| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 2001 - 2007.5 (GMT800) Non Powertrain Discussion of 01 to 07.5 Topics Not related to the Powertrain, interior, suspensions, body,wheels, tires, ect. |  |
12-01-2005, 07:41 PM
eBay Motors
#1 (permalink)
| | Junior Member
| cold weather starting If the truck has been sitting for a couple of days in cold weather my 2001 Duramax stalls after running for 20 to 30 seconds. The fuel filter has to be primed for it to start again. Has any one else had this problem? |
| Advertisement
12-01-2005, 10:09 PM
eBay Motors
#2 (permalink)
| | Super Moderator
| nope, maybe your o-ring to your filter is messed up or your bleeder screw is leaking air and not sealing properly. When was the last time you changed your fuel filter? I normally put a little petroleum jelly on the gaskets/o-rings and have never had a problem. Also had the truck sit for a month this last summer with no problems.
4" turbo back MBRP exhaust
AFE Magnum Force Stage 2 Proguard 7 intake Kennedy Diesel Merchant Automotive My Photos |
12-05-2005, 07:08 PM
eBay Motors
#3 (permalink)
| | Member
| I'd guess your truck has a air leak in the fuel system also. My 96 CTD had a very tiny crack in a flexible fuel line. Replaced the flexible line and solved the hard starting issue. I'll replace the flex line on my chevy before that long, once is enough. |
12-08-2005, 03:04 AM
eBay Motors
#4 (permalink)
| | Junior Member
| i'm curious if your fuel is gelling a little. Has it been doing this a while or just this one time?
__________________ James Wiger Home page Powerstroke.org '05 PSD, Silver, SCLW, Torqshift, 4x4 -- Mods: Fast Idle switch
'05 Freestyle, Silver, CVT
'68 Mercury Cougar, Red, 306, C6
'65 New Yorker, white, 4dr.ht., 413cid, 727TF, 400,000 original miles |
12-15-2005, 03:37 PM
eBay Motors
#5 (permalink)
| | Junior Member
| Cold starting Had my 2001 in to dealer just under warranty they replaced fuel line , filter, and what they thought was the problem the fuel injector modular it seems to have worked . I even think it runs better.Bryan |
| Advertisement
