Old 05-02-2008, 06:36 PM   eBay Motors   #1 (permalink)
jack_usa
Points: 595, Level: 8
Points: 595, Level: 8 Points: 595, Level: 8 Points: 595, Level: 8
Activity: 0%
Disconnecting Onstar?
Any clue on how to pull the plug on big brother Onstar transmitting all my private truck info to GM? Onstar collects diagostics and other info. I don't want my truck transmitting to GM.
Thanks
jack_usa is offline   Reply With Quote
Old 05-02-2008, 07:39 PM   eBay Motors   #2 (permalink)
aaronlbz
Points: 281, Level: 5
Points: 281, Level: 5 Points: 281, Level: 5 Points: 281, Level: 5
Activity: 0%
I think there is a fuse under the hood in the fuse block. Try checking there, or just cancel the service, thats what I did, even if it is free for the first 6 months like mine was you can still cancel it.
06 Crew Cab 4x4 Duramax LBZ
PPE Standard
Transgo Shift Kit
AFE Stage 2 Air Intake
aaronlbz is offline   Reply With Quote
Old 05-02-2008, 11:55 PM   eBay Motors   #3 (permalink)
r.laz
Points: 2,641, Level: 21
Points: 2,641, Level: 21 Points: 2,641, Level: 21 Points: 2,641, Level: 21
Activity: 4%
Activity: 4% Activity: 4% Activity: 4%
r.laz's Avatar
I tried looking for it on the schematics, but it doesn't show. I believe this is how GM knows that we're messin' w/ the ECM...
08 Sierra WT CC SB
Steel Gray 4x4
PPE RACE
Modded OEM AirBox/PCV Reroute/4" MBRP into 5" MagnaFlow
Isspro EGT/Boost gauges Cognito Leveling Kit/HD Tie Rods
Pitman/Idler Support Brackets/Bilsteins
Pirelli Scorpion ATR 265/75/16 Coated OEM Wheels
Factory Oval Steps/Rhino Lining EGR BLOCKED
r.laz is offline   Reply With Quote
Old 05-03-2008, 01:11 PM   eBay Motors   #4 (permalink)
haunruh
Points: 1,355, Level: 14
Points: 1,355, Level: 14 Points: 1,355, Level: 14 Points: 1,355, Level: 14
Activity: 0%
haunruh's Avatar
Are you suggesting that even if I haven't signed up for the service, they're still monitoring my truck? I sure hope not!!
2003 Chevy 2500HD LT LB7 XCab SBox 4X4, Hypertech PP3, K&N, Pendaliner, Truxedo Bed Cover
haunruh is offline   Reply With Quote
Old 05-03-2008, 06:55 PM   eBay Motors   #5 (permalink)
topcat
Points: 275, Level: 5
Points: 275, Level: 5 Points: 275, Level: 5 Points: 275, Level: 5
Activity: 0%
I'ts only on the new trucks and it's only for a year.Just call them and cancel it,my 03 never had it but our saturn did and i called and canceled it.
topcat is offline   Reply With Quote
Old 05-03-2008, 07:35 PM   eBay Motors   #6 (permalink)
Lazydog
Points: 399, Level: 6
Points: 399, Level: 6 Points: 399, Level: 6 Points: 399, Level: 6
Activity: 0%
Lazydog's Avatar
OK, lets look at this................
Just because you canceled your subscription doesn't mean they cannot and/or are not monitoring your vehicle. The signal is always there. Not sure how they monitor be it cell signal or some other way. Someone has to be footing the bill and I don't think onstar will be doing this without being paid for it.
The next thing is does the vechile transmit all the time or does something have to request the information? If it is transmitting all the time then it would be nothing for someone to monitor it. If a request has to be made then that will cost some one something thus the subscription.
I am not sure how the system works but if you are paranoid then disconnect the feed.
Regards
Robert
Smile... it increases your face value!
2006 2500HD CrewCab LBZ 4x4 // Nerf Bars // Rhino Bed Liner // Truxedo TruXport Roll-Up Tonneau Cover
Lazydog is offline   Reply With Quote
Old 05-05-2008, 05:39 PM   eBay Motors   #7 (permalink)
John-Boy 331
Points: 1,520, Level: 15
Points: 1,520, Level: 15 Points: 1,520, Level: 15 Points: 1,520, Level: 15
Activity: 11%
Activity: 11% Activity: 11% Activity: 11%
John-Boy 331's Avatar
you can always dial 911 on a cell phone w/o service,,,,, onstar same thing no service but it works w/ 911, also works to find stolen vehicles,,,, who's to say they can't find out info on your truck for other reasons
06 LBZ 3500 4x4 single rear wheel regular cab long bed WT. PPE economy, 4" turbo back straight pipe, solid gooseneck, drw wrecker prep springs, blocked, fingured, 2"plugged, and plenty of UWS boxs. work in progress
John-Boy 331 is online now   Reply With Quote
Old 05-06-2008, 05:14 AM   eBay Motors   #8 (permalink)
jack_usa
Activity: 0%
How do i disconnect the feed? Having GM/ONstar monitor my truck's info is none of their business.
Old 05-06-2008, 07:07 AM   eBay Motors   #9 (permalink)
Lazydog
Activity: 0%
Lazydog's Avatar
I would think just disconnecting the antenna should be enough. But not from the roof side do it on the other end. The wire going to the external antenna could have enough power to still send a signal.
Regards
Robert
Old 05-06-2008, 08:05 AM   eBay Motors   #10 (permalink)
FH Leader
Points: 394, Level: 6
Points: 394, Level: 6 Points: 394, Level: 6 Points: 394, Level: 6
Activity: 0%
Your truck is monitered by sat signal. They are not looking for a programer or anything like that, all they are doing is monitering you oil, air bags and crap like that hoping if there is a problem you will take it back to the chevy dealer to get it fixed. When your truck gets stolen and they cant find it cause you diconected onstar that would just suck. Any ways if your truck is older than 03 and you did not do the up grade you have nothing to be afraid of. The upgrade canges it from cell signal to sat signal.
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog tri dog with outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16
FH Leader is offline   Reply With Quote
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
