How to drain the fuel tank? - Chevy and GMC Duramax Diesel Forum
Old 04-03-2011, 06:32 AM   eBay Motors  #1 (permalink)
greygoose08's Avatar
anyone know how to drain the fuel tank on a 07 lbz? its got like 3/4 tank of fuel and i wanna remove the tank today. is there a drain somewhere on the lower portion of the tank that will drain it of does a person have to siphon(sp) it out?
2011 GMC SIERRA DENALI HD - Stock for now- line-x, 5% tint all around, cleared headlights, black mbrp tip, color matched steps and bed rails, 20x9 BMF S.O.T.A. w/ 33x12.5 toyo open country m/t's
greygoose08 is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 10:30 AM   eBay Motors  #2 (permalink)
Super Moderator
jc1843's Avatar
I think it is easier and safer to remove the bed-[ 6 bolts]- unless you are replacing the tank.
There is no drain plug, so you could purchase a siphon drain from a auto parts store.
Chevy 04.5 LLY, 2X, shell, XDR, MikeL Heavy duty up-grade, 6spd, TransGo, deep pan, de-badged, 65 Gallon replacement Aero tank, LBZ-mp, Kennedy pump, shimmed, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags, custom grille, fender vents, HD trans cooler- Curt front hitch, footwell lights, load lights, Studs, head gaskets.--- Jerry
jc1843 is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 10:56 AM   eBay Motors  #3 (permalink)
DirtyMaxx03's Avatar
autozone sells a cheap little pump thing that works good. its a straw you stick down into the tank and you just crank a little handle and it pumps fuel out
Sean
2003 Lb7 2wd
Dropped
Efi Live by Rob Coddens
s472
DirtyMaxx03 is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 11:10 AM   eBay Motors  #4 (permalink)
good thats what ill have to do, i just didnt know for sure if there was a drain on the tanks. im gonnna have to pump it out anyway, its 3/4 tank on a 34 gallon tank so you do the math. theres 150-200 lbs of fuel in it plus all the tank and theres no way id be able to tip it up and out without wasting it all in the process.
Old 04-04-2011, 11:11 AM   eBay Motors  #5 (permalink)
it is worth the 20 bucks, i dropped a tank that had 20 gallons in it. i'll never do it again.
Sean
2003 Lb7 2wd
Dropped
s472
Old 04-04-2011, 11:13 AM   eBay Motors  #6 (permalink)
haha yup, theres been a couple times i wish i had a pump, and have ended up just using a hose and myself as the pump, not fun times
Old 04-04-2011, 11:14 AM   eBay Motors  #7 (permalink)
yeah. better have some nice minty gum if you're gonna do it the ol fashion'd way hahaha
Sean
2003 Lb7 2wd
Dropped
s472
Old 04-05-2011, 10:45 AM   eBay Motors  #8 (permalink)
nsolimini's Avatar
That doesn't even help if you suck too much
Thanks to Deck Diesel Performance
2008 LMM CCSB LTZ-DSP5, MBRP exhaust, EGR blocked, leveling kit, 20x10 Fuel Mavericks, Toyo A/T
Sold2007 LBZ 2500HD Crewcab 4x4, EFI Live DSP5, TransGo Jr, Airdog II 165, MBRP 3" Downpipe, AFE intake, 4inch RBP turboback straight piped exhaust, egr blocked, PCV Rerouted, tie rods sleeved, 20inch Fuel Hostage, 305/55R20 procomp extreme A/t
SOLD2003 2500HD Ext cab LB7 4x4, EFI Live DSP5, PPE Boost Valve, Airdog 150, AEM HD intake, MBRP 5inch straight pipe, 20 inch eagle alloy 097, 33inch federal couragia mt
nsolimini is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 11:04 AM   eBay Motors  #9 (permalink)
i'll be over in a little while... i have an "extra" tank you can put it in
Rattlin & Gobblin
2006 Chevy 4x4, CCSB, LLY, 225s on forged alum 19.5 Ricksons, MIA muffler
Husker Diesel | 402-502-6961
Kst8er is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 03:05 PM   eBay Motors  #10 (permalink)
that pump worked but it sucked. i swear it took like 3000 pumps total to empy that tank into fuel jugs then pump back into my trucks tank cuz the lines where long enought to just go tank to tank..
