Remote start - Chevy and GMC Duramax Diesel Forum
2011-2016 (Non Powertrain) Discussion of 2011-2016 topics not related to powertrain
post #1 of 58 (permalink) Old 11-04-2012, 04:25 PM Thread Starter
Remote start
Just got Truck, and doesn't have remote start. Do you guys recommend adding via dealer OEM, or aftermarket? Any suggestions?
Thanks guys
BB2500HD
BlackBeast2500HD is offline
post #2 of 58 (permalink) Old 11-04-2012, 09:08 PM
Go after market i think they have a lot more things you can do and have a longer distance you can start from.
2006 LBZ EGR BLOCKER, PPE STANDARD,6000W inverter, AMSOIL DUAL BYPASS, ALL AMSOIL FRONT REAR TRANS TRANSFER CASE, BACKUP CAMERA, EDGE CS GAUGES W/EGT PROBE, REMOTE START,PARROT HANDS FREE BLUETOOTH.4"in MBRP EXHAUST/WCAT DELETE PIPE,PCV REROUTE,ALL HEADLIGHT ON MOD.
rvjabo is offline
post #3 of 58 (permalink) Old 11-04-2012, 09:14 PM
MORSNO's Avatar
Stock is only a 1 way starter remote (you have no idea if it is running) and the operating range is very short. It will only run for 10 minutes unless you hit the button again to add 10 minutes to whatever has already ran.
Aftermarket offers a 2 way remote (it tells you that it is running) and you have a much longer remote range. You can also adjust the run time.
Now the one cool thing with the stock remote start is that you can now use a smart phone to operate your truck from anywhere through Onstar.
2012 GMC Sierra SLT 2500HD Z71
Reflex Spray-In Bed Liner, Undercover Bed Cover, Undercover Swing Case Tool Boxes, XPel Clear Car Armor Film, UltiMat DashMat, Rear Underseat Storage, Rough Country Stabilizer, F&R Dura Flaps, High/Low/Fog's All On Mod, 275/70/18 GoodYear Ultra Grip Ice WRT (Winter Shoes), AMP Research Power Steps, TorkLift Stable Loads, HD Timbren SES
MORSNO is online now
post #4 of 58 (permalink) Old 11-04-2012, 09:14 PM
Administrator
ob_1jr's Avatar
Definitely aftermarket. Anything by directed electronics (python, viper, clifford, etc)
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #5 of 58 (permalink) Old 11-05-2012, 05:40 AM
Aftermarket has its advantages like the others have said, but ultimately they are only as good/reliable as the installer. The factory remote start is "installed" on all new trucks already. You only have to buy the remote(s) and have it programed at your dealer. It might not have all the bells and whistles but there is no cutting/splicing required.
2011 Sierra, Extended Cab/Short Box. No mods
AaronLML is offline
post #6 of 58 (permalink) Old 11-05-2012, 07:39 AM
Super Genius
WileECoyote's Avatar
Is that true? Just buy the remotes I mean? I would love to be able to remote start but dont want to spring for someone to install.
2011 LML, Cognito, Edge, FASS.......blah blah blah
DELETED AND LOVIN IT!
Wile E. Coyote: Super Genius
ACME Race Team, Lead Driver
NO Wins to date, I just cant get around them damn anvils..................
Cliffs are a problem........occasional piano..........sometimes tunnels aren't really open.........it's that sumbitchin bird again, sorry, gotta go!
WileECoyote is offline
post #7 of 58 (permalink) Old 11-05-2012, 01:26 PM
If you have RPO Code AP8, you are pre-wired. Most trucks have it unless ordered with non-typical option packages like fleet vehicles from what I gather.
You still have to go to the dealer though to flash the BCM with an unlock code so not as simple as just buying the remotes and probably overpriced for what you get, but its a factory setup. Do a search on the forum and there are already a few threads on adding the factory start.
AaronLML is offline
post #8 of 58 (permalink) Old 11-05-2012, 01:56 PM
From my experience in the NE, remote starts are nice until you get stranded. It is not a matter of if, but when. If you have a chipped key, the chances are increase of a no-start. Even the best installers have issues with the module.
2012 2500 HD Z71 CCSB LTZ Gunmetal Blue
S&B Oil Intake
PCV reroute
Kitty missing since 6-20-14
PPEI tuning
NickTane adapter with 1r-0750 cat
Modified CAT 177-9778 base with 1r-0770 water sep.
HID low beams/fog lights DDM tuning (No DRL thank you)
Dirtymax716 is offline
post #9 of 58 (permalink) Old 11-05-2012, 02:22 PM
I have seen so many vehicles with some idiot installing a remote start, and it gets locked up, and then you have to trace every wire and check every connection, and there is no codes available if it is the module, You are relinquished to doing the diagnosis by the ripping and tearing method.
Factory installation is all just plug in and reprogram.
I have worked on engines all my life, spent 19 years at FreightlinnerI live in the Kootenay region of B.C. I have a 2007 NBS White 3500 GMC SLE Duramax Alison 17 inch aluminum SRW Crew-cab long-box White linex in the box and black in the wheel wells BW turn-over ball. all stock.
Johnp33 is offline
post #10 of 58 (permalink) Old 11-05-2012, 04:45 PM Thread Starter
awesome... thanks for the responses guys.
Might go with the Viper... alarm and remote start.
