Oil change and routine maintenance - Chevy and GMC Duramax Diesel Forum
2011+ LML Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
Old 11-23-2012, 07:41 PM   eBay Motors  #1 (permalink)
This is my first diesel and after 9 months of ownership and only 3600 miles, I'm about ready to change the oil. I plan on having this thing for a long time so I want to ensure I take appropriate care for longevity purposes and not to "skip" something cause it'll cost me an extra $100.
So I'm about to move to Ohio from Texas. This might be a stupid question but is there a heavier oil I should ask the dealership to use? Anything else I should look into due to the colder weather?
I've got a free oil change and I was thinking of having them change the Allison filter. Will they change the fluid too or just the filter? How much does this usually run? Any other routine maintenance that I should have them perform?
I'm also reading several things about fuel additives. Is this something I should look into? Again, I apologize for the newbie questions but I'm used to just doing oil changes and that's it for my gasser.
'11 GMC 2500 Storm Gray CC Leveled
Cog UCAs | tie rod sleeves| Pitmann/Idler Supports | Fox 2.0 Performance Shocks| 305/55 20 Cooper LTZ's | Fuel Octanes| LEDs|
mastrcruse is offline   Reply With Quote
Old 11-23-2012, 07:47 PM   eBay Motors  #2 (permalink)
DenaliDuallyHD's Avatar
Welcome!!!! A lot of what you are asking has already been posted.
JohnnyO
2012 Denali Dually HD 4x4
Banks Exhaust, Ram-Air & Custom Super-Scoop
Line-X, BedStep, BedStep2, Bed Rug
B&W Turnover Ball Hitch with Companion 5th Wheel Hitch
American Work Cover-rolling cover/toolbox w/ B-light tonneau lighting system
1993 GMC 1500 SLE Extended Cab Short Box, 4x4, 5.7 gas, traded it for:
1996 GMC 3500 SLE Crew Cab Dually, 4x4, 7.4L gas, sold it and got a:
2003 GMC 2500HD SLT Crew Cab Short Box, 4x4, 8.1L gas, traded it in for the 2012.
DenaliDuallyHD is offline   Reply With Quote
Old 11-23-2012, 07:56 PM   eBay Motors  #3 (permalink)
Thanks I appreciate the help. I've read the interval threads ect. And it seems that the tranny filter change is cheap insurance. I'm interested to know if there at particular things I need to do since this is the first ones and I'm about to move from hot to cold temps. Also interested to know if the lml is different as the threads I'm reading seem to be more for lmm.
Old 11-23-2012, 08:06 PM   eBay Motors  #4 (permalink)
bigjohn's Avatar
That's the great thing about the forum willing to help out when needed.
2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again.
2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ.
LET'S GO PENS!!!
bigjohn is offline   Reply With Quote
Old 11-23-2012, 08:16 PM   eBay Motors  #5 (permalink)
In2Trux's Avatar
Everything your reading about the LMM you can apply to your LML. (with the exception of the uria) Not to be rued but you calling Ohio cold made me smile
I haven't got my hands on one yet, but your owner's manual will describe in better detail the temperature thresholds of your different oil viscosities and when to use them
Glenn
2007.5 Silverado CCSB LTZ Z71 GFX 2500HD
Glowshift Pill 3 Gauge pod
Autometer Cobalt Gauges
BFGoodrich T/A KO 265 70R 17 stock rims winters
TOYO All Terrain Grapplers 265 70R 17 summer
American Racing Dale Earnhart Signature Series Rims
In2Trux is offline   Reply With Quote
Old 11-23-2012, 08:37 PM   eBay Motors  #6 (permalink)
Thanks. Haha...I guess ohio isn't cold to you....definitely cold compared to Texas. Hell it was 85 degrees just 2 days ago.
So what I've learned from reading is...
Tranny: change the filter only, no need to drain fluid. Fill it up with transynd and screw back on. Use Allison filter.
Oil: bring napa gold filter or AC Delco filter to dealership and ask for recommended oil for "cooler" weather. I've read that the trucks down here get 15-40 but the recommendations for cold starts are 0-40 or 10-40.
Old 11-23-2012, 08:55 PM   eBay Motors  #7 (permalink)
Banned
expect to pay around 50 bucks for just the spin on trans filter at the dealer, then about 150 for the oil change.
Old 11-23-2012, 09:00 PM   eBay Motors  #8 (permalink)
Part of my negotiation for the truck was 2 free oil changes. I can change the spin on oil filter myself. Sounds like I just spin it off, fill it with the same amount of fluid in the old, make sure I have the magnet, and then spin back on. Or I just bring my own Trans filter to the dealer.
Old 11-23-2012, 09:03 PM   eBay Motors  #9 (permalink)
In2Trux's Avatar
I've had my truck for 3 yrs now... I used a quaker state oil filter once and quickly went back to the AC Delco filter cause I wasn't getting immediate oil pressure at start-ups
Turns out The AC Delco filter has some kind of a back pressure valve in the filter. (very important)
I've run Shell Rotella T 15W40 100% Synthetic Motor Oil all year round My truck still starts even in -5 F
Around 15 F I will plug it in for a few hrs before starting it.
Tranni filter I will replace every couple of motor oil change.
Front end will get grease at all 11 grease points at every service.
I do all my own truck service
Glenn
Old 11-23-2012, 09:06 PM   eBay Motors  #10 (permalink)
HD Dmax Machine's Avatar
If your trans still has factory fill conventional Dex 6 fluid use that to fill up the spin on trans filter. The dealer would use a ACDelco spin on filter & add conventional Dex 6 fluid. So if you have Transynd in your trans bring some with you.
The dealer will use ACDelco oil filter, 15W-40 conventional or 5W-40 synthetic oil (whichever you pick.)
& yes use a fuel additive. Now on what brand is "best" you be the judge. Try some brands out & see which you like best.
2009 Sierra 2500HD LMM SLE CC/SB 4x4 Stock.
Pacer LED NBS Cab lights, Putco yellow bulb Fog lights, GM Dually light bar, Footwell lights, Tinted windows, GM chrome oval Running Boards, Fumoto oil drain valve, Bilstein HD shocks, PY0 wheels, Michelin LTX M/S2 LT245/75R/16E, Rear rubber Mud Flaps, Curt Hitch class IV, Kenwood speakers, Cobra 29 CB radio, Wilson 2000 CB antenna
2011 Silverado 2500HD LML WT EC/SB 4x2 Stock. (Co. truck)
Originally Posted by The Derp
Everytime "The Derp" gets a CEL the code comes back as ID10T, user error.
Originally Posted by John Caparulo
I went to Canada for 6 weeks. Everybody's French, which is creepy. People runnin' around, speaking French. I'm not used to that. I'm used to America, where everybody speaks Spanish.
HD Dmax Machine is offline   Reply With Quote
