| Premium Membership | |
| | | 2007.5 + (GMT 900) Non Powertrain--New Body Style-- Discussion 07.5 + Topics Not related to the Powertrain, interior, suspensions, body, wheels, tires, ect. |  | |
03-30-2008, 07:02 PM
eBay Motors
#1 (permalink)
| | Member
| Cognito 12" Kit Does Anyone Have Any Experience With This Kit? I Want One Bad And Cant Decide If It Is The Right One For Me... (im Tryin To Run 40's)
__________________ 2008 GMC 2500HD
CREW CAB SHORT BED SLT 6.6 DURAMAX W/ ALLISON
FULLY LOADED W/ NAVIGATION AND DVD'S IN HEADREST
WHITE EXTERIOR WITH BLACK LEATHER INTERIOR
CURRENT MODS: UWS BLACK DEEP TOOLBOX, 15% TINT FRONT AND 5% OVER FACTORY IN THE BACK, 305/70R16 BFG ALL TERRAINS, CUSTOM ALUMINUM ROD HOLDERS, PPE AIR BOX MOD, WHITE VENT VISORS, UWS BLACK BED CAPS
MODS TO COME: 8" FABTECH, 2 1/2" KEYWAYS, 37"X14.00"X16" SUPER SWAPER IROK, 16"X12" MICKEY THOMPSON CLASSIC LOCK WITH BLACK RINGS |
| Advertisement
03-30-2008, 07:52 PM
eBay Motors
#2 (permalink)
| | DuramaxForum Fanatic
| a friend has the 12" onhis 7.5 with 40s. its a pretty penny for all those goodies. i wanted more then a 6 but did not want to spend an extra 5000$for the lift
but if u got the money do it looks awesome
__________________ 2008 silverado dmax LTZ, aFe stage 2 ppe level 5, dpf delete, EGR block off plate , autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, fabtech tierods, 35"nitto a/t. 4"turboback exhaust straight pipe
, 5"stacks coming real soon 2008 traiblazer ss, straight pipe , 1.5" down |
03-30-2008, 09:31 PM
eBay Motors
#3 (permalink)
| | Senior Member
| saw an awsome lift if you can afford it, it's a strait axle conversion from rockkrawler.com ten inches of lift full 4 link front end and optional trailing arm rear end all with coil overs guy came into our shop with one on his 05 awsome. looked very well enginierd for the lift, dodge axle, drivelines, wheels, tyres, brake lines etc. $10,000
__________________ 2002 Crewcab short box 3/4 tonHD lb7 W/Allison stock, edge is gone soon to be replaced with ats e-power, 5" Jeg's Subway tunnel exhaust straight piped, cranked up torsion bars. cst 9- 11" lift comming soon! |
03-31-2008, 07:13 AM
eBay Motors
#4 (permalink)
| | Junior Member
| I've put 2 of em on here at my shop, and they are an awesome kit, no cutting of the front diff and all the stuff they have available to go along with it you will want to make sure you get the new anti-sway bar and front driveline from Cognito also. Obviously takes more time to install this lift but it is well worth it.
__________________ o6 CC,LB
ANCIENT CHINESE SECRETS |
03-31-2008, 08:57 AM
eBay Motors
#5 (permalink)
| | Senior Member Points: 11,722, Level: 46 |
| I have alot of experience with those kits. You can fit 40's under it on a new body but you can not use a really wide wheel. On a wide wheel your turning clearance will be tight and can rub. Let me know of any other info you need on this kit.
Nor-Cal Nick
__________________ 2008 Chevy 3500HD Dually LTZ <<< Clink on link to see truck.
Cognito 2-3 leveling kit, HD tie rods, Steering braces, Idler pivot, Front & Rear Sway Bar, Bistein's frt & rear, Sulastic shackles, Bags, Toyo MT 295/70r17 w/2" spacers, AFE stg2, MBRP 5" turbo back w/RBP back 6" tip, EFI Live by Duramaxtuner.com, Nexus gauges, Nicktane fuel filter, TTS Dual pumps & pick up, Transgo JR, MagHytec Trans & Diff pans, Titan 62gal fuel tank, Amp boards, 8000k HID Headlights and fogs, Drawtite Sig.24k 5er.
6-7-08 “400hp Fun Tune” >> 414hp./786tq.
6-7-08 “LMM08_08_HOT_6.07.08_Highboost” >> 440hp./805tq. |
03-31-2008, 04:11 PM
eBay Motors
#6 (permalink)
| | Member
| what about 17/40-16.5 ground hawgs on 16.5x9.75 black steel rims
03-31-2008, 05:02 PM
eBay Motors
#7 (permalink)
| With trimming it will clear. I have done it but it's tight. I would look at some 38's so you don't need to crank that much and then it will ride better.
Nor-Cal Nick
03-31-2008, 05:43 PM
eBay Motors
#8 (permalink)
| | Member
| Cool... I Want To Run Some Ground Hawgs So The 40's Will Have To Work... Do U Have Any Pictures?
04-04-2008, 10:48 AM
eBay Motors
#9 (permalink)
| | Junior Member
| a friend just put this kit on and his rubs like crazy with 40" toyos. He has 22X14 wheels though. He cut half of his innner fender out almost and still rubs slightly... |
04-04-2008, 10:54 AM
eBay Motors
#10 (permalink)
| Quote:
Originally Posted by nbomar a friend just put this kit on and his rubs like crazy with 40" toyos. He has 22X14 wheels though. He cut half of his innner fender out almost and still rubs slightly... |
Give us some more info ... did he add keys and UCA's ??
| Advertisement
