2012 fuel filter relocation - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 10-24-2012, 05:02 PM Thread Starter
Guest
Hello everyone. Newbie here so please be kind. I transport cross country so im having to change fuel filters about once a month and the factory location is a pia due to having to take the inside fender cover off. Does anyone know of a kit or a way to relocate it to a more accessible place and not throw a dtc.
Cayenne is offline
post #2 of 6 (permalink) Old 10-24-2012, 05:24 PM
GMC..Professional Grade
KensAuto's Avatar
someone makes a trap door for the inner fender, sorry dont remember who....havent heard of relocating the stock setup but some guys install a lift pump with filters (like myself) and you can buy an empty cap that replaces stock filter
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #3 of 6 (permalink) Old 10-24-2012, 07:03 PM
How many miles are you getting on a filter? The current Delco filters are lasting MUCH longer than the previous versions.
In any case the wheel well filter access cover/door makes changing the filter easier.
redwngr is online now
post #4 of 6 (permalink) Old 10-24-2012, 07:54 PM
DENALI HD3500's Avatar
Most diesel aftermarket outlets will have the trap door in stock, use one of the site sponsors of your choice. Makes changing the fuel filter a 5- 10 minute job. They also have a special socket to re and re the WIF sensor at the bottom of the filter, instead of useing channel lock pliers and risk damaing the sensor, only use the socket to remove the WIF, hand tight going back onto the filter is all you need with the o-ring seal, and relatively low pressure at filter. You should be getting 50,000 kms (30,000 miles) out of the improved filter with your type of driving.
2015 SLT CCSB Summit White on Jet Black sunroof/rear slider/driver alert/ cooled/heated leather/nav/ telescope/tilt steer... Z71 package .
Previous:2002 LB7 ECSB
2005 LLY CCSB
2007.5 LMM CCSB
2010 CTD CCSB
2011 LML CCSB
DENALI HD3500 is offline
post #5 of 6 (permalink) Old 10-24-2012, 08:20 PM Thread Starter
Guest
Wow had no idea they would last that long. Just switched froma a jokestroke to the dmax (will never go back) but we were lucky to get 15000 from one of their motorcrap filters.
Cayenne is offline
post #6 of 6 (permalink) Old 10-25-2012, 01:28 AM
Something to also consider is using a nickname or under ground diesel adaptor and use a cat 1r0750 filter and put in a base in the back for a cat 1r0770 water separator. The water separator is 3 micron absolute and the filter is 2 micron absolute. The filter which would be under the hood could go for around 40-50k miles. Water separator could be changed easy under the truck. Just another thought.
2012 2500 HD Z71 CCSB LTZ Gunmetal Blue
S&B Oil Intake
PCV reroute
Kitty missing since 6-20-14
PPEI tuning
NickTane adapter with 1r-0750 cat
Modified CAT 177-9778 base with 1r-0770 water sep.
HID low beams/fog lights DDM tuning (No DRL thank you)
Dirtymax716 is offline
