| 2007.5 + (GMT 900) Non Powertrain--New Body Style-- Discussion 07.5 - 2010 Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect. |
| | eBay Motors #21 (permalink) |
| Senior Member ![]() Join Date: Mar 2012 Location: League City, TX
| Thanks for the quick reply man, Ill send you a PM.
__________________ 2007.5 CC/LB 4x4 LMM LT 48k miles and counting. MODS; Wanted: AFE full metal, 7-9" COG, 22s on 35s, Color match everything. Installed:EFI Live w/ DSP5 by Kory Willis, 60,80,100,120,kill, MBRP SS 5" TB, Alligator PCV reroute w/ billet plugs, ProFab EGR delete, ProFab DP, modded up-pipe, alligator Trans lines, demoulded and debadged, color matched handles. 2003 Honda RVT1000r RC51. AKRO exhaust, power commander, -1,+3 TORQUE MONSTER Big thanks to Synthetic motorsports. Kory Willis, buttapollock1010, 07Dirty, RickDLance |
| | eBay Motors #22 (permalink) | |
| DuramaxForum Enthusiast Join Date: Mar 2011 Location: jackson,nj
| Quote:
__________________ - 2010 GMC sierra dually SLT CC - sdp twins,60 overs, efi by rob, trac bars built trans/ suncoast 1058 converter djm 3/5, sleeves and braces, 5inch straight pipe cts insight, ad2 165, 1pc shaft, reroute airbags, bt lockbox thanks to: Bigdipper, ATP, BT Dieselworks, Blackout Performance time to beat: 12.60 @ 108 | |
| | eBay Motors #23 (permalink) |
| Senior Member Join Date: Sep 2009 Location: NYC/Boston
| email sent. the set up your using is pretty stright forward, you should be good
__________________ -Ryan- 2007.5 sbcc LTZ white/black interior 5" Magnaflow down pipe back, DPF GONE Edge Evolution Race CTS, 20% all around, smoked lights. 22" BMF novakane wheels on 33" Toyo mt's 4" Cognito lift 2000 Cummins 24 valve eclb 4" turbo back, rebuilt tranny billet TC, 5% all around needs a lift pump, guages and tuner DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| a remote starter with multipile channels to turn seats on. As for the heat/ac... just leave it on before you shut the truck down. I see your in Jersey, come on up, I can set you up
| i will consider this. if i decide to do it i will take you up on the install! where exactly are you located?
| Junior Member Join Date: Jan 2012 Location: Watertown NY
| My girlfriends father has a 2005 or 2006 Chevy Duramax and he told me on his truck there was a way to turn up the idle for startup. The reason for this would be to warm the truck up a little fast anyone heard of this? |
| | eBay Motors #27 (permalink) |
| Junior Member Join Date: Feb 2012 Location: NW Ohio
| Cory, with my 08 on the dic / system settings there is a high idle setting. Not sure if that is the same for the older trucks? Sent from my Galaxy Nexus using AutoGuide.Com Free App
__________________ 2008 Silverado 2500HD 6.6L LMM CCSB auto LTZ 4x4 108k XD Monsters in Chrome 20x9 +18mm offset, 285/55r20 Nitto Terra Grapplers, NorCalNick large fender mod, T-Bars cranked 2.5 turns from stock, RideRite 5000 air bags, B&W Turnover ball, B&W 5th Wheel Companion, Custom B&W to pullrite adapter, PullRite Super Slide 24K 5th wheel Idaho Rob tunes, DSP5, V2, Insight CTS, MBRP 4" DP back w/muffler and 5" tip, EGR Blocked, PCV Rerouted, Nicktane adapter & Donaldson P553203 fuel filter ----Trailers & Stuff---- 2011 5th wheel Sabre 32BHOK-6 all the goodies (13500lbs) 2008 20000lb dump trailer 2000 773 Bobcat Old equipment trailer 14000lb Sold 2001 2500HD 6.6L LB7 Auto 4x4 CCSB LS 105K Sold 2002 F250SuperDuty 7.3L PowerStroke auto 4x4 |
| | eBay Motors #28 (permalink) |
| I have a 09 I haven't seen anything in the dic. Am I just missing it or so they no longer have it? |
| | eBay Motors #29 (permalink) |
| Should be in the menu list along with tilting the mirrors for reverse, power seat all the way back at exit, what lights turn on when using your remote and all that other stuff. I think you have to have the factory remote start option for the high idle also. Hope that helps Sent from my Galaxy Nexus using AutoGuide.Com Free App
| | eBay Motors #30 (permalink) |
| DuramaxForum Veteran ![]() Join Date: Jun 2012 Location: Choctaw, OK
| Is there anyway to increase the starter crank time? When it gets cold my truck need like an extra second to crank over. As it is right now it attemps to turn on in literally a half second crank which fails... then it keeps trying to crank every 10 seconds these worthless half second cranks that cant start the truck up.
__________________ My LMM Build Thread 08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves..... |
