2007.5 + (GMT 900) Non Powertrain--New Body Style--Discussion 07.5 + Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect.
This truck does not have a ignition switched power outlet, they are always powered at all time. I found under the dash a wire that has power only when the ignition is on but it's pretty small and Im afraid to put a load on it. Anyone has found a bigger size wire ignition switched on a LMM?
__________________ 08 GMC Crew cab long bed 4x4 with 20'' xd spy and terra grappler 305/55/20. airaid filter and box. I just changed hypertech max energy set on stage 1 for better fuel economy to the quadzilla stealth 2 set on on economy and the difference is awesome. better driving, shifting and fuel economy.
P.S.
My fife didn't want me to buy the truck and buy all the upgrades for it so I decided to get rid of the wife!!!!!!
Location: Second star to the right and straight on till morning
Depends....what are you trying to power ? There are a bunch of circuits labeled in the engine bay fuse box as ignition....just pick a jumper fuse up from the local auto parts store....
My life in times is complicated, more complicated than most will ever comprehend. Going fast was the only thing that ever made me feel better about being me.
-Six Gun Todd
underhood fuse box there are a few, I'll go look in a few. I have 2 tap ins there and they are switched power.
also if you are gonna be loading any wires you better put in a relay....
Its not gonna be a big load, just gps, cell phone charger, laptop and little stuff like that but the wire was way too small to use it as ignition. Thanks guys I think Ill just run a new wire from the main fuse box under the hood and be on the safe side. at the same time i will hook up one of the power outlet so i will have one switched with the ignition.
P.S.
I hooked up my compressor with a relay to the underhood fuse panel, I dont remember the fuse number. I used the add a circuit or whatever its calles from autozone. Everytime I hook it up my DIC reads that i have a prob with trailer wiring and my cruise wont work? Unhook the add a fues and put the fuse back in normal and it goes away.
08 GMC Sierra
Summit White
Crew Cab
30% Tint
Edge Race
MBRP 4"
Go Rhino Steps
Why not run a relay and use the small ign. wire under your dash to trigger it on??
__________________ '05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Where are u getting the 12v Constant from- fuse block or positive battery jct. block? Should get it from the jct. block or from the pos. side of the battery- if that's what you are doing try a different fuse under the block for your relay trigger.
Pink wire in the middle of the 100 wire harness under the dash. You will find at least 3 pink wires in there, it is in the middle. Use a LED test light when you probe for that wire.
Alligator Diesel Performance - Chad Hall Owner 1-866-255-7212
Constant is running off the junction block. I'll check the fuse I used when I get off work. Its the only one I found that was switched. I would actually like to find one that only had power when the engine is running.
08 GMC Sierra
Summit White
Crew Cab
30% Tint
Edge Race
MBRP 4"
Go Rhino Steps
this has been done with lift pumps....
Run a power from battery, and put a oil pressure switch on a relay. Then you will only have power when oil pressure is up (engine running)...And your not taping into the other elec. components.
