When you crank the torsion bars even halph a turn you start changing the geometry in the front end. Duramarks is right your alignment and camber are out and you have to get a alignment. Or your front tires will only last 5,000 miles and you will get horible vibrations like your getting. Also wthout a alignment its bad on the front end parts. Ball joints, tie rod ends etc. Right now your basically dragging the tires sideways down the street.
