Anyone have 1-2 inch drop shackle??? - Chevy and GMC Duramax Diesel Forum
2007.5 + (GMT 900) Non Powertrain--New Body Style-- Discussion 07.5 - 2010 Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect.
Old 12-01-2012, 10:07 PM   eBay Motors  #1 (permalink)
GMCRIG's Avatar
Anyone have 1-2 inch drop shackle with tow bags???
So I have close to 33 inch tires and did the fender mod and a little crank with the T bars so tire are now clearing but I don't want to crank any more to get front end higher then the rear. I want the front end to sit higher then the rear and was thinking of just throwing the drop shackles to level.
Are tow bags gonna be a problem with 1-2 inch rear drop?
GMCRIG is online now   Reply With Quote
Old 12-02-2012, 07:47 AM   eBay Motors  #2 (permalink)
GMCRIG's Avatar
Morning Bump
Old 12-02-2012, 07:56 AM   eBay Motors  #3 (permalink)
6dot6's Avatar
oh thee ole carolina squat eh? im betting that 1-2 inches in the rear really wont make anything noticable if you didnt really crank your bars much. you can also try takin out overloads in addition. might give you around 2-3 maybe? post pics when your done.
- 2010 GMC sierra dually SLT CC -
sdp twins,60 overs, efi by rob, trac bars
built trans/ suncoast 1058 converter
djm 3/5, sleeves and braces, 5inch straight pipe
cts insight, ad2 165, 1pc shaft, reroute
airbags, bt lockbox
thanks to: Bigdipper, ATP, BT Dieselworks, Blackout Performance
time to beat: 12.60 @ 108
6dot6 is offline   Reply With Quote
Old 12-02-2012, 08:37 AM   eBay Motors  #4 (permalink)
GMCRIG's Avatar
I need the over load for the 5th wheel. But I have been looking at the
Cognito leveling kit as well. My issues is that the I don't want to
buy a upper arm then have the rear just a tad higher then the front
still. I was looking on the NorCal site and saw the trucks with
leveling kits but the front is not really level to me, but that's just
me... it does looks close.
Old 01-12-2013, 05:44 PM   eBay Motors  #5 (permalink)
GMCRIG's Avatar
Any one have 33's on a stock front with just the 2 inch lower shackles and have a picture?
2010 GMC Sierra 2500HD 4x4 White CCSB - 33's BFG AT's - XD Hoss wheels - PPE PCV - PPE modded air box - Remote start - Tow mirrors - Line-X - Amp Steps - Fumoto Valve - Firestone towing bags w/ compressor - filled with Amsoils -
Old 01-12-2013, 05:52 PM   eBay Motors  #6 (permalink)
espey34's Avatar
I have a shackle that will do 1"-4" bought it for my 04 not sure if it will work on 07.5+ but they might
Jeff-04.5 CCSB LS,Kory Willis tuned, Edge CTS, EGT and Boost guages, Afe MP, SDP EGR delete, PCV Reroute, AD 165, Fuelrail/cp3 fittings, FPRV shimmed, DHD Boost tubes and Downpipe, MBRP 4" w/6" stack, Cognito UCA's ,pitman/idlerarm braces, Bilstiens, Kryptonite centerlink/tie-rods, Trac bars by me, MA T-case brace, Kool-vue tow mirrors, Line-x everywhere, Amsoil synthetics, All light mod, 20" XD Hoss +18 305-55 TrailGraps. 2 Kicker 8" L7's
NathanAirchime K3la Hornair 548 kit with GW manual valve
BIG WISH LIST!
SYNTHETIC MOTORSPORTS AND KORY WILLIS FTW
espey34 is offline   Reply With Quote
Old 01-12-2013, 06:01 PM   eBay Motors  #7 (permalink)
Hang it!...Fire!
TDIpowered's Avatar
The cognito should be fine. It is just a matter of adjusting the keys afterwards. If you can't get the front high enough on stock keys with the uca kit, then you'll need leveling keys. But at that point you'll definitely have to upgrade your shocks to longer ones if you haven't alway
Max - 07 LBZ ECLB LOWERED!
Old 01-12-2013, 06:07 PM   eBay Motors  #8 (permalink)
GMCRIG's Avatar
Thanks
Old 01-13-2013, 06:09 AM   eBay Motors  #9 (permalink)
danhr's Avatar
33"s, with 3" lowering shackle. Did the Nor-cal large fender mod. No rubbing... even at full lock while going over bumps.
2007.5 2500HD CC/SB LTZ
498 rwhp, 845 rwtq
DiamondEye 4", Edge Evo Race CS, S&B Intake, Bilstein 5100 shocks, MOOG idler/pitman with SS support, Raptor 150, P553207, !PCV, !EGR, Transgo Jr, Rare Parts tie rods, 55 watt 4.5k HID low/hi/fogs, Belltech 3" lowering shackle
danhr is offline   Reply With Quote
Old 01-13-2013, 10:47 AM   eBay Motors  #10 (permalink)
nvrplzd's Avatar
^trucks looking good man.
To the OP, Definitely go with 3" shackles. The best part about them is that they have additional holes to be able to set them at 2" (and maybe one, never measured mine)
Belltech part #6403 is the ticket imho.
just be warned... it may not be low enough for you (I found this out the hard way)
Tyler-
2007.5 3500HD SRW Long N' Looow
EFI by Kory Willis, Garrett, DJM, DPC, PPE, Airdog, Nitto, Profab, Airlift, Cognito.. just to name a few.
BIG thanks to Will with Troll Performance Tuning and Matt with Blackout Diesel Performance
2004.5 LLY Ext Cab 8' ~EFI, Fabtech 6" and much, much more.. SOLD
nvrplzd is offline   Reply With Quote
