Old 03-24-2008, 02:19 PM   eBay Motors   #11 (permalink)
Nor-Cal Nick
Nor-Cal Nick's Avatar
Keys are not the way to go. They max out your travel. Most of the time you can just use your factory keys to get what after markey key will do.
Read this:
-- I will post ..
Nor-Cal Nick
2008 Chevy 3500HD Dually LTZ <<< Clink on link to see truck.
Cognito 2-3 leveling kit, HD tie rods, Steering braces, Idler pivot, Front & Rear Sway Bar, Bistein's frt & rear, Sulastic shackles, Bags, Toyo MT 295/70r17 w/2" spacers, AFE stg2, MBRP 5" turbo back w/RBP back 6" tip, EFI Live by Duramaxtuner.com, Nexus gauges, Nicktane fuel filter, TTS Dual pumps & pick up, Transgo JR, MagHytec Trans & Diff pans, Titan 62gal fuel tank, Amp boards, 8000k HID Headlights and fogs, Drawtite Sig.24k 5er.
6-7-08 “400hp Fun Tune” >> 414hp./786tq.
6-7-08 “LMM08_08_HOT_6.07.08_Highboost” >> 440hp./805tq.
Nor-Cal Nick is offline   Reply With Quote
Old 03-24-2008, 02:20 PM   eBay Motors   #12 (permalink)
BigRedChevy
Post Slut
BigRedChevy's Avatar
I have the Ready lift on my truck. I did not crank the bars up any with it so it is not completely level but is real close. Rides the same and have had no problems.
KYLE
Old 03-24-2008, 02:44 PM   eBay Motors   #13 (permalink)
Nor-Cal Nick
Here is what a stock GM UCA and factory frame stop should look like.
* This space will very on every truck that comes off the show room floor because GM sets there trucks up alittle deferent per what tire package they put on the truck.
After you crank your bars up you start to loose rebound/drop out travel.
When you turn your keys up you limit the travel first with your factory shock. Easy fix with extenders or longer shocks.
After the shock you loose drop out travel between the UCA and frame stop. A bad ride at that point, metal to metal. You also get a bad factory ball joint angle that binds and will wear out fast. Also the factory UCA does not allow for correct alignment spec. most of the time.
Turning your bars up are the number 1 upgrade GM owners do to get a little bigger tire under there trucks. So Cognito looked at the problems that occur and came up with there Cognito 2-3 leveling UCA kit. The bases is to correct ball joint angle and alignment specs. When testing there set up they found that the factory CV shafts will allow for alittle more drop out than factory allows. So when you find that the stance you get after cranking your bars is where you want your truck to sit and your ride has gone bad then you have ran out of drop out travel, the Cognito UCA will give you 2" more drop out from there to gain your ride back.
Again does the Cognito UCA kit give you lift? No, it corrects the problems that occur when you level your truck with factory UCA.
- For guys that are drag racing using 4wd and sled pullers, this kit is not for you because the CV angles are greater than you can use at that torq. when in 4wd. A 4" lift with a drop front diff. will work better since you will have level CV angles not cranked up.
- Guys that are every day drivers and regular 4wd offroading, this kit is great for you to get bigger tires under the truck for a better look.
- This kit works best with Bil5100's front and back.
- You can add a rear 1" block and u-bolt to raise the rear as well.
Hope this helps....
Nor-Cal Nick
Old 03-25-2008, 04:49 AM   eBay Motors   #14 (permalink)
ob_1jr
Super Moderator
ob_1jr's Avatar
Very good informative write-up. thanks
4" turbo back MBRP exhaust
Kennedy Diesel
Merchant Automotive
My Photos
ob_1jr is online now   Reply With Quote
Old 04-25-2008, 11:58 PM   eBay Motors   #15 (permalink)
chevyman07
chevyman07's Avatar
Good to know..
2007 new body style LMM DURAMAX silverado HD 2500 4x4 crew cab. 12,000k Xentec HID lighting system. Bilstien frt & rear. chrome bowtie.
chevyman07 is offline   Reply With Quote
Old 04-26-2008, 12:14 AM   eBay Motors   #16 (permalink)
chevyman07
chevyman07's Avatar
So with all that said . does that mean ready lift leveling kits are bad to put on your truck.
Old 04-26-2008, 09:34 AM   eBay Motors   #17 (permalink)
Nor-Cal Nick
If you over crank then yes. It comes down to all the key leveling kits over project lift on your front end. If you can get the lift that still keeps you in the area of a good right then those kits pretty much waist your money.
Nor-Cal Nick
Old 04-26-2008, 10:44 AM   eBay Motors   #18 (permalink)
Court
Court's Avatar
Sounds like its a double edged sword here. either go with a cheaper leveling kit and wear out fron end parts faster, or IMO if your going to spend that much mney to level a truck, you're almost better off spending the little extra money and getting a 4 or 6 in lift kit.
2008 Chevy 2500 Crew Cab Z71 dark Blue Metalic.
Chrome bug shield
Pro Comp 6047's 18x9
BFG's 285/65/18
Lund seal and peel tonau cover
Ready Lift Leveling kit
Front windows tinted to match the rear's
Banks Ram Air Intake
Court is offline   Reply With Quote
Old 04-26-2008, 11:02 AM   eBay Motors   #19 (permalink)
Nor-Cal Nick
Pretty much. Just depends how much you want to sink into it and if you even want to go as high as a full lift.
Old 07-01-2008, 12:13 AM   eBay Motors   #20 (permalink)
MrTerry1
Hey nick Ive been thinking about doing this leveling kit on my truck but do i need to do all the other stuff that they sell as well (i.e. all the steering upgrades and i pitman control part) ??? I race in baja and do alot of off roading but my tuck is only a support truck that hauls parts and tows and will come in if it needs to, but its not "mobbed" as the kids say. thanks for any help looking to get all the stuff for you so let me know.
2008 Chevy 3500HD Crew Cab Short Bed 4x4 6.6L Buckstop Baja winch bumper, custom built flat bed with sideskirts tool boxes, custom built chase rack with 4 hella hid lights, with a miller welder/gen mounted in bed.
2008 Trophy Lite Chevy Colorado race truck.
2007 Chevy 4500 FunMover Motorhome/toybox
MrTerry1 is offline   Reply With Quote
