| Premium Membership | |
| | | 2007.5 + (GMT 900) Non Powertrain--New Body Style-- Discussion 07.5 + Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect. |  |
01-31-2008, 02:45 PM
eBay Motors
#1 (permalink)
| | Member
| Lowering 2008 Dmax What is the best way or product to use to lower the font end 1" and the rear 3" on my 2008 2500HD Duramax? Can the front be lowered 1" by taking tension off the torsion bars? Will this affect the ride? |
| Advertisement
01-31-2008, 03:57 PM
eBay Motors
#2 (permalink)
| | Gear Jammer...
| I lowered my keys all the way plus took about 3/8 of an inch off of the keys to get even lower in the front. For the back i took two springs out. If you want to leave the springs Belltech sells a 3" lowering shackels! Lowering the front dosent affect the ride much at all.
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
01-31-2008, 04:44 PM
eBay Motors
#3 (permalink)
| | Senior Member
| Why would you want to lower it? Not sarcasstic, just curious..
__________________ 05' GMC 4WD SLT CREW CAB WITH 2 CARSEATS IN THE BACK!
FIRST DIESEL,
LOVE IT,CANT WAIT TO DO SOME MODS.
Air Box Mod... More to come...
Coolant Filter System, Courtesy of Dieselsite...
Hypertech Max Energy, Lots of Chrome!
Turbo resonator box plugged! Nice Whistle!
EGR Blocker Plate.... White Lighting light bar by RECON |
01-31-2008, 05:13 PM
eBay Motors
#4 (permalink)
| | DuramaxForum Fanatic
| ^^^^ yeah that
__________________ 2008 silverado dmax LTZ, aFe stage 2 ppe level 5, dpf delete, EGR block off plate , autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, fabtech tierods, 35"nitto a/t. 4"turboback exhaust straight pipe
, 5"stacks coming real soon 2008 traiblazer ss, straight pipe , 1.5" down |
02-04-2008, 12:35 PM
eBay Motors
#5 (permalink)
| | Member
| To answer your question of why I want to lower it is because I will be using my truck to pull a fifth wheel camper and I will either need to lower the truck or raise the camper. I am buying a new fifth wheel camper this spring and will make the decision then weather to lower the truck or raise the camper depending on what I get for a camper. Plus I do not really like the looks of the huge space between the tires and body on the rear. Chevy really jacked up the back end of these new body styles which is great if you want to put a leveling kit on and bigger tires. But I am going to stay with the stock size 265/70R17 for the best fuel economy. I do want to put some 18" or 20" chrome wheels on it so maybe I will go with a little wider tire if I can but I think I want to keep the same diameter tire as the stock size.
__________________ 2008 Silverado 2500HD Duramax Crew Cab |
02-04-2008, 04:35 PM
eBay Motors
#6 (permalink)
| | Gear Jammer...
| I lowered it because when you drag race in 4x4 u have to lower the front bars to keep from busting the tie rods up. So when you lower the front it looks like a big wedge with the a$$ end all up in the air. Plus, lower cuts throught the air better then higher!!!
02-04-2008, 10:18 PM
eBay Motors
#7 (permalink)
| | Super Man Moderator Points: 10,639, Level: 44 |
| Um a few friends of mine have chevys and pull a goose neck and dont have a problem pulling.. Any way if your pulling a gooseneck I definatly wouldnt touch the rear springs or youll lose the load capacity in the rear of the truck.
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
| Advertisement
