I am with tow master, 265's on the factory wheels should be no problem at all. The tires will put your rpm's down just slightly, but again the size difference is not that large so you should be fine. If the speedometer mis-calibration really worries you pro-comp makes a module to recalibrate the speedo: Pro Comp Suspension Systems
__________________ 05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
6000K HID headlights & fogs,
Upcoming mods: Lift pumps, Fully built tranny |
