flo pro exhaust 6" dual wall tip, airdog 150, PPE billet pickup tube, K&n cold air intake, LB7 mouth piece mod, tripple piller gauge mount w/ fuel pressure,egt and boost, GM touch screen navigation, extang soft bed cover, tow mirrors, debadged Wheels & Tires: 20"x10" eagle wheels and 33"x12.5"x20" nitto mud grapplers |
| Senior Member Join Date: Dec 2009 Location: GA
| Transfer cases need servicing just like trannies |
| Junior Member Join Date: Sep 2008 Location: norwalk, ct
| Just curious if u ever figured out what was wrong cause mine is doing the same thing
__________________ 2003 2500 hd crew cab -ppe boost increse valve -MBRP 4 in. turbo back into dual 5 in. mitre cut stacks -ppe standard programmer-HID conversion-20% tints -ready lift leveling kit-18" KMC badlands wrapped in 325/60/r18 nitto terra grapplers-S&B intake-tie rod sleeves thanks to idaho rob- 3" body lift- autometer cobalt boost and pyrometer gauges |
| I did figure out what it was. It was the dash switch that has the three push buttons on it to select 2hi 4hi 4low. Easy fix for now..... |
| how did u determine that was the issue. did u do something in particular or just change the switch with the hopes that was the problem? thanks
| Yup, it's a dikfir. Join Date: Jan 2009 Location: Chandler, AZ
| I am having the same issue & pretty sure it's my push buttons. What exactly did you replace? Thanks
__________________ 2006 GMC Sierra 2500 LBZ Edge Juice w/ Attitude & hot unlock TransGo Jr - Volant air intake MagnaFlow 5" turbo back exhaust Diamon Eye downpipe - Kennedy boost stick Blocker plate & finger stick - Firestone airbags Viair compressor - Train horn -3 gal air tank 34' Thor ToyHauler |
| Junior Member Join Date: Jan 2010
| I have '03 gmc 2500 4wd dmax. svc 4wd light keeps coming on, check engine lt comes on and off. trsnfr case switch 2wd/4wd/4low sometimes switches to neutral, 4wd or 4 low and still actually in 2wd. sometimes when it is shut off for a while, it will clear up. has anyone figured out what is really going wrong and what to do? |
| Junior Member Join Date: Nov 2009 Location: Highland, IL
| my old truck was a 2000 half ton truck and it did that same thing w/ the service 4wd light and mine was the switch in the dash. popped front trim panel around the gauges, removed 2 screws(i think) and unplug and replace. very easy to do. my part cost me aroud 60 bucks if i remember right, i know it wasnt a lot.
__________________ 2007 2500 Classic CCSB LBZ 265 Dick Cepek FC II EFI W/DSP5 and egr blocker..thanks to Dustin & Rob @ www.atptrucks.com Truxedo Bed Cover Plugged Resonator Banks CAI MBRP XP 4'' (missing kitty) Exhaust & CAI thanks to Nate @ www.performancetruckproducts.com/ 2012 Puma 31KBH |
| Duramax Lifetime Supporter Join Date: Aug 2009 Location: Phoenix
| These switches go bad all the time. Put two in my gasser, never one in the DMax though (yet)
__________________ 2002 Silverado 2500HD LB7 FE9 Ext Cab 4x4 LT, Goodyear Wrangler MT/R 285/75R16, Resonator plugged, B&W Turnover ball, LB7 Intake Horn Mod, PPE Airbox mod, Rancho 9000XL shocks, PPE Running Level 3! 4" MBRP Turbo Back,Pillar Mounted Autometer Cobalt Boost and Pyro gauges, PPE Boost Increase Valve |
