Oil pressure - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 07-11-2012, 11:57 AM Thread Starter
Grasshopper101's Avatar
Oil pressure
When I started the truck this morning I heard the BEEP BEEP BEEP of the warning system. No lights and the gauges were normal. When I got the DIC it said "oil pressure low stop engine" then the light went out. The whole thing lasted 6-8 beeps. I shut it down and checked the oil level (after 10 minute wait) and it was normal. The truck ran fine the rest of the day.
Has this happened to anyone else had this happen and are there any ideas what could cause it?
There is 31% oil life remaining so I don't think there is a way for cavitation to be a factor and other than the BEEP there was no sound indicating a problem.
2011 GMC 2500 HD. First ever diesel and loving it.
PPEI tunes by Kory
Flo-Pro 4" exhaust with muffler
EGR blocker plates
DPF/DEF deleted
Air Dog Lift pump.
Edge CTS
Grasshopper101 is offline
post #2 of 10 (permalink) Old 07-13-2012, 08:28 AM
GMCustomerService's Avatar
How are things going with your truck? Did you have the vehicle into the dealership so they could, at the very least, get your experience into the system? I completely understand your time is very valuable, but having this type of thing within our systems can prove to be helpful if needed in the future.
I hope you have a great weekend.
Michelle, GM Customer Service
GMCustomerService is offline
post #3 of 10 (permalink) Old 07-13-2012, 03:44 PM Thread Starter
After the one incidence it has been fine. The gauge is reading the same as normal and I am ALMOST certain that it read normal when I scanned it during the start. I didn't get anything on the Edge so I don't think it threw a code. I will put a reader on it and get the info into the system this week. I leave for a long trailer pulling trip on the 1st and really don't want any problems.
PPEI tunes by Kory
EGR blocker plates
DPF/DEF deleted
Air Dog Lift pump.
Edge CTS
post #4 of 10 (permalink) Old 07-13-2012, 04:12 PM Thread Starter
I just went out and checked the Edge for DTC's and there were none shown. I will still take it in and get it on the record. Thanks.
PPEI tunes by Kory
EGR blocker plates
DPF/DEF deleted
Air Dog Lift pump.
Edge CTS
post #5 of 10 (permalink) Old 07-18-2012, 07:45 AM
I had that problem, 2011 GMC Denali HD, it was a bad wire going to the oil pressure gauge, the gray wire is what the repair info noted.
soark is offline
post #6 of 10 (permalink) Old 07-18-2012, 10:41 AM Thread Starter
Thank you. That is a lot better than a problem pump.
PPEI tunes by Kory
EGR blocker plates
DPF/DEF deleted
Air Dog Lift pump.
Edge CTS
post #7 of 10 (permalink) Old 10-26-2012, 11:25 PM
No oil pressure
I have a 2011 duramax, a week ago while on my way to work my truck said service diesel exhaust fluid system. I called the shop and they threatened me and said it will cut you back to 55 mph. I drove the 400 miles to work and parked the truck. Two weeks later I began the drive home and it cut me back to 55 mph on a road where the speed was 75 mph. After almost being killed by my truck I ordered a dpf delete! I installed it and it worked great, shortly after the install my oil pressure went to 0 for a few seconds and has been doing this regularly now. I have checked the oil pressure with a Manuel pressure gage and the oil pressure is fine. I replaced the sending unit twice and flushed the motor and changed the filter. Still going to zero. Monday I will put it in the shop and have to hear about putting a programmer on the truck. I would rather live and pay for the fix then die due to an engineering snafu! If anyone knows what and how to fix this please let me know.
Narc705 is offline
post #8 of 10 (permalink) Old 10-26-2012, 11:52 PM
GMC..Professional Grade
KensAuto's Avatar
try putting the stock program back in....mine actually just did this a few weeks ago but mine was the sender...with only 6000 miles on it
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #9 of 10 (permalink) Old 02-01-2013, 11:39 AM
My 2012 GMC 2500 HD just done the exact same thing this morning. I started the truck and the gauge dropped to 0, the back up to 90 or so... Got the " low oil pressure please stop engine " warning.... So I checked the oil, oil level is fine. The truck has 5300 miles on it, and I am curious as to what the problem is. Anyone know anything about this??
Greg C.
2012 GMC Sierra 2500 HD Crew-Cab
Stock Equipment
grego is offline
post #10 of 10 (permalink) Old 07-23-2014, 11:48 AM
2013 GMC 2500 HD Oil Pressure Problems
My 2013 GMC 2500 HD I started the truck and the gauge dropped to 0, the back up to 90 or so... Got the " low oil pressure please stop engine " warning.... So I checked the oil, oil level is fine. The truck has 3100 miles on it, and I am curious as to what the problem is. Anyone know anything about this??
sagecrest795 is offline
