stock specs??? - Chevy and GMC Duramax Diesel Forum
2007.5 + (GMT 900) Non Powertrain--New Body Style-- Discussion 07.5 - 2010 Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect.
post #1 of 11 (permalink) Old 02-16-2009, 06:07 PM Thread Starter
cbchevy98's Avatar
stock specs???
does anyone know what the stock hp and torque rating is on an lmm i know i could look it up but i figurted theres plenty of people here that would know.... just wondering ... thanks!!!!
2008 3500hd,Duramax,
4 inch rancho, pro comp traction bars, 35" tires
airaid intake,straight piped,8"cat stack,egr delete,pcv reroute,downpipe,Alot of bumper,blowoff valve, EFI live,dsp5,tuned by idaho rob
cbchevy98 is offline
post #2 of 11 (permalink) Old 02-16-2009, 06:08 PM
timespentsearching's Avatar
at the crank, 365 and 660
03 EC/LB LB7: EFI LIVE, S&B intake, 5" DE, ATS manifolds and up pipes, Stock turbo (for 1 more weeks), airdog 150, pieced together trans, sleeve (trac bars and centerlink soon), 8" rear air bags-overload springs+2" blocks, bilstein 5100 shocks, leveled, nitto 285/75/17's and BFG KM2 255/85/16's for winter.
timespentsearching is offline
post #3 of 11 (permalink) Old 02-16-2009, 06:09 PM
Slave to the Interwebs
Johnasara's Avatar
365hp and 655 tq I beleive.
Johnasara is offline
post #4 of 11 (permalink) Old 02-16-2009, 07:05 PM Thread Starter
cbchevy98's Avatar
thank you! i knew that would be faster than looking it up!!
post #5 of 11 (permalink) Old 02-16-2009, 09:52 PM
And that is with the DPF in place.
Thanks to Navistar and the over badged 08 Superduties for turning me off Ford and getting me to buy my 2008 Silverado 3500 HD Dually LTZ Duramax Allison. Wow, what a truck!!
Big White Dmax is offline
post #6 of 11 (permalink) Old 02-17-2009, 06:20 AM Thread Starter
cbchevy98's Avatar
and thats at the crank... anyone know by chance what its rated at the wheels?
post #7 of 11 (permalink) Old 02-17-2009, 06:29 AM
One Hudered Thousand horsepowers
2008 2500HD Crew Cab LWB
MMcanulty is offline
post #8 of 11 (permalink) Old 02-17-2009, 06:35 AM
Duramax-LML's Avatar
my dads lbz which is rated 360hp/ 650ftlb tq just 5hp less than the LMM was dyno'd at 281.3rwhp and 496.2 act ftlbs tq after ppe at 160hp it was 347.5rwhp and 668.7ftlb tq
Name: Jake Age:26 INSTAGRAM: @jakethomaspnw
2013 Duramax LML CCSB LTZ My Build Thread
SPORTSMAN CP3/ S369SXE/ 30% OVER EXXERGY INJECTORS, FASS 150, diamond eye 5" TB,6" Fabtech Lift no bolts, 35inch Toyo M/T, 20x12 Fuel Octanes,ISSPRO EV2 GM MATCH, BOSS grill,Fusion front and Iron Cross rear, Pioneer In dash, subs, ARB twin air compressor, Cognito UCAs
Duramax-LML is offline
post #9 of 11 (permalink) Old 02-17-2009, 06:36 AM
so its prolly just 1 or 2hp more than the LBZ on the dyno
here r some specs from wikipedia:
LBZ
The LBZ (engine code "D") debuted in the later part of 2006 and continued into 2007 sold only in the "classic" body style. Its output is 360 hp (268 kW) at 3200 rpm and torque is 650 lbft (881 Nm) at 1600 rpm. The LBZ is mechanically identical to the 2006 LLY engine, however it has a more powerful tune loaded into the computer that allows it produce more power and torque. The LBZ is and will be known as the hot rod of diesel technology due to it being extremely powerful and able to be easily modified in contrast to the new diesels currently on the market that have stringent EPA regulations.
The following trucks have the LBZ engine:
Chevrolet Silverado HD
Chevrolet Kodiak
GMC Sierra HD
GMC TopKick
Chevy Express full-size (reduced power output mated to a 4l80E transmission)
GMC Savana full-size (reduced power output mated to a 4l80E transmission)
[edit]Specifications
Engine Code: LBZ
Displacement: 6,599 cc (403 cu in)
Bore x Stroke: 4.06 in (103 mm) x 3.90 in (99 mm)
Block / Head: Cast gray iron / Cast aluminum
Aspiration: Turbocharged & Intercooled
Valvetrain: OHV 4-V
Compression: 16.8:1
Injection: Direct; Bosch High Pressure Common-rail
Power / Torque: 360 hp (268 kW) @ 3,200 rpm / 650 lbft (881 Nm) @ 1,600 rpm
Source: [4]
[edit]LMM
The LMM specifications are nearly identical to the LBZ engine. It is a 6.6 L turbocharged engine and was introduced for the 2007.5 model year. Its output has seen a slight increase of 5 hp (4 kW) and 10 lbft (14 Nm) of torque over the LBZ. This makes it 365 hp (272 kW) at 3200 rpm and 660 ft (201 m)ftlbf of torque at 1600 rpm. It's mated to an Allison 1000 6-speed transmission. Engine performance curves can be found here : [1]
The LMM Duramax 6.6L V-8 has new equipment to help it meet the US EPA mandated 2007 emission standards. The new standard requires a 90-percent reduction in particulate matter (PM), compared with the previous standard, implemented in 2004, and a 50-percent reduction in oxides of nitrogen (NOx). The use of reformulated, ultra-low sulfur diesel fuel, which went on sale nationwide in the fall of 2006, is required to meet the new emissions standard and prevent damage to the emissions equipment. In addition the LMM utilizes a Diesel Particulate Filter (DPF) to trap all soot emitted from the engine. The DPF traps particulate matter aka(black smoke), when the computer senses a pressure differential between two sensors (one located before and another after the DPF) the truck enters a "regeneration" during this time the computer commands the fuel injectors to inject fuel after the cylinder has fired forcing raw fuel into the DOC (Diesel Oxidizing Catalyst) where the fuel is burned to elevate the temperature of the exhaust. This hot exhaust flows into the DPF and burns the trapped soot.
Engine Description: LMM
Valvetrain: OHV 4-V
Compression: 16.8:1
Injection: Direct; Bosch High Pressure Common Rail with CP3.3 Injection Pump
Power / Torque: 365 hp (272 kW) @ 3,200 rpm / 660 lbft (895 Nm) @ 1,600 rpm
Source: [5]
To meet the new emissions regulation in the US, the LMM Duramax 6.6 L V-8 engine features:
Additional combustion control, including an even more efficient variable-geometry turbocharging system, cooled (enhanced) exhaust gas recirculation (EGR) and closed crankcase ventilation to reduce nitrogen oxides (NOx)
Additional exhaust control, including oxidizing catalyst and new diesel particulate filter (DPF) to reduce soot and particulate matter
Increased-capacity cooling system
New engine control software
Use of low-ash engine oil (CJ-4)
The following trucks have or are due to have the LMM engine:
GMC Sierra HD
Chevrolet Kodiak
GMC Topkick
Chevrolet Express/GMC Savanah
post #10 of 11 (permalink) Old 02-17-2009, 09:49 AM
I guess that is why the oil shoots out of these things when you drain the crankcase!
Thanks for the great information.
