front axel leak - Page 4 - Chevy and GMC Duramax Diesel Forum
2011+ LML Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 12-05-2012, 02:46 PM   eBay Motors  #31 (permalink)
KensAuto's Avatar
I understand they can blame a leaking axle seal on the lift/cv angles but to say powertrain warranty void is a little much
2012 GMC 2500 SLT 4x4
H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass
Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights
Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps
KensAuto is offline   Reply With Quote
Old 12-05-2012, 02:47 PM   eBay Motors  #32 (permalink)
LMLDenali11's Avatar
$500 to fix it
LML Denali HD 2500 Z71
7" Full Cognito Setup
BMF Novakanes / 37" Toyos
AFE / H&S / 5" Exhaust / FASS
AMP Steps / JL Audio
LMLDenali11 is offline   Reply With Quote
Old 12-05-2012, 03:56 PM   eBay Motors  #33 (permalink)
I'm going to do it myself $50 for the seal and $65 for some Amsoil
Old 12-05-2012, 04:00 PM   eBay Motors  #34 (permalink)
KensAuto's Avatar
Save some hassle and pull the whole rt. axle housing out...if you pull just the axle #1 its a bit** to pop out and #2 there's a thrust washer that may (will) drop, I think it's #9 in your pic...just use sillycone to put back together
Old 12-05-2012, 05:01 PM   eBay Motors  #35 (permalink)
Agreed that's what I'm doing.
This should not be hard at all with the silicone.
Old 03-26-2013, 01:35 PM   eBay Motors  #36 (permalink)
CODE4's Avatar
Throwing in my current situation:
2012 2500HD (build date of 10/11) with 19xxx miles. Just climbed under to do a quick once over and noticed both axle seals leaking gear oil :/ Not severe, as the front diff skid plate has little pooling on top of it. Probably happened in the last 1000 miles I am guessing.
No lift or suspension mods. Called the dealer, and they said they would set me up with a loaner while under service.
I am the type of person that would rather do this myself despite being a warranty item, but between work and kiddos, I really do not have the time to have the truck down in my own garage.
Will update after service.
2012 2500HD LML
http://zero-signal.org/2500HD/2500HD_sig_small.jpg
SGT/USMC | 0311/8541
CODE4 is offline   Reply With Quote
