275/70/18 - Chevy and GMC Duramax Diesel Forum
post #1 of 18 (permalink) Old 10-30-2011, 04:14 PM Thread Starter
275/70/18
I'm currently in the market for Snow tires for a 2011 2500HD LTZ 18in wheels. Not alot of options for the OEM 265/70/18, but I see that Ford and many others use 275/65/18 or 275/70/18's on new option upgrades. I'm looking at 275/70/18 E's Cooper Discoverer M/S studded which I have ran previously on half tons. I like the Nokian Hakka LT's but can't go that direction without 17's.
--Does anyone have 275/70/18's on a 2011 2500HD I could see pictures of, any info with rub isssues etc... Thanks
2011 2500HD CrewCab SB LTZ
AKSPIKE is offline
post #2 of 18 (permalink) Old 10-31-2011, 08:31 AM
The Peddler's Avatar
I've got LT275/70R18 Open Country A/T's on my LML. They're not on stock wheels, but the wheels are the same width and offset as stock. They rub a little on the splash guard/mud flap in full right-lock turns occasionally. If I trimmed the inside edge of the flap a little, it probably wouldn't rub any more.
Present: 2015 K2500HD LTZ Crew Cab Z-71
My Chevy Truck History:
2011 K2500HD LTZ Crew Cab LML
2007 Classic K2500HD LT3 Crew Cab LBZ
2006 K2500HD LT3 Extended Cab LBZ
2003 K1500 LTZ X-Cab Z-71 5.3 Liter Gas
1998 K1500 Silverado Z-71 5.7 Liter Gas
The Peddler is offline
post #3 of 18 (permalink) Old 11-01-2011, 04:34 PM
DENALI HD3500's Avatar
Stock rims , LT 285/65r18E 10 ply same as stock height but an inch wider. BFG All Terrain KO2. Not the best hiway tire ,but good for logging roads and snow, light mud. Has the snowflake rating for the new winter tire laws here in the north.
2015 SLT CCSB Summit White on Jet Black sunroof/rear slider/driver alert/ cooled/heated leather/nav/ telescope/tilt steer... Z71 package .
Previous:2002 LB7 ECSB
2005 LLY CCSB
2007.5 LMM CCSB
2010 CTD CCSB
2011 LML CCSB
DENALI HD3500 is offline
post #4 of 18 (permalink) Old 11-01-2011, 06:59 PM
NorskeNY's Avatar
From another posting:
One option that would be a match to the stock tire as far as tire diameter is a 285-65-18. Tire rack shows a few available in this size.
What would be nice about that size, is that there would be no need for reprogramming the truck, as both that size and stock size are 32.6" in diameter.
Another option would be to go to a bigger, more popular tire size. We had a customer who bought a 2011 HD with the 18's ask about bigger tires. I told him about a 275/70/18 but that would be bigger than stock (32.6" versus 33.2") and give a 1.7% difference in speed. The plus side to this size, is that availability of tires is much more vast. Tire Rack lists 24 E load tires.
Interestingly, Ford uses this size on Super Duty if I recall, and makes me wonder why GM didnt.
So...to simplify...If you would like to go slightly bigger and have more variety, go for 275/70/18. If you see what you like in a matching diameter tire, then try 285/65/18.
2011 Chevy Silverado 3500HD LTZ CCLB LML SRW 4X4 Blue Granite Metallic.
Towing a 2012 Cruiser Patriot CF335SS fifth wheel.
Previous DAs:
2005 Chevy Silverado 3500 LT CCLB LLY SRW 4X4 Silver Birch Metallic
2004 GMC Sierra 2500HD SE ECLB LB7 4X4 Sand Beige Metallic
NorskeNY is offline
post #5 of 18 (permalink) Old 11-01-2011, 09:39 PM
envelopo's Avatar
Denali HD3500, any issues with rubbing in that size. I am thinking about going to the exact same size when my stock michelins wear out. Also, did you detect any mileage loss when going to the slightly wider tire? Thanks
11 CCSB 3500HD LTZ 4WD - Blue Granite / Ebony
05 CCSB 2500HD LT 4WD - Dk Blue / Grey - SOLD
envelopo is offline
post #6 of 18 (permalink) Old 11-01-2011, 10:24 PM
mackyoudip's Avatar
These size changes are so negligible that any mileage loss would be unnoticeable. A 2" increase or more in tire Height, width, or both is when you will really notice mileage decrease.
Mack: 2004 lb7
1960 f100 Cummapart conversion
Ex's:2006 LBZ ppe tuned
2007.5 LMM s366. 12.4@109
mackyoudip is offline
post #7 of 18 (permalink) Old 11-02-2011, 11:51 AM
No rub anywhere, no MPG change.
2005 LLY CCSB
2007.5 LMM CCSB
2010 CTD CCSB
2011 LML CCSB
post #8 of 18 (permalink) Old 11-02-2011, 03:45 PM Thread Starter
Thanks for the input I located the 275/70/18 E's, and the 285/65/18 E's in the Firestone Winterforce LT's and Cooper Discoverer M/S.
AKSPIKE is offline
post #9 of 18 (permalink) Old 11-10-2011, 10:19 PM
I have the Coopers on my 2011 GMC LML same size as you are thinking about. Barley a rub when cranked left - zero rub cranked right. On the left the e brake cable is behind the plastic fender well and pushes it out some.Good tires I have 1000 miles on them great in mud and wet. No real snow yet here in Utah. I ran Blizzacks on 17 inch last year love those tires.
6mmsl is offline
post #10 of 18 (permalink) Old 11-17-2014, 03:48 PM
DirtEmax-USMC's Avatar
I am looking at Hankook 275/70R18 in the Dynapro ATm. Great tire. I am going up in size. i have 2 turns on my torsion bars and am wondering the possibility for excess rub
15.5 LML
BIG THANKS to BAMAOFFROAD
SHEEPDOG
Til-Valhalla The Dysfunctional Veteran
DirtEmax-USMC is offline
